Old 04-28-2005, 02:19 PM   #886
How or where did you get this figure from? How long do tires last?
The tires can be found at the following;
brucknerhobbies.com Jaco 1.8th scale tires 29.99 per set of four
brooklynhobbies.com ForFaster Tires 29.99 ' '
twistertires.com Twister Tires 29.99 " '
Tire wear depends on surface conditions, what you true them down too, etc...
[FONT="Arial Black"][SIZE="2"]team kyosho / empire racing / speedmerchant / ko propo / novarossiusa.com / phat skeems paint works / 301 raceway [/SIZE][/FONT]
NitroHead is offline   Reply With Quote
Old 04-29-2005, 04:32 PM   #887
can someone tell me were i can buy some belts for my evolva i been looking i cant seam to find
gozoracer is offline   Reply With Quote
Old 04-29-2005, 09:26 PM   #888
Super Moderator
Snowy's Avatar
Trader Rating: 14 (100%+)
Ace Hobbies sell them. They also sell the Belts from Empire Racing which are even better than the stock belts.
Snowy is offline   Reply With Quote
Old 04-29-2005, 09:32 PM   #889
Super Moderator
Snowy's Avatar
Originally posted by tomkelley
Looks like us 2003 evolva/delta xp4 owners really don't need to do too much modification if we want to upgrade to the 05 spec when it comes available. Plus the empire belt tensioner already does the belt tension adjustment.
I'm pleased Kyosho chose to make only subtle changes to it. I guess they thought why change something that works good? As far as I reckon its only a few things:
-pulleys, differnet internal ratio, higher or lower?
-new front bulkhead and arms- for wheelbase and 8 stage belt tension adjustment
-new tank lid- (I never knew there was anything wrong with it)
-new longer break lever.
Thats makes it really not much worth to buy a whole new kit, but might make for a few worthy extra hop ups in the future.
I hope this is the case. Although, I've noticed that the front upper & lower Arms look different than the Evolva 2003 in regards to the cross bracing in between the arms. Hope that makes sense.
I wonder if they have changed the geometry of the front arms...
Old 04-29-2005, 09:35 PM   #890
thanks Snowy
i called them today they said they dont have nothing sometime next week they are to get something from japan
Old 04-29-2005, 10:03 PM   #891
thanks Snowy
Old 04-29-2005, 10:09 PM   #892
Default Belts
Contact Speedline - Mike Queller. I'm sure he has Bando - Urethane Kevlar Side and Rear belts for the Evolva. Ask him what type of front belts he has in stock.
Rich Browne is offline   Reply With Quote
Old 04-30-2005, 07:42 AM   #893
Hello Mr Browne,
I was wondering if you know when or if Bando will make the front belt for the Evolva?
Old 04-30-2005, 08:16 AM   #894
Default Belts
That's the jackpot question. Bando Japan has informed us they do not have a mold for the 207 tooth belt (Bando US said they did have a mold and they made the UK belts). So, no Bando U/K front belt. Unfortunate but true. The other issue is the 14 week lead time, from Japan, for the Rear and Side belts. We (Empire) are testing other UK belts - the first two tests were, shall we say, sad. We're not giving up. As the Evolva grows in popularity the need for durable belts will increase. The 2005 will be an improvement, but, we feel, the eccentric solution will help in keeping the belts tight (stop breaking) - but - that won't stop the stripping problem (caused by hard contact or a bumpy track).
Old 04-30-2005, 08:33 AM   #895
Thanks Rich,
Keep working at it, Im sure you guys will come up with a solution.
Old 05-02-2005, 08:10 AM   #896
uaerc's Avatar
Default Need Help n Advice....
Hi Guys.....
I am already a proud owner of a fw05rr and V one RRR..... now we have a sort of a drag race amongst a group of friends who use their carss for dragss......these are 1/8th scale.... 950's ... Evolva's --- Fantoms ....... etc...
Now for me to kick [email protected]@ there... I would definately need a fast car.........all the above are suspected Stock cars...no modds...
I would want to buy a EVOLVA. ... attach a damn good fast engine on it. Play with the gear ratio....... belts ? to make it more faster than those guys.....
In order to do this....i need all the help i can get....
Please let me know what engines and what moods i need to do..... and yeah what pipe..... and servos......
regards
ZiiZO
uaerc is offline   Reply With Quote
Old 05-06-2005, 08:51 PM   #897
dougday's Avatar
The new belts from Delta seem to work fine. Call Dave Campbell at Delta. His numbers can be found on his website at http://www.deltainc-usa.com/
Has anybody run the 2005 yet or used any of the new parts?
dougday is offline   Reply With Quote
Old 05-06-2005, 09:19 PM   #898
Hey Doug, can I drive your Evolva @ the nationals?
viperrj is offline   Reply With Quote
Old 05-07-2005, 10:12 AM   #899
dougday's Avatar
Sure.
If you break it you bought it.
One tank of fuel will cost you a set of tires.
Old 05-11-2005, 01:27 PM   #900
Perez's Avatar
Has anyone tried the option rear alum suspension holder?
Perez is offline   Reply With Quote
Kyosho Evolva M3 tomkelley Nitro On-Road 1002 05-19-2015 08:49 AM
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
