head shims and 30% question
decided on an RB Rody V12 after all the questions i asked here. btw - thanks, everyone here seems to be very knowledgable.
my question is that i plan on running 30% in this mill - do i need to shim the head at all, and if so, how do i do it? also - since this is a modded engine, will it already be setup for higher nitro content fuel? finally - is break in any different with a modded engine, and can i use 30% for break in, or no?
i pick this engine up on friday, so quick responses would be appreciated. thanks.
I do not have your answer, but you may want to check out the RB forum if you dont get your answer here.
http://www.rbproducts.com/rbww/ubb/c...ultimatebb.cgi
wow! i just registered there - what a wealth of information! thanks alot for the link!
Try using MC-8 medium plugs.
