Old 03-23-2009, 01:33 AM   #1
Default Novarossi glow plugs ????
I am new to the hobby and it seems that novarossi glow plugs have very many choices to pick from can anyone explain this to me and if so is there a chart out here so i can understand thanks btw i just bought a (murnan modified novarossi .12 sct )
infernoman2008 is offline   Reply With Quote
Old 03-23-2009, 02:41 AM   #2
NiTrO BoOsTeR's Avatar
well im not running a Murnan but i got a 3SCT - Tuned and im running C7TF but gonna order some C7TFC (i think) they are the Ultra Version. just a better Quality plug. the 7 runs a bit cooler so u can lean it out a bit more and gain more top end
Mitchell
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 03-23-2009, 08:08 AM   #3
musti72's Avatar
there is no glow plug named 7TFC
the number(5,6,7,8)/turbo(T)/gold(G) or not/cald(hot)(C) or freda(cold)(F)
a lot of combinations can be made
musti72 is offline   Reply With Quote
Old 03-23-2009, 08:44 AM   #4
wmay11's Avatar
I think the .12 motors like hotter plugs, number 6 and 5. The shorter and longer body plugs will change the compression ratio of the motor slightly. I run 21 and generally stick with #7 plugs. Do a bit of research or ask Grinder what the best plug and head clearence is for that motor, two small things that will make a big diff.
RX8 - Savox - Reds Racing - Ko - Contact - Enneti
wmay11 is offline   Reply With Quote
Old 03-23-2009, 09:17 AM   #5
Thanks for all the help but i still do not under stand all the codes of the plugs and when to use what plug in what type of condition????
Old 03-23-2009, 11:29 AM   #6
JayL's Avatar
http://www.outlawrc.com/glowplugs.htm
JayL is offline   Reply With Quote
Old 03-23-2009, 12:52 PM   #7
wingracer's Avatar
Trader Rating: 24 (100%+)
They will not change compression at all. These are not like standard plugs. The turbos fit flush regardless of body length. The only difference is that long body plugs seem to retain a bit more heat giving a bit better idle for some conditions. They act like a slightly hotter plug.
For .12's I usually use 5's and 6's for the average short track. A monster 301 style track might prefer a 7.
Edit: Actually now that I think about it, the longer bodied plugs probably have a deeper hole so they might cause a very slight drop in compression, unlike standards where a longer body means the plug is deeper in the head and therefore slightly raises compression. I'll have to yank some elements out of some old plugs and check.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 03-23-2009, 01:37 PM   #8
JayL's Avatar
the long/short plug part is up top, not the inside the engine, so no compression change
Old 03-23-2009, 03:27 PM   #9
ALG
Go with the 6F and if you are eating that plug go with the 7F, as said before, only on MONSTER tracks go with the 7,
have fun and I forget, run with 16% nitro, more is just waste of money
ALG
ALG is offline   Reply With Quote
Old 03-23-2009, 05:18 PM   #10
haha sorry mate, i must have been smokin somthin that night i ment the
C7TGF - the Ultra (thats on the Nova Website) and the one im using now is the C7TF (the older style Plugs)
Old 03-23-2009, 07:07 PM   #11
Trader Rating: 15 (100%+)
Even if the length is above the head it is still part of the compression chamber. Lets say that the hole where the wire is 1 mm x 3mm deep = 3 cubic mm. Now lets say that the long body plug is 1 mm x 5mm deep =5 cubic mm. It is volume in the squash area of the compression chamber. The numbers that I gave are not the correct sizes but I used them to show that the length of the plug would matter in the volume that the plug has. It is not much.
THE DOCTOR is offline   Reply With Quote
Old 03-23-2009, 07:45 PM   #12
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Given the engine displacement 2cmm is huge. They used to offer "special" plugs that cost a couple bucks more and durability was much greater than what I have seen out of the available plugs lately.
I need to spend sometime on there web-site to research this as the cost effective Ninja plugs are on the endangered species list...
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 03-23-2009, 09:26 PM   #13
lil-bump's Avatar
Trader Rating: 83 (100%+)
I emailed fusion motor sports awhile ago and ask the about long and short plugs. Basically a long or short will not change compression. but the two plugs will hold heat from the engine in different matters. In the past most 12 engine where tuned with high nitro content and users used very cold plugs. that's when 30% nitro was the norm. Well since the price of fuel has risen some drivers are opting to go lower on nitro content (16-20%) with that being said; racers now could lower the deck head height and move to hotter plugs.
A hotter plug will give better idling and better low accelaration at the expense of top end. A colder plug might give a rougher idle and trouble clearing out the engine but once a little heat has been generated the engine will sing. I normally use cold plugs because my engine is shimmed for 25% but I do intend to move to 20% this season maybe 16% (If I can find a dedicated supply) At that time I would probally move to a medium heat plug.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 03-23-2009, 09:37 PM   #14
wingracer's Avatar
Actually that would be 2.355 cmm and 3.925 cmm. Volume of a cylinder is pie x radius squared x height. I still want to measure the holes to see if a long body plug actually does have a deeper a hole.
Team Shepherd USA
Old 03-24-2009, 10:38 AM   #15
JayL's Avatar
I guess I wasn't clear enough, sorry, no part of the plug that is in the compression chamber is different....It's the part in open air, the part you stick the igniter on, compression doesn't change.
Novarossi engines thread EVOLUTION Onroad Nitro Engine Zone 5440 Yesterday 02:12 AM
brand new os and novarossi turbo plugs glow plugs johndayo101 R/C Items: For Sale/Trade 11 11-16-2008 08:07 AM
LOSI 8 RACE KIT , NEW MOTORS AND MORE BKILLER R/C Items: For Sale/Trade 16 08-11-2008 03:58 PM
Novarossi plug differences AMGRacer Onroad Nitro Engine Zone 9 06-12-2007 06:07 AM
Mugen MBX5-R Buggy & Nova Motor M-SPEC Australia For Sale/Trade 21 05-10-2007 11:14 PM
