Old 06-10-2004, 11:28 AM   #391
dougday's Avatar
Originally posted by jwf-ronni
Ohh I see... I would bet that he is faster.... For a time, I know he
has been struggling with the other car.
Maybe I should give Terry a call and try to convince him to make
the switch to the Kyosho Car.... I know Brett has done that
already and so did Kevin on his sedan.
And I would bet even further that he will be much FASTER with
the Evolva...
Give him a call. I also think he would be faster with the Evolva
dougday is offline   Reply With Quote
Old 06-11-2004, 07:49 AM   #392
Default My broken evolva
Here are pics of my Evolva. You can see the second 45T spur gear is stripped. The plastic at the rear upper suspension that holds the rear pivot ball is broken.
Alan
raceblast is offline   Reply With Quote
Old 06-11-2004, 07:50 AM   #393
Default broken evolva more pics
more pics
Old 06-11-2004, 07:56 AM   #394
more pics
Old 06-11-2004, 10:20 AM   #395
Send a message via Yahoo to TambokGT
where can I get receiver batts for the Evolva....preferably NiMH not less than 1000mah .
TambokGT is offline   Reply With Quote
Old 06-11-2004, 10:59 AM   #396
BIBOY's Avatar
Send a message via Yahoo to BIBOY
I am actually getting the evolva and i was also thinking of what battery to put in. I want a bettery that would give great power and also longer run time... Anyway i did some research and found the new lithium polymer batteries are are pretty good the only thing is that they come in different sizes and voltage and they also require a different charger... but this battery will last longer and give you sufficient run time without charging it during race day... these batteries are normally used on rc planes and helicopters... as you know these RC's require high voltage and longer run times ... the lithium poly mer has7.2v, 8.4v, 11v or more on them so you might use a micro volt regulator if you go higher voltage ... by using this you actually extend the run time better... oh did i mention its three times lighter than the normal AAA or AA battery we use!!! good luck! hope this helped you!!!
R1 Wurks
Xray
RC America
Reds Racing Engines
Rctarget
BIBOY is offline   Reply With Quote
Old 06-11-2004, 11:48 AM   #397
fraz's Avatar
Send a message via AIM to fraz
Many folks (inc. Cyrul) are just building their own receiver packs with AA batteries. Just go down to a big electronics store like Fry's Electronics and get some 2400mAH AA batteries and be done with it. If you start getting into LiPo you have excessive voltage issues and there are some stability (read:explosion) issues as well.
fraz is offline   Reply With Quote
Old 06-11-2004, 12:05 PM   #398
I suck in electronics...I would rather buy than make it myself. I would end up spending more if I'm gonna make it myself.
Old 06-11-2004, 12:07 PM   #399
thanks Biboy....Ron already helped me.
BTW those cells are super duper expensive....I would stick on the NiMh and maybe get one of those thing later.
Old 06-11-2004, 12:08 PM   #400
BIBOY's Avatar
ITS onlt $30 but the charger is $29...
R1 Wurks
Xray
RC America
Reds Racing Engines
Rctarget
Old 06-11-2004, 12:13 PM   #401
hmmmmm.......$30 to get 6V? picture? website?
Old 06-11-2004, 12:18 PM   #402
dougday's Avatar
I had Batteries Plus make up a 5pk AA with 2100MaH (cost about $15.00). It is a tight fit and heavy, but the car needs the additional weight as it is so light .
Now I can run all day without recharging.
Old 06-11-2004, 12:21 PM   #403
BIBOY's Avatar
Post RE: battery
http://www.thunderpower-batteries.com/ this the web site check out.... oh i think you fit a 3cell in the evolva bec it uses the AA betteries...
R1 Wurks
Xray
RC America
Reds Racing Engines
Rctarget
Old 06-11-2004, 12:35 PM   #404
Data's Avatar
Default Re: RE: battery
thanks for the link. do you know anyone who had tried it ? wanted to use this kind of batteries for a long time by the safety issue and the discharge rate issue keep holding me back.
Data is offline   Reply With Quote
Old 06-11-2004, 01:14 PM   #405
BIBOY's Avatar
Post
ive been using it on my heli rc and on my 710.. its pretty good
R1 Wurks
Xray
RC America
Reds Racing Engines
Rctarget
Kyosho Evolva M3 tomkelley Nitro On-Road 1002 05-19-2015 08:49 AM
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
