Old 07-09-2005, 06:10 PM   #961
Default Nitrohead
I do the setup on Scott's car. We don't measure droop. We measure as Fraz points out:
"Droop or Up travel (what Empire team uses)==Car settled on flat board ready to race. Hold a metric ruler perpendicular to the flat board and slowly lift the chassis. Note the measurement from the settled ride height to the point where the tires lift off the board and this is your actual droop or up travel measurement." We measure 1.5 mm of up travel in the front. The rear measures 5mm of up travel (just to prevent shock damage). We run no stops - limiting the downward travel of the chasis - we allow the car to bottom out (which it never does)
Rich Browne is offline   Reply With Quote
Old 07-09-2005, 06:52 PM   #962
Awesome!
Im going to try that after I put my ER front sway bar mounts on...
[FONT="Arial Black"][SIZE="2"]team kyosho / empire racing / speedmerchant / ko propo / novarossiusa.com / phat skeems paint works / 301 raceway [/SIZE][/FONT]
NitroHead is offline   Reply With Quote
Old 07-09-2005, 07:30 PM   #963
Originally Posted by NitroHead
Awesome!
Nitrohead (Steve Perez, Chris Verano - you too) Fill out a set-up sheet. I'll post it on our site. The more folks who send in the "sheets" the larger choice of set-ups we'll all have. I think every one can gain from our mutual experiences.
We are testing "new" rear suspension hinge pin mounting blocks. They allow an even larger range of adjustment. They seem promising.
Old 07-10-2005, 06:39 PM   #964
Will do Rich...
Old 07-11-2005, 11:53 AM   #965
Default Additional set-ups posted
New set-ups and clutch info:
http://www.empirercracing.com/blog.html
Old 07-11-2005, 12:32 PM   #966
C Verano's Avatar
Sorry about the delay Rich...I'll get a set up sheet filled out soon.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 07-11-2005, 12:37 PM   #967
fraz's Avatar
Send a message via AIM to fraz
Hi Rich, thanks for the update.
You meant +1.2 front toe instead of -1.2, right?
What exactly do you mean by ".5mm bearing insert" for the front scrub set?
It would also be really cool to see Scott's comments on the setups too. Something like, "Yeah I was fast but the car needed more/less of _____".
fraz is offline   Reply With Quote
Old 07-11-2005, 02:41 PM   #968
anyone know when the 2005 evolva coming out? Or is it out already? Thx.
silverM3 is offline   Reply With Quote
Old 07-11-2005, 04:11 PM   #969
Default Scott's comment
The damn toe was 1.2 out - smile. Scrub set: instead of using the kit shims - I'm using the optional bearing shims. The bearings are moved out as opposed to using the kit shims to move the axle. I'll show you at the next race.
Scott was pleased with the car - during the main, he said "put the damn thing down - let me drive it...you can't fix it fast enough - I'm just gonna have to deal with it" His only comment besides "a little less wing please" It was fast until the driver side Universal broke (broke at the axle end)
Old 07-11-2005, 05:11 PM   #970
lol! Rich, your awesome! I know Scott must be very happy to have you wrenching for him... Anyway, I wanted to know if you know where I could get Empire rear sway bars and mounts from.
Old 07-11-2005, 05:13 PM   #971
Smile Thank You
Rich,
I would like to Thank You and your team for sharing your setups with all of us!!
MBlackketter is offline   Reply With Quote
Old 07-11-2005, 05:34 PM   #972
Default Rear Sway bar
Our "master of creation" Rick Davis - hasn't released his rear sway bar assembly. The parts we (Empire) run come, for the most part, from the mind and talents of Rick. Rick does the concepting - design and prototyping. I have the "production" items made. Our team does the testing. I don't know if we will ever make the rear sway assembly - it would be way too pricey.
Old 07-11-2005, 05:37 PM   #973
Default Hey Mark!
Originally Posted by MBlackketter
Rich,
We finally made (thanks Rick) and ran the suspension block you suggested - you were spot on - good call - way fast!
Old 07-11-2005, 07:46 PM   #974
Scott Kimbrow's Avatar
Nitrohead,
I am extremelly lucky to have Rich Browne and Rick Davis to develop and setup the car. They are invaluable and we would not be having the sucess es we are without all their hard work. I get the easy part..........THANKS Rich & Rick.
Scott Kimbrow is offline   Reply With Quote
Old 07-12-2005, 12:23 AM   #975
Roger's Avatar
Rich Browne is truly a master in his art. It shows on the track and in the pits that he is a perfectionist. And he also a good and helpful friend. I'l see you at the Rody race Browne.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Kyosho Evolva M3 tomkelley Nitro On-Road 1002 05-19-2015 08:49 AM
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
