Old 04-21-2008, 08:54 AM   #1696
rpoage's Avatar
Originally Posted by cdelong View Post
Robert.... anyone make a rear axle for the Evolva yet that's worth at least 2 or three races without getting torched
M3 changes the rear axle to a FM617 so I suspect if Empire Racing does make any heat treated axles they will be FM617's. Rear CVD do reduce the issue by not letting the dog bones seek the lowest area on the axle.
rpoage is offline   Reply With Quote
Old 04-23-2008, 10:56 AM   #1697
Green Machine!'s Avatar
Send a message via MSN to Green Machine!
I have a question. I just finished with my 07 Evolva. I also run a RRR. I run the RRR with the optional middle pulley to run a 2mm split on the front tires. On the Evolva it only has the 26t middle pulley, right? I did not see an option. Do I run a split, and if so what is the split. I herd its 7mm. Is that correct? I am going to cut some of my first tires this weekend and I don't want to mess them up. Also, what shores are most popular. Most people I know are running 35 front and rear I think. Thanks for the help. Also. I have the front belt tensioner from Empire Racing, so should I run the front belt loose (tabs twords the front of the car) or tight, the way I do the RRR?
Thanks for the help!
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Green Machine! is offline   Reply With Quote
Old 04-23-2008, 11:38 AM   #1698
There are options included in kits for all of the front pulleys, my advice is stick with the 26th, the 16th and the 24th and play with overdrive by varying your split from 7mm to 6mm (more overdrive), when using the Empire front tensioner leave the bulkhead settings a tiny bit on the loose side and use the slack in conjuction with the tensioner to gain an extra tooths worth of engagement on the 16th pulley.
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - IGT8 2017
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 04-23-2008, 11:46 AM   #1699
Thanks. That was perfect. (And quick) I thought the front belt seemed a little tight. I appreciate all the help.
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Old 04-30-2008, 04:52 AM   #1700
Default Clutch Info Pls
Hi Guys
I am not sure if someone asked this already - but I need to know if the Serpent clutch shoes will work on the 3D clutch for the Evolva? Also, is there any other parts that can easily be interchanged between Serpent and Evolva?
Acid
Acid is offline   Reply With Quote
Old 06-10-2008, 12:05 AM   #1701
bsmooth's Avatar
Trader Rating: 17 (100%+)
HAs anyone experienced the servo saver brushing the underside of the front belt (when turning left). Other cars i've seen have a lot more clearance than mine. I've disassembled everything and can't figure out why the arm that the tie rods connect to is so much higher!!!
Thanks for any insight.
-Steve
bsmooth is offline   Reply With Quote
Old 06-10-2008, 06:46 AM   #1702
-Steve
Actually the M3 servo saver output is lower than the old car, by any chance your not trying to use one of the old Shimo units are you??
Old 06-10-2008, 09:25 AM   #1703
bsmooth's Avatar
No, it's all from the 05 kit parts. I'm running the Empire belt tensioner, but it doesn't look like that has anything to do with it.
-Steve
Old 06-10-2008, 05:29 PM   #1704
occ
Trader Rating: 15 (100%+)
-Steve
I have had this problem with both the standard plastic & option shimo version servo saver. I had to file them down but they still lightly touched the belt but I didn't seem to effect the belts life.
You running the standard tie rods & ball cups? Did you try it without the empire belt tensioner?
occ is offline   Reply With Quote
Old 06-10-2008, 06:17 PM   #1705
bsmooth's Avatar
I haven't tried it without the empire tensioner yet. I'm using lunsford ti- tie rods and captured ball ends. From what I see those aren't the problem though.
Your suggestions are greatly appreciated.
-Steve
Old 06-10-2008, 06:54 PM   #1706
Steve,
Grab me (or Jim A) at the next RAMS race - we'll get it fixed
Rich
Rich Browne is offline   Reply With Quote
Old 06-10-2008, 10:48 PM   #1707
bsmooth's Avatar
Originally Posted by Rich Browne View Post
Steve,
Rich
I will.
BTW. It was good to see you out at the track again.
-Steve
Old 06-19-2008, 11:27 PM   #1708
dameetz's Avatar
Default Clutch set up
Can someone post a good clutch set up pls...like Spring? Shoes? Preload? Endplay? I m having trouble with mine. It seems my car just doesnt have the low end side. I m using Nova engine with it and a friend of mine who uses the same eng in a Serpent has more than enough low end. At the moment i m using Grey clutch shoes and it worn out just after a whole main. Both the clutch bearings gone too after the race. This problem frustrated me a lot as I have to replace everything after a race.
dameetz is offline   Reply With Quote
Old 06-20-2008, 04:37 AM   #1709
Clutch Setup - Read This - http://www.kyoshoamerica.com/techtips.php?techtip_id=32
ElliotCanada is offline   Reply With Quote
Old 06-20-2008, 06:20 AM   #1710
dameetz's Avatar
Thanks ElliotCanada.
Kyosho Evolva M3 tomkelley Nitro On-Road 1002 05-19-2015 08:49 AM
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
