Old 06-13-2007, 09:55 AM   #1426
Arno's Avatar
Any feedback from the 301 race from anyone that used the 07 converstion? And please post the set up also if possible.
Arno is offline   Reply With Quote
Old 06-13-2007, 10:33 AM   #1427
aaron_buran's Avatar
See attached, my car was great, Q2nd... Finished 6th, engine gremlins kept me off the track in the main. Ran an 18.5 in the main.
Horizon Hobby, JR Propo, Spektrum, Parma PSE, Faskolor, Tornado Racing Fuel, Calandra Racing Concepts, Murnan Modified Motors, Kyosho America
aaron_buran is offline   Reply With Quote
Old 06-13-2007, 01:57 PM   #1428
I just realized I have the rear and front tire size and ride height listed backwards. Sorry,
-A
Old 06-13-2007, 02:03 PM   #1429
Arno's Avatar
-A
Yeah I saw that and I figured it out, I was like how is he running the front of the car higher than the rear, then I saw the tire sizes and figured it out.
Old 06-18-2007, 10:09 AM   #1430
Default Brake Problem
Hi Guys
I just completed building my car and I have the following problem:
When I leave my throttle the car automatically engages the brake = correct.
When I accellerate slightly (35%) then the no brake and the car rolls smoothly.
When I accellerate full (100%) the brake engages again = not correct.
Any ideas why this would be. The car not run yet, still brand new - does it need to wear in?
Regards
Acid
Acid is offline   Reply With Quote
Old 06-18-2007, 10:32 AM   #1431
Arno's Avatar
Originally Posted by Acid View Post
Hi Guys
Regards
Acid
Can you take a picture of the throttle linkage and post so we can see how you have it set up.
Old 06-18-2007, 11:23 AM   #1432
Acid - Disconnect your linkage and see if the stop mechanism provided by the underside of the brake arm and the top of the sway bar bracket is doing it's job correctly i.e. not allowing the cam to go beyond center, I'm assuming you've still have stock parts, I've always used a very soft spring on the return side so as not to overstress this area - that might be your problem.
Rick Davis is offline   Reply With Quote
Old 06-18-2007, 03:33 PM   #1433
Winner's Circle's Avatar
Hi Guys
Regards
Acid
Take a look at the spring and collar on the brake linkage side. If the collar is pressing on the spring at all it will cause the brake to be put on at full throttle. I suggest that you loosen the collar and move it well away from the spring.
Winner's Circle is offline   Reply With Quote
Old 06-19-2007, 01:07 AM   #1434
moy
moy's Avatar
does your delta xp4 batt pack fits the evolva?
moy is offline   Reply With Quote
Old 06-19-2007, 01:12 AM   #1435
Default Rear upper a arm
Understand you are using long rear a arm. Do you find long upper rear arm to have better side traction in combination with the new blocks?
-A
slide_228 is offline   Reply With Quote
Old 06-19-2007, 09:27 PM   #1436
nitrodude's Avatar
Is there a spring chart for the car? Im still running the stock black springs and I wanted to get a couple of different springs so I can work on a set up, maybe 2 softer and 2 harder than stock, front and rear.
nitrodude is offline   Reply With Quote
Old 06-19-2007, 11:32 PM   #1437
nikoskar's Avatar
Just check how many coils and thickness have the new springs and compare them with your old. You find out very easy which spring is soft and hard
nikoskar is offline   Reply With Quote
Old 06-20-2007, 12:00 AM   #1438
RRRoy23's Avatar
check this out. http://rams-club.com/yabb/Attachments/Springs.jpg
courtesy of Rams Club.
ARC R11, UF1 Team Force India, Tamiya F104 PRO Black
RRRoy23 is offline   Reply With Quote
Old 06-21-2007, 01:30 PM   #1439
KyoshoEvolva03's Avatar
Kyosho Kicks Ass.........Sorry guys just having Kyosho moment.......
KyoshoEvolva03 is offline   Reply With Quote
Old 06-21-2007, 01:54 PM   #1440
Arno's Avatar
Kyosho Evolva M3 tomkelley Nitro On-Road 1002 05-19-2015 08:49 AM
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
