Old 12-10-2007, 11:49 PM   #1666
Originally Posted by Rick Davis View Post
Acid - we played with carbon fiber plates two seasons ago and had some issues with battery pack failure that I felt were related to excessive vibration being transmitted by the harder material, I went back to the plastic one and problems went almost completely away. If you're having screw loosening issues use a product like vibra-tite on the screws - also I change to Allen head screws for a better "feel" on the torque.
Thanks Guys. Appreciate the info. Will try switching to the allen head screws.. you right, it will help with the torque feel.
Regards
Acid
Acid is offline   Reply With Quote
Old 12-11-2007, 10:50 AM   #1667
blanks596's Avatar
Trader Rating: 14 (100%+)
Hey fellas, just picked one of these up ans was wondering, how do you adjust the front and rear roll centers?
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 12-11-2007, 11:02 AM   #1668
Front roll center is adjusted by moving the upper arm inner pin mount block - up (lower roll center) using shims or down (higher roll center)using option parts (Shimo or Empire). Rear by changing the blue spacer on the top of the hub carrier (more raises rollcenter , less lowers)
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - IGT8 2017
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 12-11-2007, 12:05 PM   #1669
blanks596's Avatar
what about the rear lower sus holders. I see optios of 7-2 and 7 but don't know what these mean, and are there only 2 types of these sus holders?
Max S
Old 12-11-2007, 01:54 PM   #1670
The 7 (indicates # of mm up from chassis of pin centerline)was the original from the early Evolva, by the time I got involved with the car mid 2004 the 7-2in (which moved the pin 2mm inboard) was standard, there is also the 7-3.5 necessary to use with the 2007 lower rear arms, this pin movement has a small effect on rollcenter but the easy changes are the ones previously mentioned.
Old 12-11-2007, 08:16 PM   #1671
RcLoCo Online's Avatar
Default evolva 07 modded all the way!!!
hey guys i have a extremly modded wc 07 with the updated conversion ,i have the blackletter chassis with drilled chasis to lower servo, extra parts, every empire mod avalable, including both sets of hangers, i can sell a rody c5 w/new rod etc.. with less than a 1/2 gallon thru if interested id like to get $650 for roller as its run twice!!!and blackletter edition was 1k alone not including another $500 or so in hop-ups all empire racing, please email or pm for more info!1Thanx , i have references on here if you like to vouce my creditability!!!Includes killer custom made battery, to many hop-ups all teflon pivot balls, lightweight outdrives, lightweight tire clamps, way to much, THIS iIS A STEAL!!!
Ill sell motor for 300 as its new as well, 1/2 gallon and fresh rebuild never run
email [email protected]
tommy
{Mugen Seiki } { RB Concept }
{ Team Durango { JP Motors }
{K.O. PROPO } {SERPENT 811, FOREVER WAITING ON SERVO FIX!!} Nuff Said!!!!
RcLoCo Online is offline   Reply With Quote
Old 12-15-2007, 12:06 AM   #1672
moy
moy's Avatar
is it possible to use the 7-2in on the 07 lower arms?whats the diffrence?so is the 7-3.5in makes the track width longer and 7-2in shorter?
tnx
moy is offline   Reply With Quote
Old 12-15-2007, 03:19 AM   #1673
Richard E's Avatar
Rick has explained it clearly, the 7 indicates # of mm up from chassis of pin centerline, with the 7-2in the pin moves 2mm inboard, subsequently the 7-3.5in likewise. Changing the blocks slightly changes the rollcenter. Assuming you run the car at a normal rear width, the gap between the lower suspension arms and rear uprights is different. The only thing is that with the 7-3.5in the gap is maximum i.c.w. the 2003 arm, which may look a little bit funny, for that reason the 2007 arm was extended. However, all 3 blocks and the rear 2003 or 2007 lower suspension arms are interchangeable. Hope everything is clear.
Richard E is offline   Reply With Quote
Old 02-24-2008, 09:35 AM   #1674
johndayo101's Avatar
Trader Rating: 128 (100%+)
Default evolva
im looking for the 2007 conversion kit for evolva.?? can anyone send me a link,
i want to change all my screws to hex screws, what is the best screws that are available?
johndayo101 is offline   Reply With Quote
Old 02-24-2008, 09:44 AM   #1675
cdelong's Avatar
Originally Posted by moy View Post
can anybody help.i have a problem with all my shocks on my evolva,everytime i replace the shock oil and race it,its leaking from the top.i use 60 wt. is it the ballon thing? or the oil to thick?
tnx
Bleeding Kyosho shocks is a bit tricky. I like M****'* idea of a bleed hole. I drilled my collars with a tiny bleed hole and they bleed like a champ now. The stock shocks are fine, but bleeding them was tricky for ME, so I drilled the bleed holes and my shocks are much more consistent.
Always check the bladders especially if you see oil above the bladder- almost always a torn bladder. I use the white bladders. I tried the M**** clear bladders, but they don't fit the Kyosho cap very well and tear easily after 1-2 rebuilds.
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 02-24-2008, 09:45 AM   #1676
cdelong's Avatar
www.ashfordhobby.com has the conversion kits and I use the screws from RCScrewz. Pricey but easy to perform maintenance over and over vs. the cheesy phillips screws.
KYOSHO EVOLVA
35PLUS21
Old 02-24-2008, 09:56 AM   #1677
thanks.. appreciate the help.
Old 02-24-2008, 11:11 AM   #1678
Trader Rating: 27 (100%+)
I got a screw set from rcscrewz and noticed that some of them do not sit flat on the chassis. Mainly the countersunk ones. Maybe it's was my luck. I ended up buying HPI screws. Those worked really nice.
JoeyE is offline   Reply With Quote
Old 02-24-2008, 12:24 PM   #1679
Default screw
i was thinking to get the mugen titanium screws set and set b? is there anyone who used these screws on there evolva?
Old 02-24-2008, 03:22 PM   #1680
occ
Trader Rating: 15 (100%+)
Yes, I used some of the Mugen titanium screws in my Evolva 07. Not all of them are suitable though.
occ is offline   Reply With Quote
Kyosho Evolva M3 tomkelley Nitro On-Road 1002 05-19-2015 08:49 AM
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
