clutch ?
Old 01-27-2002, 03:44 PM
carpet_killa's Avatar
Default clutch ?
i am woundering do all kits like the reflex nt , gt4 . ect. come with a clutch kit and if not what is the best clutch kit to get for a mt12 engine .thank you.
carpet_killa is offline
Old 01-27-2002, 03:49 PM
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
I believe all nitro touring cars come with shoe type clutch. The only exception is the MTX2 Pro Spec and V One RR which is replaced with a Centax clutch.
There is not really a "best" clutch. Its simply a matter of tuning. Clutch tuning is essential for getting the best "launch." You can alter it by adding or removing more weight on the shoes or using lighter or heaver clutch springs. You can record data when you start doing clutch tuning. Most people use Centax clutch because it can be easily tuned without removing the engine.
Dan is offline
Old 01-27-2002, 04:07 PM
Default reply
thanks , i was thinking that most kits came with clutch of some sort either 2 shoe or 3 shoe. so the centax clutch is a more heavy duty clutch and easer to tune. thank you.
Old 01-27-2002, 08:22 PM
Default where can i get a centex clutch
i have a mt12 engine ,where can i get a centex clutch, and who makes them.
Old 01-27-2002, 09:12 PM
Dan
Dan's Avatar
What car do you have?
Dan is offline
Old 01-27-2002, 09:23 PM
Default re:
trinity reflex nt
Old 01-28-2002, 03:15 PM
psycho's Avatar
I think Mugen's is the least expensive and it works well. You'll need an sg shaft engine or the sg adapter for a standard crankshaft engine. Check www.speedtechrc.com The Mugen clutch should be around $70 and you'll need a thrust bearing. It doesn't come in the clutch kit. Buy an extra and keep that bad boy lubed up.
psycho is offline
Old 01-28-2002, 04:30 PM
Default re:
ok mine has the sg shaft , great i will check it out . thank you
Old 01-30-2002, 12:34 PM
Trader Rating: 105 (100%+)
Will the mugen centax work in the relfex NT or should you use the V one R centsax. or maybe they are the same and I obviously know nothing!
dan-o is offline
Old 01-30-2002, 03:40 PM
psycho's Avatar
dan-o
I haven't seen the Trinity car up close, but it should fit. You might have to shim the flywheel or flip the pinion gears around to get things to line up correctly, but it should work. I am using a Mugen centax clutch on a Collari Innotech engine installed in a Kyosho FW04 and everything fits perfectly.
psycho is offline
