Old 01-04-2007, 05:24 PM   #1051
aaron_buran's Avatar
They are only available for the swingshaft/CVD axle type. Which IMO are the only ones to be running especially in the front.
Horizon Hobby, JR Propo, Spektrum, Parma PSE, Faskolor, Tornado Racing Fuel, Calandra Racing Concepts, Murnan Modified Motors, Kyosho America
aaron_buran is offline   Reply With Quote
Old 01-04-2007, 05:26 PM   #1052
Hey Aaron,
Congrats on the new edition! Is this your first child?
Oh yeah, thanks for your input on the car!
[FONT="Arial Black"][SIZE="2"]team kyosho / empire racing / speedmerchant / ko propo / novarossiusa.com / phat skeems paint works / 301 raceway [/SIZE][/FONT]
NitroHead is offline   Reply With Quote
Old 01-04-2007, 06:03 PM   #1053
Thanks,
No, its our second...
No problem, let me know if you make any progress on the setup.
Old 01-04-2007, 08:21 PM   #1054
Originally Posted by aaron_buran
Thanks,
Nice... Enjoy your blessings.
As far as the set-up goes...
I noticed towards the end of last season MRX4R's had ALOT of corner speed...
Though I was able to hang with them, I found myself driving alot harder to keep up... The 4's seemed like they slowed very little or not at all for pretty sharp turns... I had to go in slow and come out fast...
I hope these new rear upper a arms do the trick, giving more side bite thru 180's
Old 01-05-2007, 07:05 AM   #1055
Rick Vessell's Avatar
Aaron,
Congrats on the new baby! How's Holly doing? Looking forward to this year's MWS schedule, I should actually be able to make a few this time! I'll be in touch soon to get base setups for all the tracks.
Take care,
Rick Vessell
Rick Vessell is offline   Reply With Quote
Old 01-05-2007, 03:25 PM   #1056
whynot's Avatar
Trader Rating: 18 (100%+)
Are you guys using AA or AAA batteries in your evolva's I have a AA pack but it seems to be just a bit to wide.And Does anyone lower the gas tank so that it just sits on the top of the battery.
mike
whynot is offline   Reply With Quote
Old 01-05-2007, 03:58 PM   #1057
fraz's Avatar
Send a message via AIM to fraz
mike
I have used a 2000mAH AA pack since I built the car and love it. I was still underweight (originally) and all the big weight stays low. There is a trick to making a pack to fit in the tight battery opening. You can open it up with a Dremel like some people I have seen, or build the pack a little narrower. My 2000 cells are a tiny bit shorter and much smaller in weight and diameter than the current 2400/2600 cells.
Make sure you get the thinner heatshrink for starters and then I make my connections with this stuff http://www.electronicsic.com/wick.htm It is pure copper and flows electricity great. Make sure you don't go hog wild on the amount of solder and you shouldn't have any buildup problems.
There is one other thing you can do pre-build if you are super careful. Get a tiny hammer and tap the positive nubs down a little bit. Just a tick so you don't damage the internal cell structure but it should get you much more clearance.
Aaron, spill it on the offset axles How are they offset? What is the goal? More/less scrub set spacers or different positions? Is the dogbone itself any different in length? Enquiring minds wanna know
fraz is offline   Reply With Quote
Old 01-06-2007, 08:21 PM   #1058
Grenade10's Avatar
Trader Rating: 37 (100%+)
I've listed my 2005 Evolva, Motor, Parts, Tires here on RC-Tech.
Time to clean out the closet!!
Good buys on everything!!
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 01-08-2007, 05:52 AM   #1059
fraz,
I haven't seen them yet, I should have a set this week, more scrub usually equals more steering, almost like running more caster. The set that I have (delta), let you offset the wheel 2mm. You don't have to do anything with the swingshaft, if you put the shims on the inside (to run no offset) just remove a spacer behind your one-way drive if necessary.
whynot,
The chassis opening is really narrow, if you run the kyosho NiCad packs they fit perfect, if you run NiMh batteries they are usually very tight. Many of us mill our chassis a bit so we can run NiMh batteries without risking shorting them out. They will fit, but they are very tricky to align and install/remove. Also roughen up the battery plate and use 5 minute epoxy & strapping tape to attach them to the plate. We have seen the batteries get loose then break at the solder joints, if not glued to the battery tray on bumpy tracks.
