-   Nitro On-Road (https://www.rctech.net/forum/nitro-road-3/)
-   -   i need more braking power to my 1/8 DM 1 Spec (https://www.rctech.net/forum/nitro-road/284483-i-need-more-braking-power-my-1-8-dm-1-spec.html)
greenracing 03-23-2009 05:32 PM
as the title says, i need more brake, first lap or two the braking is fine, then it is like i toss the brake away!!! no brake....i read in a thread that some of the guys are putting dual disk from the CTR...so can anyone can point me it the right direction to make this mod? thanks!!!
tbo713 03-23-2009 07:14 PM
try to clean your pads with alcohol or a strong servo
greenracing 03-23-2009 07:39 PM
well i have a 9100T so i know the servo is not the problem....it is just the disk is too small for a big car...i want to convert to a 2 disk but i dont know how to do it...
aft53 03-24-2009 07:33 AM
I just took my DM-1 Spec out for the first time for practice last weekend. I had installed the Ofna special brake pads (36659) with the laser cut steel rotor (49009). I had more brake than I could use and ended up turning it way down on the radio. Give them a try. You can find them in the "Option Parts" section of DM-1 Spec parts if you look them up on the Nitrohouse website.
sandfan85 03-24-2009 05:10 PM
+1
greenracing 03-24-2009 06:38 PM
thanks guys!!! i didn't know nitrohouse have DM1 parts!!! thanks again:):)
tbo713 03-24-2009 07:53 PM
they specailize in dm-1 parts
Powered By: vBulletin v3.9.3.4
Content © 2001-2011 RCTech.net
