Old 11-29-2003, 10:03 AM   #1
Send a message via AIM to donthaveaclue
Default Help On Break In Please
my friend has put 10 tanks through his car, and still the max speed is like 20 what should we do to fix the problem? or what could it be? we have leaned it out about 1/2 a turn, what else could this be?>
donthaveaclue is offline   Reply With Quote
Old 11-29-2003, 03:04 PM   #2
ziggy12345's Avatar
More info needed. Engine? Size? Nitro%?
Cheers
ziggy12345 is offline   Reply With Quote
Old 11-29-2003, 03:27 PM   #3
fe-15 .15 engine 1/10 scale 20% nitro
Old 11-29-2003, 09:36 PM   #4
rushdude's Avatar
Send a message via AIM to rushdude
When you hit the throttle is the engine revving?
rushdude is offline   Reply With Quote
Old 11-30-2003, 04:29 AM   #5
not fully, its like 10,000 rpm or so, just a guess, i think were running REALLY rich, its spits gas, so thats the problem most likely, cuz we just left it box tuned
Old 11-30-2003, 05:08 AM   #6
ziggy12345's Avatar
Sounds like its really rich top end. You will need to screw in the top end needle. If its that bad try 1 full turn.
Make sure you run it on the track along a straight at full revs for at least 3-4 seconds as the engine needs to clear the mixture in the crank before it sees the effect of the adjustment. If it worked the engine will pick up and rev well aafter 2 seconds.
Another problem could be that the head clearance is too big. Take out the plug and insert a piece of solder into the head and turn over the engine by hand. The piston will flatten the solder against the head.
remove the solder and measure with a vernier. It should be about 0.018" or 0.4mm
Make sure you are running a hot plug. C5 TGF Novarossi
Break In jlinds Nitro Off-Road 5 07-26-2008 10:44 AM
break set up? roy862 Nitro Off-Road 3 02-29-2008 06:45 PM
New O.S. eng break in? kcsoa22 Monster Trucks 2 09-02-2005 10:40 PM
Break In Dirtfreak15 Monster Trucks 7 05-26-2005 05:30 AM
MT 12 break in Fastburn Nitro On-Road 14 03-28-2003 04:54 AM
