Old 03-09-2009, 07:14 AM   #1
beers4evo's Avatar
Default car revs, but won't move
hey guys, i have a kyosho evo 2 rrr...my issue...
start the car up, hit the acceleration on controller, and the car won't move, just revs....
Now....I checked the linkage and is fine, carby is fine, its not the brakes, car rolls freely when pushing it, flywheel spins when doing it manually by hand, pinions spin doing it manually by hand, the controller settings are fine and I'm out of ideas...my friend told me its too rich and to lean it (haven't had a chance to do that yet) but was wondering for any other opinions for when I do test it again...
thanks
beers4evo is offline   Reply With Quote
Old 03-09-2009, 07:26 AM   #2
check to see that the clutch is engaging the clutch bell if it starts and run it should not be that it too rich even a rich motor will make the car go you may have to much play in the clutch bell if so the clutch shoe cant make it out to engage correctly
Roadrash730 is offline   Reply With Quote
Old 03-09-2009, 07:28 AM   #3
jameslow's Avatar
thanks
- what do u mean by flywheel spins when doing manually? the flywheel is not secure onto the engine crank shaft?
- it could be ur engine really in v rich mode!
- how big is the gap between ur clutch shoe to ur clutch bell?
Waiting!
jameslow is offline   Reply With Quote
Old 03-09-2009, 07:44 AM   #4
yeah i guess i missed the flywheel part, if you spin the flywheel it should turn over the motor and some time the presure used to start against the startbox will be enough to start it but if its not secure enough when you let of the box the flywheel will spin on the crank shaft
Old 03-09-2009, 09:48 AM   #5
Speyederjedi's Avatar
Sounds like your clutch shoe is not grabbing the clutch bell. This can be caused by a few issues.
1. You may have the clutch spring to tight and it is not allowing the weights to overcome the spring tension enough for the clutch shoe to reach the clutch bell.
2. You may have to much gap between the shoe and bell or the end gap between the thrust bearing and clutch retainer. This can cause the same problem. When the motor spools up if there is is to much gap between the shoe and bell the spring won't allow the shoe to reach the bell. If too much end gap then the bell will move too far out and again the shoe may not reach or just reach the bell but not enough to fully engage.
3. The flywheel is not secured and it is spinning on the engine shaft. Check the engine collet to be sure it is not longer than the depth of the flywheel. If it is this is not allowing the flywheel nut to completely secure the flywheel down. You may have to grind down the collet a bit to get it to the right depth so that you can tighten down the flywheel properly. Just be very sure to grind it down evenly or you'll end up having a flywheel which mounts out of center and that will create a whole other problem.
Hope this helps.
Regards,
Speyederjedi
Schumacher Mi5/Serpent Cobra GT
Novarossi Kappo Rally .21/Novarossi Kangaroo .21
Airtronics M8/Spectrum
SWEEP Tires
Speyederjedi is offline   Reply With Quote
Formula 1... Darkseid Chat Lounge 15120 01-14-2018 06:04 PM
Rc10ntc3 Taz_S Nitro On-Road 9437 05-28-2017 09:13 PM
NTC3 Running but not moving **Need Help** xman Nitro On-Road 11 06-14-2008 07:54 PM
HPI R40 and OS CV-R .18 Engine RObErT_RaTh Australia For Sale/Trade 10 06-16-2007 02:07 AM
difference between 4 cycle and 2 cycle engine? dragoneuh Onroad Nitro Engine Zone 35 01-05-2006 10:00 AM
