Kyosho Evolva
Old 06-21-2004, 11:05 PM
  #451
sikgraffx's Avatar
Originally posted by jwf-ronni
Hi Bill,
Yes he is..
And he was at Rev last Saturday setting his Evolva for the
O'Donnel Race.
OH NO!!!!!!! Good luck to you too Ron. I got your shock tower, I'm going to try to make it to the track tomorrow for some run time hopefully.
sikgraffx is offline
Old 06-22-2004, 12:03 AM
  #452
Default ceramic bearing
does the ceramic bearing improve the rev and performance of the engine ? I know they are very expensive particularly the big bearing to hold the crankshaft in place internally of the engine...anyone who has tried ?
speedy100 is offline
Old 06-22-2004, 12:11 AM
  #453
MrChan's Avatar
Default Re: ceramic bearing
I feel no diff for me .... but it suppose to be better performance. but I couldn't feel a difference.
MrChan is offline
Old 06-22-2004, 08:16 AM
  #454
Ron C.'s Avatar
Hi speedy100,
I actually found that it revs up quicker having the Ceramics
in the motor. And because of that, it gave out a more responsive
power output. I find it worth having them in the motor.
We did find out though, that there are "good ceramic balls" and
the "not so good ones". I suggest knowing the source you are
getting your bearings from. Because in as much as I was very
satisfied with having them in the motor, I have seen some
Ceramic Bearings where the balls broke down and therefore
that was the end of that motor. And it only takes one of the balls
to do a devastating thing like that.
Ron C. is offline
Old 06-22-2004, 10:12 AM
  #455
Default Re: Re: ceramic bearing
Hi speedy100,
Hi Ron,
many thanks for your comment. the only available source here is Squat from a japanese rc work shop. they do a lot ceramic bearing and the engine bearing but i do not know whether they are good or not. Where your source from to get the bearing ? the one i get from squat should be around $80 us, the one to hold the crank shaft inside the crankcase.
if my understanding is correct, the KMH EVO5 also comes with the ceramic bearing in the box.....thanks
Old 06-22-2004, 10:46 AM
  #456
Ron C.'s Avatar
Default Re: Re: Re: ceramic bearing
Hi Ron,
Hi Chris,
At first, we get the Ceramics from JP Racing.. We have never had
a bad one from them...
Nowadays, we have a source from Colorado here in the
U.S.... It's a guy who imports the Ceramic Balls. Then he goes
thru a very tedious process of testing each one (with some kind
of a tool) and hand picks each ball to segregate the quality of
each one of them. From there he puts together a good Ceramic
Bearing.
I guess, the main thing is to have some kind of relationship or
experience with the source to ensure that it is trusted. Maybe
referrals from good friends who have used that source before
would be a good start. I would guess that if Squat does a lot of
Ceramics over at your area and a number of your R/C buddies
have used them with good results, then (with a good referral),
I would get from them too. I would not feel comfortable just
buying something like this online or from a walk-in store because
as mentioned, it only takes one ball to end the life of a good and
expensive motor.
Yes, I do believe the KHM Motors have ceramics fitted in them. Dont
have info on their performance though. If someone has used them,
please share your experience with us.
Ron C. is offline
Old 06-23-2004, 02:12 AM
  #457
jasoncsc's Avatar
Default KHM performance
I personally don't have a KHM, but one of my friends has one KHM Evo5. Its is so fast that amongst our A-Main guys even they all have the fastest engines available they feel that the KHM is even faster than their engines. However, the downside of that engine is that it gobbles fuel like crazy, so my friend said in the race the advantage of the speed of the KHM is badly handicapped because he need to pit in more frequently than others for fuel. He even changed the fuel nipple on the carb to 0.7mm (From the origianl 0.9mm) and fuel consumption just improve a little bit.
In addition, the KHM only have ceramic bearing on the big crankshaft bearing, not the small one, and the KHM ceramic bearing does not comes with full ceramic balls but a hybrid with 6 ceramic balls and 3 steel ones.
jasoncsc is offline
Old 06-23-2004, 02:18 AM
  #458
MrChan's Avatar
Default Re: KHM performance
I saw one of my friend who had KHM and run in the A Main ..The engine is extremely fast but fuel consumption not that good.
MrChan is offline
Old 06-23-2004, 08:52 AM
  #459
Ron C.'s Avatar
Hi Jason and Mr. Chan,
Thanks for the info.
I wonder how the internals of that motor looks like.
I would guess that they modified the heck on those motors which
is why they consume a lot of fuel, though fast.
Ron C. is offline
Old 06-24-2004, 09:13 AM
  #460
Ron C.'s Avatar
Default Ralph Burch driving KYOSHO Evolva
Just in case you guys have not heard :
http://babelfish.altavista.com/babel...4.htm&lp=el_en
Ron C. is offline
Old 06-24-2004, 03:50 PM
  #461
BIBOY's Avatar
Default Re: Ralph Burch driving KYOSHO Evolva
great!! his a good driver ... hey Ron are gonna be at the track today? or tom
BIBOY is offline
Old 06-25-2004, 01:54 AM
  #462
BIBOY's Avatar
hey guys
is there a gearing calculator for the evolva?
BIBOY is offline
Old 06-27-2004, 03:46 PM
  #463
For those who don't know, Josh Cyrul has recently posted his setup from the Las Vegas race a couple months back on his website. Its in the setups/tips area. As we go to races there will be more setups on there so keep an eye out.
www.CEFX.net
Bobby Flack is offline
Old 06-28-2004, 12:29 PM
  #464
BIBOY's Avatar
Thumbs up this car is wonderfull!!!
it was my first time out with this car and its was also my first big race at the O-donnel championship and luckily i got third in novice A main .. im not a great driver, but the car really gave an excellent performance... i was really surprised this car handled really well... maybe more practice will give a better result. I have to learn how to tame this fierce beast...
BIBOY is offline
Old 06-28-2004, 01:21 PM
  #465
C Verano's Avatar
Default Re: this car is wonderfull!!!
Give it some time. You have to get used to the car. I'm sure you'll do better after a couple more races.
C Verano is offline
