Old 03-25-2009, 11:19 AM   #1
Default s960 os1 to os2
anyone got any pictures of their front os2?
1 with the wheel on and 1 without it
front only
appreciate it if someone could do this.
yappy is offline   Reply With Quote
Old 03-25-2009, 11:31 AM   #2
nitrodude's Avatar
What do you need to know?
The smaller diameter side of the aluminum whashers go towards the bearing, one on each side of the knuckle. I have 3 spacers on the wheel side of the knuckle under the drive pin.
Ill try to get some pics.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 03-25-2009, 12:38 PM   #3
yes i need assistance in setting it up
post pics please!
what do you mean 1 on each side of the knuckle ( where exactly )?
well after i finished mine, i tried a standard kyosho/mugen wheel on and the QR snaps onto the rim but it doesnt snap on by awhole lot. If i pull on the wheels hard they fly right off and that can't be good going at high speeds
I must be doing somthing wrong.
Old 03-25-2009, 12:59 PM   #4
nitrodude's Avatar
You put one washer on the axle before you insert it into the knuckle, then put another washer on to the axle on the front side, where the wheel goes. So when its all together you have (starting from the inside, where the cvd is)axle, washer, bearing, bearing washer. Then you add shims between the washer and the drive pin.
You do have the aluminum washers, right? The ones that are tapered on one side. Those are ones Im talking about.
http://www.serpent.com/product/903290
These?
Steven Muller
Ronin Speed Parts
Old 03-25-2009, 01:13 PM   #5
nitrodude's Avatar
Heres some pics, sorry for the quality, my camera is at home and this one is not very good.
Steven Muller
Ronin Speed Parts
Old 03-25-2009, 01:15 PM   #6
nitrodude's Avatar
Also, what wheels are you using? Jaco and Xceed wheels fit a little tight, it takes some effort to get them to clic. The one on the pic is a Kawahara tire, it slips right on. Let me know if you need any more help.
Steven Muller
Ronin Speed Parts
Old 03-25-2009, 01:19 PM   #7
Yes i have similar washers, its kyosho but same measurements.
I will add the washers how you said it and let you know later, I didn't set mine as to how you said it.
thanks for the pictures, i have a better idea now and from you explanation.
the tires are twister, they slide right through and CLICK but the QR isn't as far over as your wheel in the picture.
Old 03-25-2009, 01:21 PM   #8
thinking about it, i think the problem will be fixed once i do it as you explained.
will let you know later tonight
Old 03-25-2009, 03:41 PM   #9
M7H
M7H's Avatar
I drive my car with Twister, and they fit.
So you should be able to figure it out....
1 thing though, if You go to Kawahara, which I also have, they are just a tiny bit wider, so you need more shims on the outside, to offset the wheel more, just as in the pictures of nitrodude...
Serpent
M7H is offline   Reply With Quote
Old 03-25-2009, 04:00 PM   #10
nitrodude's Avatar
I havent tried the twisters on, but on some wheels you have to push the lever because it doesnt snap all the way, the wheel has flashing and it gets in the way.
Steven Muller
Ronin Speed Parts
Old 03-25-2009, 08:35 PM   #11
thats exactly my problem, so i guess i had everything on correctly.
the wheel wasn't snapping all the way, i have to push the lever over more for it to clip full way.
does this mean i have to keep doing this once i am using twister tires?
Old 03-25-2009, 09:37 PM   #12
Team Kamikaze's Avatar
Switch to the new XCEED/JACO tires (6 spoke rim) then you won't have any problem.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 03-26-2009, 08:18 AM   #13
Thanks for the help guys!
