Old 06-29-2004, 04:28 PM   #466
BIBOY's Avatar
Send a message via Yahoo to BIBOY
Cool Re: Re: this car is wonderfull!!!
Originally posted by C Verano
Give it some time. You have to get used to the car. I'm sure you'll do better after a couple more races.
THANKS Chris!! i just have to really get used it and try to drive smooth
R1 Wurks
Xray
RC America
Reds Racing Engines
Rctarget
BIBOY is offline   Reply With Quote
Old 07-14-2004, 05:48 PM   #467
BIBOY's Avatar
Default hi guys
i made an avatar for evolva lovers here is one more for you all
R1 Wurks
Xray
RC America
Reds Racing Engines
Rctarget
Old 07-14-2004, 06:19 PM   #468
Default setting the clutch
I had a hard time assembling the Evolva clutch. Does anyone set the clutch shim space to be anything larger than 0.5mm? What lubrication do you use on the thrust bearing? I am using dry graphite grease. I am using the V one RR clutch shoe since the stock shoe is not sold separately here.
The problem with my clutch is that, the thrust bearing was totally damaged when I set the space less than 0.5mm.
If I set it around 0.7mm, the car does not have the speed even in first gear.
Please help.
raceblast is offline   Reply With Quote
Old 07-14-2004, 06:40 PM   #469
whynot's Avatar
Trader Rating: 18 (100%+)
Go to http://www.cefx.net/ and then go to the setups and look for clutch setups.
mike
whynot is offline   Reply With Quote
Old 07-14-2004, 06:45 PM   #470
rjl
rjl's Avatar
Default Re: setting the clutch
Please help.
Set the clutch as per the instructions. That is with .4mm float, then shim out the inner bearing till the bell rotates freely but has very little in out movement. Use lube on the thrust bearing, graphite is good for belts and pulleys.
rjl is offline   Reply With Quote
Old 07-14-2004, 07:29 PM   #471
What kind of lube?
Old 07-14-2004, 08:20 PM   #472
BIBOY's Avatar
Please help.
HI! there are a couple of lubricants you can use. you can buy the mugen grease. or if your near a pep boys or any automotive supply try the white lithium grease that will be much cheaper and man thats going to last you long time that you wont be able to finish.
There is also the molydenum grease which is alot better but a little more expensive and is not much as the lithium in quantity... both of them work great...they just vary in temp holding...
About the shims on the clutch i have found that the stock shims is not really enough and have changed them with a much thicker to get rid of the play as for the the space mine is set at 1.0mm more or less depends on the track with this much my car does not bog down on slow corners... have fun and good luck!!!
R1 Wurks
Xray
RC America
Reds Racing Engines
Rctarget
Old 07-14-2004, 09:37 PM   #473
I am going to buy shock springs for the Evolva. Currently, I am using the stock black springs. I need a variety of springs to adjust the car's handling. Does Mugen spring fit the Evolva shock? Is it better to buy the Kyosho front 3.5 gold, 4.5 silver, rear 5.0 gold, rear 4.5-1.9 copper springs? I don't quite understand the relationship between the numbers and the hardness of the springs.
Old 07-14-2004, 09:48 PM   #474
whynot's Avatar
I heard that the mugen pinks,reds and whites are a must have for the Evolva.I think cyrul uses these on his
Old 07-15-2004, 01:40 AM   #475
Default Springs
I am currently running mugen white (front) and red or pink(rear). It works well for me. If you want to stick with kyosho springs, Tower sells the optional springs like yellow,pink,blue, light blue.. etc.. check it out.
manokgt4 is offline   Reply With Quote
Old 07-15-2004, 02:00 AM   #476
jasoncsc's Avatar
I ran Mugen white on the front, original black on the rear. This gives me a bit more steering I feel.
jasoncsc is offline   Reply With Quote
Old 07-15-2004, 09:08 AM   #477
Do you have the part no. of the Mugen springs (white, red and pink)?
Old 07-15-2004, 12:11 PM   #478
BIBOY's Avatar
you'll find it here http://www.mugenseiki.com/menueefi.htm good luck!! have fun
R1 Wurks
Xray
RC America
Reds Racing Engines
Rctarget
Old 07-15-2004, 12:19 PM   #479
C Verano's Avatar
I think people may run Mugen springs because it easier to keep track of. Kyosho makes about 20 different pairs of springs. Some are the same color but a different shade.The Kyosho springs definitely work well, but you just need to spend a lot of time at the track trying them.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 07-15-2004, 05:53 PM   #480
I don't understand why Kyosho makes over 20 different springs for one car!!! I can't really tell which one is softer than which. Do the Mugen springs fit the Evolva stock shock, or I need to use the Mugen shocks with the springs? Does the Mugen spring set give enough handling adjustability?
Alan
Kyosho Evolva M3 tomkelley Nitro On-Road 1002 05-19-2015 08:49 AM
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
