Old 07-03-2008, 11:21 AM   #1711
Hello guys,
im new here, and i hope im in the right section....
Well, i have the new Kyosho Evolva M3, and I i was hoping if you can tell me the right way to build the shock absorbers to work (oil filling etc). is there any "rule of thumb"?
What about the shock springs? i was searching for a rate chart regarding the kyosho springs but no luck; any one knows about the rate and color of the springs?
Thanks, guys
neanto7 is offline   Reply With Quote
Old 07-03-2008, 11:35 AM   #1712
Originally Posted by neanto7 View Post
Hello guys,
Thanks, guys
Actually there is an M3 thread wandering around here somewhere but your questions are applicable to both. The way I build my shocks is put my finger over the small end and fill 1/3 to 1/2 way, insert piston and rod assembly all the way to bottom , use vacuum chamber (or time) to get out bubbles, move piston up about 1/3 , drop in bladder and use a tool to gently seat, add the plastic shock end and put the cap on and screw down snugly - fingers only no pliers.
Springs - the whites in the kit are in the middle, silver softer, black harder.
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - IGT8 2017
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 07-03-2008, 01:35 PM   #1713
YBSLOW's Avatar
Originally Posted by rpoage View Post
The 2-speed shaft is the same as the Evolva FM515, The mid shaft is also the same (FM514) I'm told we will get some new ti shafts from Delta Mfg. any day now. Delta Dave are you listening? Maybe YBslow will work on this also? Brad?
Ashford Hobby Delta Mfg.
I should get new Empire Racing M3 items early next week. I'll try to get pictures and get them posted on site as soon as I can.
Ashford Hobby Empire
Funny you should ask. We have the M3 midshaft in stock and it is made from 7075 and weighs about 3 grams. Currently making some titanium 2speed shafts that weigh about 10 grams and should be available later next week.
Brad
YBSLOW Racing
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 07-04-2008, 04:55 PM   #1714
Thanks Davis for the help
Old 07-21-2008, 11:21 AM   #1715
tomkelley's Avatar
I've put the evolva 2005 rear bulkhead on my delta xp4. I'm having problems with the belt riding off the gear. So My question is what tension setting (per the manual) should you start with on belt tension? I understand there's both r and l bearing tensioners, and 4 different slots. I put the R on the R bulk and the L on the L bulk and the second from the front slot.
Detroit Radio Control Car Club
www.drccc.org
tomkelley is offline   Reply With Quote
Old 07-21-2008, 01:54 PM   #1716
Tom - depending on the belt and pulley wear sometime you even have to use the LH cam in the RH bulkhead and visa-versa, never have had any issues with belts riding off, do you have the flanges opposing each other?? - typically the belt tends to nestle against the spool pulley flange, left side of car.
Old 07-21-2008, 02:02 PM   #1717
tomkelley's Avatar
I studied some drawings just recently and I noticed that i put the rear pully on backwards (was working late last night). When setting the tension, what typically do you set it at when installing a fresh belt?
www.drccc.org
Old 07-21-2008, 02:38 PM   #1718
Tom - there is no typical in my world - belts have varied from batch to batch and from std to SP, just start with the rh cam in the rh bulkhead and one of the middle two positions and make judgement calls from there.
Old 07-21-2008, 03:53 PM   #1719
Tom - there is no typical in my world - ....
Well, that I have to agree with....
Rich Browne is offline   Reply With Quote
Old 09-10-2008, 01:08 PM   #1720
pipcars's Avatar
Hi I'm new to 1/8th on road and have just got a Evolva 2005 with an 2007 uprade pack to fit, Anyone still running this model? or have you all got the M3 now?
Cheers Paul.
pipcars is offline   Reply With Quote
Old 09-10-2008, 04:02 PM   #1721
tomkelley's Avatar
From what I hear the suspension geometry is the same between the M3 and evolva 05 , its just that you couldn't interchange parts between them.
i almsot forgot about the 07, isn't that basically the 05WC editition?
Heck, my Delta XP4 is the same as a 03 spec evolva with 05 bulkheads and I'm still driving it.
www.drccc.org
Old 09-10-2008, 04:22 PM   #1722
Belts changing from batch to batch is right! My experience of the last 4 to 5 weeks proved that, and also it sort of pointed out I should refer to the assembly instructions a little more often than I usually do.LOL!
Is Quebec leaving any time soon?
fossil is offline   Reply With Quote
Old 09-19-2008, 10:17 AM   #1723
nitrodude's Avatar
http://www.rctech.net/forum/r-c-item...picco-p9r.html
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 10-01-2008, 11:23 AM   #1724
IQ0
IQ0's Avatar
Default evolva 2007
hi there...I have evolva 2007,...anyone can tell me what effects we get when we change the position of the side linkages that attached to the rear body mount? for info, 07' rear body mount has 3 holes (inner/mid/outer) on each side.
IQ0 is offline   Reply With Quote
Old 10-03-2008, 11:24 AM   #1725
<PsOp>
Guest
Posts: n/a
Hi, can someone give me a link to a good starting setup thanks.
Kyosho Evolva M3 tomkelley Nitro On-Road 1002 05-19-2015 08:49 AM
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
