Old 05-06-2007, 08:18 PM   #1291
SRAD's Avatar
Originally Posted by Snowy
The instructions that come with the conversion kit say if you use the silver blocks, then use the old arms becasue the rear will be too wide with the new arms.
I cant confrim if this is true, have not installed the kit as yet.
Makes sense. Either way even with the conversion installed I'll have plenty of the older longer arms common to the 05 car in the tool box. Thanks
SRAD is offline   Reply With Quote
Old 05-06-2007, 08:18 PM   #1292
cdelong's Avatar
I just talked to Ted Hammer.... the black 7mm/3.5 blocks are required for the '07 conversion kit. The others will not work.
Guess I need a pair- anybody know where to find some?
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 05-06-2007, 08:22 PM   #1293
SRAD's Avatar
AHHHH!!!! Those babies aren't cheap!! I thought so...as the 07 conversion was designed around the WCE car I believe.
Old 05-06-2007, 08:57 PM   #1294
Super Moderator
Snowy's Avatar
Trader Rating: 14 (100%+)
They also say you need to use the 2 Degree knuckle arms, like the standard 05 used. The 05 WC uses the 0 Deg arms as standard.
Racing Lines Magazine
Snowy is offline   Reply With Quote
Old 05-07-2007, 06:34 AM   #1295
aaron_buran's Avatar
I ran all the 07 stuff this weekend at the Midwest Series race.
Correct, you must run the 7-3.5 blocks with the new lower a-arms. The Cincinnati track had very low bite, so I ran the old long upper a-arm with the new body mount. To run the old a-arm with the new body mount you must narrow the bosses on the a-arm so the body mount uprights fit. The rear body mount adjustability was invalueable on the low bite track. I ran the body on the 2nd highest setting.
Horizon Hobby, JR Propo, Spektrum, Parma PSE, Faskolor, Tornado Racing Fuel, Calandra Racing Concepts, Murnan Modified Motors, Kyosho America
aaron_buran is offline   Reply With Quote
Old 05-07-2007, 09:15 AM   #1296
bsmooth's Avatar
Trader Rating: 17 (100%+)
Are you guys running the 'stock' tie rods and camber adjustment rods? Using a piece of piano wire to make adjustments is becoming a real bitch!
I thought of getting some rods from Lunsford, but I don't see anything for the Evolva from them.
Thank you for any help.
Regards,
Steve
bsmooth is offline   Reply With Quote
Old 05-07-2007, 09:18 AM   #1297
cdelong's Avatar
Aaron.... could you possibly get me pair of the 7mm/3.5 blocks? No one has any.
How do I tell the difference between the 7mm and 7mm/2 blocks? They are both silver and there are no markings. I think I have 7mm/2 blocks right now.
Corey DeLong
KYOSHO EVOLVA
35PLUS21
Old 05-07-2007, 09:18 AM   #1298
I use a small alen wrench that I cut down, it works great.
Old 05-07-2007, 09:20 AM   #1299
Sorry Corey, only have one set, have you checked with Robert at Ashford?
The only other way to tell is by measuring them,
Old 05-07-2007, 09:24 AM   #1300
cdelong's Avatar
Robert has them on backorder
What do I measure.... pin height?
KYOSHO EVOLVA
35PLUS21
Old 05-07-2007, 09:43 AM   #1301
Arno's Avatar
Regards,
Steve
I use these and they work great with no frustration
http://buy1.snapon.com/catalog/item....re&dir=catalog
Arno is offline   Reply With Quote
Old 05-07-2007, 09:51 AM   #1302
From the side of the block to the hole with your calipers.
Old 05-07-2007, 11:26 AM   #1303
dougday's Avatar
Aaron, How did the car handle in relation to the 05?
dougday is offline   Reply With Quote
Old 05-07-2007, 12:49 PM   #1304
Aaron is essentially correct - the 7 is the dimension in miilimeters from the chassis surface to the pin centerline, the 2 (or 3.5) is the dimension inboard from the original (first generation ) lower blocks. By the time i became involved with the car in the summer of 2004 the 7-2in was the kit part, I've only seen one 7-0 that Dana Smeltzer got by mistake, a quick way to tell if you've got 7-0 or 7-2 is the on 7-2 the pin is inboard of the set screw centerline.
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - IGT8 2017
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 05-07-2007, 12:51 PM   #1305
It's hard to say with so little traction, not a night and day difference, I just had more tuning options that I didn't have in the past, the body mount itself was an asset with the low bite. I couldn't have thrown any more aero-downforce at the car, with the old body mount it wouldn't have been an option. The other big advantage is durability of the lower rear a-arm. I have backed the car into a board hard a couple times, and have driven away. The old a-arm's would have broke.
Kyosho Evolva M3 tomkelley Nitro On-Road 1002 05-19-2015 08:49 AM
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
