Old 06-10-2005, 10:08 AM   #916
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by SRAD
Man this thread is slow.....there has to be more chatter out there on this car. Time to refresh my last post about anyone knowing when Kyosho plans to release the 2005 car in the US.
It comes out 6/17 in Japan. Not sure about the US but you can call Kyosho America (www.kyoshoamerica.com) and find out.
jeffreylin is offline   Reply With Quote
Old 06-10-2005, 10:09 AM   #917
P2gee's Avatar
Thumbs up
Originally Posted by speedy100
hey, can anyone tell how long you will rebuilt the car ? I found the front wish bone and one way cup weared significantly after a few gallon gone thru.
Lube your dog bones with moly-disulfide grease when you assemble and you won't have this problem. I have a small container of this stuff that I dip the dog bone ends up to the pins in and then assemble. I dis-assemble my car and clean/re-lube the axles like this after every race. My rear spool is showing some slight wear but I've been running the car for over a year now.
P2gee is offline   Reply With Quote
Old 06-10-2005, 11:28 AM   #918
The '05 Evolvas will be here sometime in July.
[FONT="Arial Black"][SIZE="2"]team kyosho / empire racing / speedmerchant / ko propo / novarossiusa.com / phat skeems paint works / 301 raceway [/SIZE][/FONT]
NitroHead is offline   Reply With Quote
Old 06-10-2005, 03:09 PM   #919
Winner's Circle's Avatar
Default fix for shocks and linkage popping off
Delta/Kyosho linkage and shock absorber popping-off fix
I love the car but HATE the shocks and linkage popping of in even the most minor of racing mishaps.
Here is what it takes to fix this once and for all!
1) I replaced the bottom shock snap on ball (located on the lower arm) with a Serpent 1650. I held these on with Serpent 1241 M3x12 allen head screws that I screwed in from the back side so that it extended through the arm. and I then cut it to the proper length.
2) I replaced the plastic end on the shock rod with Serpent 909403 rod ends.
3) I had to grind the shock spring retainer (just a little) so that the 909403 would fit into it.
4) Next I replaced the Delta linkage with Serpent 902128. I used Serpent 1241 M3x12 screws through the bottom of the steering block to secure the linkage on the outboard end of the linkage. The existing screw on the servo saver fits the Serpent 1650 ball.
Now I have to use a 3mm wrench to remove the lower shock. The ball stays inside the rod end. The ball is set-up so that a 3mm wrench fits it. The shock is much more secure and still easy to remove when I want to take it off.
Since I made this change I have not had the shocks or the linkage pop off. Prior to this modification I had them pop off a number of times each race day.
Here is the bill of materials to do this job
1650 Balls 6mm/ setscrews (4) = $7.75 ea package - 2 packages are required
909403 ball-joints 6mm short (4) = $3.00 - one package required
1241 screw RH allen M3x12 (10) = $8.50 - one package required
902128 track rod set = $10 - one package required
Contact me if you have questions about this repair.
Lee Muse
1-866-nitroRC
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 06-12-2005, 07:47 AM   #920
hi guys any help on what engine i should get for my evolva
gozoracer is offline   Reply With Quote
Old 06-22-2005, 12:10 PM   #921
Default Exhaust Hole or Flap?
Do you cut a hole or flap in the side of your body for the exhaust
to outlet? I have been getting a lot of crud inside my bodies lately,
and I'm trying to cut down the mess.
r1sportbike is offline   Reply With Quote
Old 06-22-2005, 01:04 PM   #922
flap...
use body stiffeners
Old 06-22-2005, 04:39 PM   #923
Default Small flap
See image, racey stuff - stiffner, no flap
Rich Browne is offline   Reply With Quote
Old 06-22-2005, 06:17 PM   #924
I just cut the flap!
Old 06-24-2005, 07:14 PM   #925
Perez's Avatar
lets see some personal setups!!!
Perez is offline   Reply With Quote
Old 06-26-2005, 01:26 AM   #926
kidDynomite's Avatar
Default PBs
Does anyone know the part # for the black pillowballs?
kidDynomite is offline   Reply With Quote
Old 06-26-2005, 06:33 PM   #927
Default Pillow Balls
FM 337 if I understand correctly. Those are the large ball ends used with the hub carriers.
Old 06-27-2005, 12:15 AM   #928
hey all,
wow talk about some frustrations today. I thought the car was going pretty quick when i qualified 4th in open at RAMS after running the car 3 times untill the main. the car was running and handleing really good, just down on power! Im running an OS Version 2 and it just wouldnt keep up. so while trying to run faster then was possible a board came out of nowhere and pulled my dog bone out lol.
what engines are you all using? i had my eye on an RB MODS Nova 321p
but man this 8th scale stuff kicks butt!
nitrolover is offline   Reply With Quote
Old 06-27-2005, 12:42 AM   #929
suntok2's Avatar
Send a message via ICQ to suntok2 Send a message via AIM to suntok2 Send a message via Yahoo to suntok2
Originally Posted by nitrolover
hey all,
Try the latest Novarossi engine plus 21-3
suntok2 is offline   Reply With Quote
Old 06-27-2005, 06:31 AM   #930
Yes it is! Thanks a lot, Rich!
Kyosho Evolva M3 tomkelley Nitro On-Road 1002 05-19-2015 08:49 AM
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
