Old 10-19-2007, 08:06 AM   #1606
avs
avs's Avatar
Default handling qualities question
hi, i just got a evolva 05 (thanks Scott), and tried it out last weekend.
i was wondering if others had noticed this (please note, this is not a 'which is better' question!)
my throttle control is suspect, and my driving style is to give as much throttle coming out of a turn as i can and rely on the car's behavior to indicate a limit.
it seems that the evolva has a gradual, but distinct understeer out of slower corners when overpowered with too much throttle, while in the same situation, the rearend of my 960 would let go abruptly.
is this a common characteristic, or have i accidently setup the car to make this happen?(if so i would like to duplicate it in my 960!)
please this is not a 'which is better' question.
avs is offline   Reply With Quote
Old 10-19-2007, 08:30 AM   #1607
Post your setup, I'm sure someone can help.
[FONT="Arial Black"][SIZE="2"]team kyosho / empire racing / speedmerchant / ko propo / novarossiusa.com / phat skeems paint works / 301 raceway [/SIZE][/FONT]
NitroHead is offline   Reply With Quote
Old 10-20-2007, 10:08 AM   #1608
avs
avs's Avatar
Arrow
here is my setup, std '05 WC parts with:
tires 35/35 67/74
front
shocks Hposition, white springs, kit oil
0 shims under front hangers
scrub 1.0
caster/wb 6 short
camber 0.5
toe 0.5
width 252
downstop 0
ride height 6
rear
shocks 1 position, white springs, kit oil
scrub 1.0
upper arm 5
camber 3.5
toe 2.5
width 262
downstop 9
ride height 7
i hadn't noticed how much rake and little caster i had, i will try using more caster and less rake.
any suggestions?
Old 10-20-2007, 05:06 PM   #1609
Richard E's Avatar
Although your setting data are not complete, I'll give my first advise.
Before I do that I would like to say, you will find out that the Evolva has a very wide "sweet spot" and the chassis is very forgiving compared to the S brand that you mention. It is easier to feel when the car traction in general nears the "edge". Anyway, that is my personal experience, other drivers might have different experiences, I advise you to ask them as well.
Front: I would not go as far creating a caster of 6 degrees. You really want your caster angle as close to 11 as possible, but definitely not at the expenses of everything. Try 11 or 9 and not over 7.5 degrees. A toe out angle (instead of 0.5) of 1 degree per side works very well.
Rear: Camber of 3.5 degrees seems to me like a lot. In general I set it to 2 to 2.5 degrees, and make an adjustment, depending of the tyre wear on a specific track of the first set of tyres on a training day.
The kit shock oil is okay however quite thin. In The Netherlands we usually go a little higher in viscosity, but not a lot (500-600) front/rear. Sometimes I use 800 at the rear to make the car more stable, in particular for the finals.
Of course this is only my opinion and personal experience, and as I said, track conditions here in Europe may differ form US, and you might want to set your car to suit your own driving style. Some people have a very "relaxed" driving style, making the car roll a lot, and some drivers tend to push their car a lot during a race, so basically it depents what you want.
Questions: antiroll bar positions? Uprights 0 or 2 degrees? Which body do you use? Many other settings to consider, and for every track situation and weather conditions you might want to create the ideal setup / geometry for that specific day.
Hope it helps, have fun at the track!
Richard E is offline   Reply With Quote
Old 10-20-2007, 07:40 PM   #1610
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Nice informative post. Josh Cyrul also posted some good info on the Kyosho America site under the tech info.
Had a sedan race to go to today so I wasn't able to work on my Evolva much the past couple days, it's killing me not having that thing ready to hit the track, lol.
Old 10-21-2007, 09:58 PM   #1611
On a lot of the setup sheets people are checking off "N" for shock pistons. Does that just mean they are running the stock pistons?
Old 10-21-2007, 10:56 PM   #1612
occ
Trader Rating: 15 (100%+)
Yes, thats right. I guess "N" just means normal.
occ is offline   Reply With Quote
Old 10-21-2007, 11:22 PM   #1613
Alright, thanks. I'm used to reading 1/10 EP sedan setup sheets, looking at this sheet, I need to learn a lot.
Old 10-22-2007, 03:57 PM   #1614
Were any of the molded suspension parts changed between the '05 and the '05 WC kits?
Old 10-22-2007, 04:12 PM   #1615
Richard E's Avatar
nope, all moulded parts are the same, but I can assure you that the option parts that come with the WC edition are WOW ... they make it easier to make the adjustments and/or really add to the overall performance of the car as well ... on top of that I recomment the adjustable rear sway bar ... that helped me out a few times, either to improve high speed cornering or solving uneven tyre wear at certain tracks ... and it gives more play area for balancing the car.
Old 10-22-2007, 05:06 PM   #1616
Cool, I'm just wondering what parts to put on mine. I got an '05, then got the WC parts to update it, as well as the '07 conversion set.
How many different front upper arm mounts are there available?
Old 10-22-2007, 05:55 PM   #1617
gashuffer's Avatar
Trader Rating: 48 (100%+)
You need nothing else. Great car
gashuffer is offline   Reply With Quote
Old 10-22-2007, 10:37 PM   #1618
avs
avs's Avatar
Originally Posted by Richard E View Post
Although your setting data are not complete, I'll give my first advise....
Richard,
thanks for the observation, i will try those changes on my tuning session.
Old 10-22-2007, 10:55 PM   #1619
lol, I already have the parts I want, I just have a lot of different pieces for adjustment, and dont really know which to use while building. I'm trying to use JJ's setup from the Nats, I think the easiest thing to do might be to try and meet up with him this week and have him explain things to me
Old 10-23-2007, 10:09 AM   #1620
Richard E's Avatar
That's an easy one again. If you have to choose parts, go from 2007 + WC --> 2005. Guess you know what I mean. Indeed you do not need any other parts. You own a great car! Enjoy assembling it! And go-go-go hit the track!
Kyosho Evolva M3 tomkelley Nitro On-Road 1002 05-19-2015 08:49 AM
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
