Ok Mugen Bro's need HELP with MRX4-R stopping power !
Hey Bro's any tips on MRX4-R stopping power ? I have installed new break pads ( yellow ones ) clean the disk really good and made sure all linkage and screws are tight but my MRX4-R seems to have inconsistent braking , it very's from lap to lap , one lap it break fine after the straightaway next lap it fades , next lap its ok , next lap it fades and then next lap it strong this is off and on and yes my lap times do suffer so any help will be of great help.
Thanks for your time and help.
Big C
Big C
Big C
Big C
The the yellow pad on one side and black on the other side...
both side are yellow.
Sorry Francis I got you on the yellow and black side , maybe I need a new disk ?
Francis thanks for your help and time bro , my MRX4-R is about a year in a half old with about 30 races on it and tons of weekend play time the brakes started to fade away 2 races ago so I bought some new pads but still had the problem, I know it could be a # of things but thought I would come to some Mugen Bro's for some help. Again thank and I will try the yellow and black pad combo.
A few tips.
1. The yellow + black combo works well.
2. Try another servo and make sure it has plenty of torque.
3. Try a longer spring or piece of fuel tubing on the brake linkage to increase the amount of servo travel needed to go from the start of brake pressure to full brakes. This can give a more consistent feel.
Hey wingracer, thanks for the great tips I will look into it , by the way what servo is a good one for braking on these high power high speed 8 scale on road ?
I love Futaba S9452 servos. The things kick butt and last forever.
Drill more holes in the disc. The outer ring of the disc does not contain holes what will keep dirt and oil between the disc and brakepad. Holes in the disc will scrap off the dirt and keep the surface clean and so you will have a better brake.
Thanks to all that replied and for the info.
