Old 02-28-2009, 06:45 AM   #1
prd
Default fuel problem
Hi wonder if anyone can help have kyosho pureten gp alpha 2
it seems to be runing really rich even with the needle screwed right in it ueses a tank of fuel in mins and it still smokes quite abit and does not run right please can any point me in the right direction thanks
prd is offline   Reply With Quote
Old 02-28-2009, 07:09 AM   #2
s10dude's Avatar
where is your low speed needle at ?
is motor broke in yet ?
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 02-28-2009, 02:28 PM   #3
prd
Default fuel prob
Hi the motor is broken in yes but all i can find is the high speed needle and the idle adjustment screw there is no low speed needle thanks
Old 02-28-2009, 03:15 PM   #4
s10dude's Avatar
they ALL have low speed needles....you just gotta look harder...
Old 02-28-2009, 03:23 PM   #5
Roelof's Avatar
Send a message via ICQ to Roelof
Not all have a LSN....
Also take a look to the exhaust, maybe you have to clean it out so more pressure will flow out instead to the tank (what will cause a rich setting). And be sure ti use the right plug, if the plug is old then get a new one.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 02-28-2009, 04:01 PM   #6
freestyles's Avatar
Trader Rating: 14 (100%+)
I don't know the car does it have a 2 speed. I once had the same sort of problem and actualy found that it was bogging the motor.
Or how is your clutch set up, this to can make you think the motor is playing up
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 03-02-2014, 05:36 PM   #7
F3ckLand's Avatar
F3ckLand is offline   Reply With Quote
Old 03-03-2014, 10:43 AM   #8
You won't believe this at first, but I bet almost anything it is your air filter. Not that I would ever do this (this is a lie, I did this), but I have a "friend" that put oil on a paper-element air filter, which completely stopped it up. With a basically plugged air filter, the motor just isn't breathing, so it is pretty much impossible to lean it out. So, either replace your air filter, or clean it really well, and be very careful - richen it up or you will blow out your motor once it starts breathing again (again, I have a friend that may have had to replace my, i mean his RB worlds because of this very reason).
Post up if this is the problem - I chased this issue for months, or maybe even a year and it drove me crazy! Good luck.
qjmcrae is offline   Reply With Quote
Old 03-03-2014, 12:40 PM   #9
blis's Avatar
Looks like a HSN only...
https://www.kyosho.com/jpn/support/i...p_alpha2_m.pdf
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Fastlane Raceway kansasracer Kansas/Missouri Racing 17302 11-12-2017 03:30 PM
Rc10ntc3 Taz_S Nitro On-Road 9437 05-28-2017 09:13 PM
Kyosho Gas powered 1/12th pan car ianhobbies Nitro On-Road 1083 02-24-2017 09:46 AM
Kyosho FW-05R Finnitro Nitro On-Road 5443 02-07-2017 11:10 AM
EGTC Summer Outdoor Series (ESLROC) Silver Cup Northwest Racers 1991 06-13-2011 06:55 PM
Engine dying problem Fishing Fool Nitro Off-Road 11 07-07-2008 04:53 PM
Problem during break in Vester Singapore R/C Racers 20 04-18-2003 12:56 AM
