Old 02-28-2009, 01:29 AM   #1
jameslow's Avatar
Default Tires Wears Rate!
Hi, can anyone guide me, what can i do to reduce my rear tire wear rate? It has been wearing much faster than my front! Thanks!
Waiting!
jameslow is offline   Reply With Quote
Old 02-28-2009, 01:39 AM   #2
redsand's Avatar
Send a message via Yahoo to redsand
Use harder shore in the back.
redsand is offline   Reply With Quote
Old 02-28-2009, 02:13 AM   #3
Pattojnr's Avatar
Trader Rating: 19 (100%+)
try using 37 front and 40 rears. you may need to harden up the front springs to use a softer tyre. rear tyre wear can be caused by lack of traction. if you spin up the tryes then they will wear more. sometimes a thin diff oil can cause the unloaded tyre to spin also. a softer tyre can create more grip and by this can create the same or even less tyre wear, so many things to try.
often i will stagger tyres , if the left wears more, then i will use harder tyres in a longer main on the left side. this will even out left to right tyre wear, but you need to work out a shore from front to rear that wears even then make setup changes to accomodate.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 02-28-2009, 02:17 AM   #4
asw7576's Avatar
Yea, simple and beautiful...... and get more steering too.
( I use 37 front 40 rear for high traction, or 35 front 40 rear for low traction ).
Old 03-04-2009, 07:07 AM   #5
jameslow's Avatar
Guys, Thanks for the reply! For my case i think is bec my car slide too much n wheel spin which had cause the tires to wear much faster. Therefore if i increase more grip at my rear ( softer suspension ) will it reduce the wear? at the same time may i know how do u guys usually do setting for the rear? harder suspension or softer ? As for me is quite hard for me to use front n rear diff shore therefore i will always purchase one set of same shore tires! ha!
Waiting!
Old 03-04-2009, 08:57 AM   #6
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Are you running a 1mm spilt or even tire size? because the same thing was happening to me and I went to a 2mm spilt problem solve...You can give it try an see what happens..
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 03-04-2009, 10:11 AM   #7
musti72's Avatar
yes, more overdrive to either axle causes more wear on that axle, and less wear on the other one. But be careful, very much rear overdrive with harder rear tires would be very difficult to drive.
musti72 is offline   Reply With Quote
BMI's DB12R Mr. Shookie Electric On-Road 8730 02-11-2017 12:12 PM
Kuala Terengganu RC Track smilekt Malaysian R/C Racers 29327 03-12-2016 11:01 PM
SPRC XTREME TRACK ecrawler Malaysian R/C Racers 2160 03-08-2016 11:42 PM
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-25-2015 12:28 AM
Jump Square Arena, Sg Buloh mbskl1963 Malaysian R/C Racers 1709 07-22-2014 09:26 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
