Old 02-06-2009, 05:51 PM   #1
dvu
Default gear differential oil leak
Hello,
I have this problem both with my HPI R40 and the kyosho evo 2 wc edition i'm building. I've rebuild it several times, and always have oil leak out of the casing. ANy ideas whatI'm doing wrong? It. sems to leak where the to halves come together. I've got the rubber seal in the right place, and screw it pretty darn tight. Is it just not tight enough?
dvu is offline   Reply With Quote
Old 02-06-2009, 05:56 PM   #2
getpip's Avatar
Originally Posted by dvu View Post
Hello,
Probably nothing .. its not unusual for diffs to leak a little ..
Make sure you are not overfilling them.
You could try using 2 gaskets or even a smear of silicone.
getpip is offline   Reply With Quote
Old 02-06-2009, 06:10 PM   #3
dvu
Thanks for the advice. For me it's just not a little leak, it seems to all leak out given enough time. It just gets annoying.
Old 02-06-2009, 07:01 PM   #4
wizby's Avatar
If the two half's are not warped. Then it must be overfilling. Dont fill it above the cross shafts.
XRAY NT1 2014 NOVA KEEPON DX3R
MIKE PARKER PRESIDENT
NORTHERN INDIANA TEAM RACING ORG. MIDWEST SERIES TEAM DIRECTOR
wizby is offline   Reply With Quote
Old 02-06-2009, 10:18 PM   #5
JetMD's Avatar
I usually use some RTV on the case halves along with the gasket and that works like a charm.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 02-07-2009, 07:47 PM   #6
freestyles's Avatar
Trader Rating: 14 (100%+)
If you use to much oil it will leak no matter how many gaskets or whatever you put on it. You only need to fill your diffs so the oil just covers your spider gears any more and you will leak when you put it back together. Try using smaller amounts of oil and see how you go. This also frees up your diff action a bit as well
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 02-07-2009, 07:50 PM   #7
dvu
Thanks for all the replies.
Old 02-09-2009, 04:46 PM   #8
Nuclear Dave's Avatar
mugen mbx5's diff's had the same problem and this was the fix i read on these forums. assuming your not overfilling your diffs. the likely culprit is a warped diff housing. i found 2 things that worked to fix it. 2 gaskets will seal it, but you end up increasing the length and its a lazy fix. the other is get some sandpaper, around 600 or so. lay it on a table and lay the diff cup on it, up side down. while keeping the cup flat on the paper, rub in a round motion. peek at the seating surface after a couple revolutions and if you have a consistent surface on the lip of the cup your done. if not, repeat till you do.
would you say i have a plethora of pinata's?
Nuclear Dave is offline   Reply With Quote
Batam RC Kopitiam batamrc Indonesia Racing 3502 07-28-2015 01:14 AM
Kyosho V-ONE RRR Evo boy2rc Nitro On-Road 3234 08-07-2014 12:43 AM
New Traxxas Slash 1:10 Electric CORR Truck salteen Electric Off-Road 3949 03-19-2012 09:24 AM
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 06:23 PM
HELP! Front & Rear wheels opposing one another nikkor Singapore R/C Racers 9 11-16-2006 06:24 AM
