Old 12-01-2003, 11:15 PM   #46
For Fail Safe, is KO Fail Safe works for Futaba Remote? Anyone knows? Thanks.
ckh1328 is offline   Reply With Quote
Old 12-01-2003, 11:39 PM   #47
InitialD's Avatar
Any external fail safe device will work on either radios.
Old 12-02-2003, 12:18 AM   #48
If you choose 3PK set with PCM Modulation receiver, you do not need external fail safe, coz its included.
GoldFinger is offline   Reply With Quote
Old 12-02-2003, 12:30 AM   #49
InitialD's Avatar
You actually can under PCM mode but then like what you say, it is redundant as 3PK already has built in fail safe...
In any case, I forgot to add that if you're using the 3PK under HRS mode, you CANNOT use the external fail safe device. This is mentioned in their manual.
Old 12-02-2003, 01:00 AM   #50
Nice to meet yo u here D.
True for the PCM, sorry it is not included actually it is a feature that we can use it.
In HRS mode(HRS receiver) actually we could still using the fail safe, you can switch off the TX before RX then you can see that the servo is going to the position that you set before.
But no Battery fail-safe feature just like we need in gas powered car so PCM is better for gas car.
Hope this will helps..
Old 12-02-2003, 01:28 AM   #51
InitialD's Avatar
Ummm, on my 705 with HRS receiver, battery fail safe feature is activated.
But I think you mistook what I mentioned earlier. With HRS, you cannot install the EXTERNAL type fail safe units like the one from Venom, KO or even by Futaba.
I quote from the 3PK manual;
FailSafe: the FS1 FailSafe may be used with standard PPM/FM receivers to return throttle to idle in case of a loss of signal,
similar to the FailSafe function of PCM/HRS receivers. NOTE that HRS receivers can not operate with the FS1.
Old 12-02-2003, 01:43 AM   #52
....Oohhh
Im gonna try that. Looks my English is very bad, so i wrongly understand the manual.
1 more thing D , when you tune the carb (w/ HRS rx) if the metal part of driver touchs your skin, some glitch is happen in your servo is it true?
Old 12-02-2003, 01:59 AM   #53
InitialD's Avatar
Don't worry. Your english is pretty good already !
I have not noticed this. But I know that if I start the engine with my glowstarter and if it touches the heatsink, the servos will glitch a little. Both PCM and HRS.
Old 12-02-2003, 08:29 AM   #54
Thanks, but sorry I am kind of lost. So do I need an external Fail Safe if I am using 3PK?
Old 12-02-2003, 08:40 AM   #55
Regional Moderator
Darkseid's Avatar
Anyone who might be looking for a good radio, UltimateHobbies has a sell on the Lynx3D FM w/spectra module AND Novak Xxtra for only $189.99
I would certainly pick one up if I wasn't already running this setup.
TLR 22...Tamiya F104...
Old 12-02-2003, 08:54 AM   #56
InitialD's Avatar
Sorry for the little digress...
An external fail safe device like the Venom, KO or the Futaba varient is NOT needed when you use the 3PK because it already has an in-built fail safe that you can activate.
If for whatever reason you want to run an external fail safe with the 3PK (of course this is redundant), you can do it when you're running under PCM mode but NOT when you're running HRS. Hope that was clear !
Old 12-02-2003, 10:07 AM   #57
Old 12-02-2003, 10:30 PM   #58
Send a message via Yahoo to SerpentNewbie
I am planning on getting a KO PROPO EX-10 Helios.... just wondering if anyone could tell me where the best price to get one is?
SerpentNewbie is offline   Reply With Quote
Old 12-02-2003, 11:20 PM   #59
microrcshop ...comes with free shipping ...I bought my helios from them
microrcshop
penggoy is offline   Reply With Quote
Old 12-03-2003, 10:17 AM   #60
The best price if you are only getting a remote is from your lhs.
2 DTX ICE - Car stands, 8000 7.4 lipos, B4 Spares, Tires, 3PK radio M8 radio spektrum racer34v R/C Items: For Sale/Trade 7 07-16-2008 06:10 AM
gt2 truck,spectrum radio,ae radio,glow starters.......trade for non rc realted xsxracing Other Items: For Sale/Trade or Wanted to Buy 1 08-07-2007 05:43 PM
gt2 truck,nitro extras,spetrum radio,ae radio,charger,battery more....cheap xsxracing R/C Items: For Sale/Trade 0 08-07-2007 08:40 AM
Good radio:fm, any brand, no offer refused! needed radio(3 channel t to the maxx2 R/C Items: Wanted to Buy 16 02-05-2005 11:20 AM
Futaba 3PJS FM/PCM radio w/7 sets of crystals and MATT FRANCIS radio bag Ron Meloni R/C Items: For Sale/Trade 1 01-08-2003 04:43 PM