Old 01-08-2007, 06:45 AM   #1060
rpoage's Avatar
Fraz, you might want to rethink your choice of battery connector. I have a LOT of SMP battery experiences and that stuff has lead to more that a few run a ways. It saturates with solder and becomes brittle from movement and vibration and cracks. I suggest using pieces of copper flat stock you can buy or make. A good general hobby shop (planes and trains) will have this. In a pinch you can pound a piece of 1/8th copper tubing flat.
Ashford Hobby
Real time inventory for the things you need.
rpoage is offline   Reply With Quote
Old 01-08-2007, 10:18 AM   #1061
Grenade10's Avatar
What's your thoughts on having Batteries Plus Spot weld using thier flat metal straps? This is almost non-existant in size, and still has some movement if needed? This is the same type of connections used in cell phone and other cordless devices.
Old 01-08-2007, 05:35 PM   #1062
fraz's Avatar
Good point Robert. I also forgot to mention I built the pack with the old school 1/12 scale pack building technique... CA glue with fillets of baking soda so the pack is a solid unit. I have been running the same pack for over 2 years on the same car and have only once had to clean it up thoroughly, reshrink and add a new plug once and it is in great shape with no runaways. Heck I even ran a back to back B and A main at Toys for Tots the year before last and it was like 90 minutes straight with 2 KO high torque digitals, no problem. If you have the cells floating around inside shrink and not glued to each other, I wouldn't use anything but wire.
If ya want to talk risky... I'm considering LiPo! <LOL>
Old 01-08-2007, 09:52 PM   #1063
Sirio2127's Avatar
Send a message via MSN to Sirio2127
Hello Aaron, I tryed some things on the test day i had at the track i ended up with kyosho light blue springs on the car and a tiny bit of front bar and it gave the car much more stability all round i ran 2.5deg camber 3deg toe on the rear and the out side bulkhead hole. Ive now gone to the inside hole at the rear bulkhead and will up the camber to 3deg and see if the car keeps inproving. The car befor the changes just seem to become unsettaled under braking and corner entry but its got a lot better just from that small spring change. Ill let you know what i end up with by the end of our first race meet. Thanks agen and Best Regards jeremy. Ps also about battery i use 1000mah nimh 3a pack's i made I only use them because of the big weight saving I can now run a heavy body 1mm dome and i am still under weight but at least i can place the weight were it can be used to my advantage. I just have 3 pack charged at all times one in the car i run the qualifers with it and then switch to a fresh for the 20 or 30min final. I find provinding you charge them slowly they last along time and you good run time from them befor they need recharging.
Sirio2127 is offline   Reply With Quote
Old 01-08-2007, 11:07 PM   #1064
Orfeous's Avatar
Send a message via ICQ to Orfeous Send a message via AIM to Orfeous Send a message via MSN to Orfeous Send a message via Yahoo to Orfeous
anyone got pictures of their evolvas? i have just seen an overview picture on kyoshos site.
i am just curious
Orfeous is offline   Reply With Quote
Old 01-09-2007, 02:05 AM   #1065
Sirio2127's Avatar
Here are some pic's of my chassis in a novarossi config. Regards Jeremy.
Kyosho Evolva-sany0010%7E1.jpg   Kyosho Evolva-sany0009%7E1.jpg   Kyosho Evolva-sany0008%7E1.jpg   Kyosho Evolva-sany0007%7E1.jpg   Kyosho Evolva-sany0006%7E1.jpg
Kyosho Evolva M3 tomkelley Nitro On-Road 1002 05-19-2015 08:49 AM
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
