Kyosho FW-05RR Forum >
Old 01-04-2006, 12:14 AM
Default Kyosho FW-05RR Forum
This is a thread for us RR fans it's used to show pics and setups and any inquiries.(problems)
ShAfTy is offline
Old 01-04-2006, 12:48 AM
Trader Rating: 15 (94%+)
awesome car on high traction surfaces
was a bit hard to get setup on loose surfaces
upgrade to 37t ring gears as a must, the top end is awesome then
mrgsr is offline
Old 01-04-2006, 12:58 AM
i have not tried that yet i was thinking about doing that. what engine are you running i've got a o.s tr but im soon updating to a sirio evo 3 or a o.s TZ
ShAfTy is offline
Old 01-04-2006, 01:01 AM
i was using the os tr then i upgraded to the os tz
awesome engine!
i dont use the fw anymore, i now use the v one rrr
i found that its easier to set up and i can get better support for it
mrgsr is offline
Old 01-04-2006, 04:32 PM
i just got one of these my friend says i sould have got rrr but i think im gonna like it does anyone have a good starting set up and what parts i should add
donald wilson is offline
Old 01-04-2006, 04:48 PM
DITTO
I have a friend that runs a OS TZ. very quick and good top end. The car is quick and has the ability to handle like on rails once set-up. General good set-up doesn't vary much from stock. Personal trial and error from there w/ minor changes. Try to run w/o the sway bars at least once to get a feel for the full range of how the car handels. I still haven't varied the spings, just played w/ shock wghts, diff grease and camber. Toe front usually 0, rear 2. Camber may vary from 1.5-2, rear 2.0-3.5. Droop? What's that....naw don't remember, think stock. Hope this helps.
Havy
havy is offline
Old 01-04-2006, 08:02 PM
k617nu-b's Avatar
My 05RR with OSTZ 5 port....
Attached Thumbnails Kyosho FW-05RR Forum-dsc01489.jpg   Kyosho FW-05RR Forum-dsc01490.jpg   Kyosho FW-05RR Forum-dsc01495.jpg   Kyosho FW-05RR Forum-dsc01496.jpg
k617nu-b is offline
Old 01-05-2006, 06:35 PM
ChApS's Avatar
Nice RR
ChApS is offline
Old 01-05-2006, 06:37 PM
ChApS's Avatar
Does anyone use black spring for the rear.
ShAfTy you got PM
ChApS is offline
Old 01-05-2006, 07:31 PM
Here is my RR.
Attached Thumbnails Kyosho FW-05RR Forum-dsc00064.jpg   Kyosho FW-05RR Forum-dsc00065.jpg
jeff whiting is offline
Old 01-05-2006, 07:33 PM
ChApS's Avatar
is that a k factory or 3 racing gear box.
What engine is bolted in.
ChApS is offline
Old 01-05-2006, 07:39 PM
Its the 3 Racing one. I have 39 tooth rings in it but my 37's just came in. The 39's had so much bottom end that with any thing but glue for a track surface it would just spin all 4 tires!!!
Old 01-05-2006, 07:42 PM
ChApS's Avatar
cool hows you're top end with the 39's does it make much of a diffrence from the stock 40 tooth rings i think thats what comes with it.
ChApS is offline
Old 01-05-2006, 08:16 PM
I never ran the car with the 40's (yes, thats what it comes with) so I am not sure of the differnce between them. If ever find a track with gobs of traction and short....the 39's would be just a freak show. Of course my Colllari might have something to do with it too
JEFF
Old 01-05-2006, 08:49 PM
37t are a must
mrgsr is offline
