Old 03-18-2009, 10:09 PM   #1
beers4evo's Avatar
Default servo noise...normal?
hey guys, theres a few sites i visited in regards to servo noise and just thought i'd get the right information as its all mixed thoughts.
Now, i have 2 digital servos....and they make noise....on idle its very little noise, sometimes no noise at all (servos in neutral) upon opening the throttle or steering, it makes a buzzing noise.
I have checked my steering servo and made sure it was aligned correctly and when turning the wheel on the controller, i made sure the horn is not binding/or pressing against anything. But the noise occurs. Yes thats right, I have done epa as well on my controller
Same goes with throttle...
Another thing, some sites say, digital servos making noise is NORMAL, thats how they are. But also could be tension...If the servo's make noise then is that ok? and as long as its not pressing up against anything (tension)...
Now for another issue, my buggy, with the receiver, servo and radio it came with was all AM. I changed the receiver to digital (specifically to the mx3fhss receiver) and put the same controller settings as the AM radio on the mx3fhss and upon neutral, a slight buzzing noise occurs, for steering and throttle...so im assuming this is normal then....otherwise please explain why not?
thanks
beers4evo is offline   Reply With Quote
Old 03-19-2009, 04:08 AM   #2
I use ko digitals and they have made a buzzing noise since they were new. The old jr's I replaced didnt buzz, but they were not digis.
Jason
thewood1987 is offline   Reply With Quote
Old 03-19-2009, 06:38 AM   #3
wingracer's Avatar
Trader Rating: 24 (100%+)
Digital servos make all kinds of buzzing noises. Nothing to worry about.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 03-19-2009, 08:47 AM   #4
speedracer1bp's Avatar
Default servo noise
I had some servos that used to make noise. I have since started using li-po's and using a Novak Voltage regulator. No more noise. The regulator takes the 7.4V Li-po's and regulates it to a perfect 6V. If you are using Ni-cads or Ni-Mh, they are not a perfect 6v either. Most servos cannot take the extra voltage. The buzzing you hear is more than likely the Potentiometer.....the device that centers your servo, and is not rated for extra voltage, thus the buzz. Just my 2 cents......
speedracer1bp is offline   Reply With Quote
Old 03-19-2009, 06:18 PM   #5
Trader Rating: 93 (100%+)
Default Buzz
The ko servos seem to buzz more than others. This is common on digital servos. I like it when sitting on the track and people ask what that buzzing noise is.
latemodel13 is offline   Reply With Quote
Old 03-19-2009, 08:15 PM   #6
spurgear's Avatar
Send a message via MSN to spurgear
im using Digital futaba with HRS and my throttle servo buzzes only when its under strain from the brake. So any little strain under neutral will buzz
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 03-26-2009, 02:18 PM   #7
Default Buzzzzzzzz!
thanks
Almost all digital servos make that high pitch buzzign sound you are experiencing. This is the result of motor and circuitry making fine adjustments trying to keep the gears, and thus the servor horn in a steady position until they get input from your radio.
I'm not sure if you know this or not, but it is also why digital servos drain batteries faster than non-digital servers. if you'r not careful you can drain a battery pack just letign yiour car sit on the ground with power on.
Yes....I did that once before
You might want to consider just using normal servos in your throttle and only use digital for steering. Otherwise, invest in lipo receiver packs and a good votlage regulator.
I mean honestly, I only have digital servors because they have come down in price so much from when I first started RC'ing (2000) and the because of the torque they provide. So unless you are a serious racer (with considerable driving skills) or you do alot of off roading, then you don't have to use digital.
With all that said.....they do add to the bling factor of any rc vehicle, but they are becoming more and more common.
Kyo83 is offline   Reply With Quote
Old 01-20-2011, 04:30 AM   #8
RCaddict0's Avatar
Trader Rating: 85 (99%+)
Send a message via AIM to RCaddict0
I have a JR z9000t and it makes that same "buzzing" noise your refering to
E Maxx Brushless ~ Rustler VXL ~ Rally VXL 1/16
Ruckus Brushless ~ Stampede VXL
* Hobbywing Powered *
RCaddict0 is offline   Reply With Quote
Old 01-20-2011, 05:02 AM   #9
NitoriousRC's Avatar
Well that's great ... and a great dig up of a nearly two year old thread~
NitoriousRC is offline   Reply With Quote
Old 03-19-2011, 08:19 PM   #10
RCaddict0's Avatar
Your welcome
We will pull it up one last time for the 9000t that seems to be noisy but workin flawlessly!
RC10B4/T4 Forum DerekL Electric Off-Road 14338 11-18-2017 04:19 PM
SORMCC onroad racing black-knight Australian Racing 7011 11-09-2014 06:31 AM
KO PROPO EX-10 Helios q's Kenshin Electric On-Road 2225 03-13-2014 02:04 AM
servo noisy; normal? NitroWD Radio and Electronics 6 08-05-2008 03:32 AM
receiver Noise ?? catchm3srt Electric Off-Road 6 01-10-2007 07:20 PM
