Old 09-03-2004, 06:07 PM   #556
Default Re: Front belt problems?
Originally posted by my2cents
So even the Evolva is not immune to the front belt/small 16 pulley problem? Too much power on these 1/8 scale cars is revealing the weakness that may cause me to just go back to 1/10 scale sedans. It's more fun to be running than fixing belt problems in the pits. What's worse is you know you'll be breaking it again and again.
manokgt4 is offline   Reply With Quote
Old 09-03-2004, 06:20 PM   #557
C Verano's Avatar
I've actually only had problems with the stock belt on really bumpy tracks. With the SP belts I get quite a few runs on them before they need replacing.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 09-04-2004, 07:10 PM   #558
dameetz's Avatar
manokkgt4: What is Takagi belt? It is meant for Evolva? Anyhow i managed to fit Serpent rear belt to my Evolva, but it needs some trimming down of width to fit the pulley. It didn't fit that well because its a bit long so i changed the front pulley to 17t. I tested it yesterday and so far it worked. Hopefully it can hold during the race today.
raceblast: Thanks for the link. I will try to order from them.
Thanks!
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 09-05-2004, 10:36 AM   #559
BIBOY's Avatar
Send a message via Yahoo to BIBOY
yes its for evolva its an optional belt which is a bit wider than the sp and the stock belt ... but its smoother than both of them ... and this belt will last longer too
R1 Wurks
Xray
RC America
Reds Racing Engines
Rctarget
BIBOY is offline   Reply With Quote
Old 09-07-2004, 08:46 AM   #560
dameetz's Avatar
OK, where can I get this Takagi belts? Is there site i can order from? Preferbly the one can do interntional order, I m from South East Asia btw. Also do they do side and rear belts too.
Old 09-07-2004, 08:55 AM   #561
dameetz's Avatar
Default steering ackerman
What steering ackerman are you guys using? I m using stock set up and using no12. If I need more steering during medium speed 180 turn which one should I use?
Has anyone use the optional brake disk and pad from Kyosho? How is the performance? During the race last weekend, I noticed that the Mugen guys here who use teflon pad, were braking more consistant.
Old 09-07-2004, 12:53 PM   #562
BIBOY's Avatar
yup they have it ... i have a friend who sells in ebay il ask him to post here in the thread if he has some belts for sale ...
R1 Wurks
Xray
RC America
Reds Racing Engines
Rctarget
Old 09-14-2004, 11:14 AM   #563
Has anyone had a problem with the evolva shocks whereby the small clip, that holds the 2 clear rings and single white washer at the bottom of the shock in place, just pops off when the shock is pressed?
Maybe its something Im doing wrong so I would appreciate if anyone else has had this problem.
Clubman is offline   Reply With Quote
Old 09-14-2004, 11:26 AM   #564
BIBOY's Avatar
yup happend to once but i found out that the gruv where the clip sinks in is to shallow so i just got a dental pick and made the gruv abit deeper it solved that problem and it never poped out again... good luck
R1 Wurks
Xray
RC America
Reds Racing Engines
Rctarget
Old 09-14-2004, 11:31 AM   #565
BIBOY,
Thanks for that. I was thinking that the groove didn't luck that deep at all. I'll give it a try,
Clubman
Old 09-14-2004, 11:43 AM   #566
BIBOY's Avatar
BIBOY,
Clubman
no prob ... good luck and have fun!!
R1 Wurks
Xray
RC America
Reds Racing Engines
Rctarget
Old 09-15-2004, 02:14 PM   #567
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Can someone give me the part numbers for the blue pivot ball retainers and those plastic cups that go between the pivot ball and retainer?
Thank You
Racing4Evo is offline   Reply With Quote
Old 09-15-2004, 02:59 PM   #568
Kurly's Avatar
Default Evolva parts
If your talking about the Ball screws, the parts your looking for are on the FM509 small parts set and FM338BL screw caps.
Kurly is offline   Reply With Quote
Old 09-15-2004, 03:09 PM   #569
Racing4Evo's Avatar
Thank you Kurly.
Where can I get the caps? I can't find them on Tower and I think Delta is out.
Old 09-17-2004, 08:20 PM   #570
Default damper leaks oil
Have u guys ever had problems with Evolva shock oil leak? I think the leak is at the bottom of the shocks, because the top caps are dry. I readjusted the shocks two weeks ago, and the car was put on a car stand so that the wheels were hanging free. While setting up the car today, I find that the shocks does not rebound much, and oil is everywhere. I never have this kind of oil leak with my NTC3 or Serpernt 835.
raceblast is offline   Reply With Quote
Kyosho Evolva M3 tomkelley Nitro On-Road 1002 05-19-2015 08:49 AM
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
