Old 07-26-2004, 12:11 AM   #511
BIBOY's Avatar
Send a message via Yahoo to BIBOY
Originally posted by Mr-V-One-S
L Think This Car Is Bit like A V-ONE-RR-EVO Just But its A Smaller Size L am right or not
the evolva is bigger its 1/8 scale and alot faster its more simillar the new EVO RRR...
R1 Wurks
Xray
RC America
Reds Racing Engines
Rctarget
BIBOY is offline   Reply With Quote
Old 08-12-2004, 10:01 PM   #512
hi jwf-ronni:
Have u finished making the charts of the spring rate of different springs yet?
raceblast is offline   Reply With Quote
Old 08-13-2004, 12:57 AM   #513
C Verano's Avatar
I think Ron is just waiting to get the rating on one other set of springs...I know at the Nationals he was almost done.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 08-13-2004, 06:07 PM   #514
I tried to compare the spring rates myself by compressing two springs together. Man, it is sometimes hard to tell which spring is harder as both springs seem to compress at the same time.
Old 08-16-2004, 05:38 AM   #515
subject: 2 speed one way
How is the proper maintainence procedure for the 2 speed one way? Do you use brake cleaner to clean it and lube it with one way oil after every race?
Old 08-16-2004, 05:57 AM   #516
Default rear ball end
The rear track width of my evolva is set to 262mm, rear toe in 1.5, but 1 degree camber. The rear ball end protrudes out of the rear upper arm for 3.5mm. When the rear wheel hits the board, the ball end comes loose from the camber adjustment screw or cracks.
Perhaps, the ball end protrudes less with 2 degree camber. But I really think Kyosho needs to address this weak ball end problem. When the ball end needs to be replaced, the upper arm must be taken off to unscrew the adjustable rod. One loses so much precious time during the race for that.
It is very time consuming to adjust the front toe and rear camber with the hole in the adjustable rod. The hole in the steering turnbuckle is blocked by the suspension arms, it is troublesome to put an allen key there and turn. When I put the L shape allen key in the hole to adjust the rear camber, the movement of the allen key often is restricted by the shocks.
It'd be nice that the rear camber could be adjusted by turning screw from the side of the car(like a pivot ball design), or use a conventional nut shape adjustable turnbuckle
Old 08-16-2004, 09:24 AM   #517
C Verano's Avatar
I clean the one-way out with denatured alcohol and then put a drop of Serpent one-way oil on it.
Old 08-23-2004, 12:44 AM   #518
Default Ceramic Bearings
Can somebody point me where we can get complete set of ceramic bearings for this car.
Also, complete set of titanium screws would be nice too.
Thanks in advance,
Edwin
manokgt4 is offline   Reply With Quote
Old 08-23-2004, 07:21 AM   #519
kidDynomite's Avatar
Default Re: Ceramic Bearings
Thanks in advance,
Edwin
Edwin, Check these guys out. They have various spec degrees for their ceramic bearings. Also designed for different budgets.
http://www.bocabearings.com/default.aspx
If they don't have the a kit for your ride, they'll make one up for you.
kidDynomite is offline   Reply With Quote
Old 08-23-2004, 08:10 AM   #520
dameetz's Avatar
Default Engine
Hi everyone! I just got myself this car (Evolva) today. I will start to putting it together tomorrow. Any assembling tips before I get started? Anyhow I m going to buy a new engine for this car. So can you advice me which one is the best/fastest non modded engine for this car.
Thanks!
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 08-23-2004, 09:23 AM   #521
Default Re: Re: Ceramic Bearings
Thanks.
Old 08-23-2004, 09:24 AM   #522
Default Re: Engine
Originally posted by dameetz
I will Anyhow I m going to buy a new engine for this car. So can you advice me which one is the best/fastest non modded engine for this car.
Thanks!
Rex 321P
Old 08-24-2004, 04:48 AM   #523
dameetz's Avatar
Default Re: Re: Engine
Rex 321P
How about Sirio 21 PR PRO AAC? Its the best deal I can get here in my country, and it comes with the Sirio pipe package too.
Old 08-24-2004, 04:57 AM   #524
Send a message via Yahoo to speedy100
Default Re: Re: Re: Engine
siro is junk...........better to get nova rossi or nova rossi base modified engine like MAX, JP, RB......the best nova engine you can trust.......
speedy100 is offline   Reply With Quote
Old 08-24-2004, 06:01 AM   #525
Hi Speedy100,
Have you ever seen junk winning the worlds
I'll bet you find it junk because you get beaten by Sirio powerd cars all the time
Have fun
840918001 is offline   Reply With Quote
Kyosho Evolva M3 tomkelley Nitro On-Road 1002 05-19-2015 08:49 AM
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
