Old 11-07-2003, 11:56 AM   #1
Default 3PK Help!!!!!!!!
I just got a 3Pk 75MHz with HRS RX,
with the HRS rx i can't use futaba s9405 servo right?
IF i get a PCM 1074 FP-R113ip reciver do i have to get a PCm modul???????????
Justin
GoDspEed is offline   Reply With Quote
Old 11-07-2003, 12:06 PM   #2
InitialD's Avatar
Default Re: 3PK Help!!!!!!!!
You're right ! The S9405 is an analog servo and is therefore not compatible with HRS. I hope you did not get it mixed up with the S9450 servo which is indeed a digital servo...
You only need to change the receiver. No changing needed for the Tx module.
However, remember to get the same 75 MHz PCM RX. If you get the 27 MHz one, then of course you need to change the Tx module to the same 27 MHz.
Old 11-07-2003, 12:11 PM   #3
That is correct, the Futaba 9405 is an analog servo and can't be used with the HRS receiver. You can buy a Futaba 9451 digital servo for $80.
You can get a PCM 1024 R113 receiver but they use a different crystal (standard) than the HRS Rx (short). So you'll need to buy a new Rx crystal with the Rx to match the crystal in the transmitter. The PCM Rx cost about $90 and a crystal runs $15 for a total of $105.
The transmitter module is the same for FM, PCM and HRS. The transmit mode is selected from the radio's menu. The only reason you would need to change modules would be to stay legal with the FCC for changing frequency channels (Tx crystals).
I'd say buy the new servo and save the $25.
BTW, are you using a 5 cell receiver pack, the HRS Rx requires 6 volts.
AreCee is offline   Reply With Quote
Old 11-07-2003, 01:14 PM   #4
InitialD's Avatar
I've been asked what short and standard crystals are... What difference are these two types of crystals?
Strange... I run both HRS and PCM with the 3PK on my cars and I use the same crystals that I plug into the receiver... I don't know if short or standard crystals matter with 40 MHz band (which is what is legal over here).
If he was using 4 cell alkalines, it'll still make 6V right? 5 cell only matters when using NiMH or NiCD cells.
Old 11-07-2003, 01:48 PM   #5
Some people put NiCADs into the 4 cell holder.
I'm not sure about the 40MHz band but here in the USA the HRS uses the Futaba short crystal and the PCM uses the regular crystal on 75MHz.
Old 11-07-2003, 02:21 PM   #6
Registered User
Send a message via AIM to bbntc3
I use PCM and the HRS too, and I use the same xtals.
bbntc3 is offline   Reply With Quote
Old 11-07-2003, 03:57 PM   #7
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
yeahh... me too i wanna know what is actually the difference between SHORT and NORMAL CRYSTALS....
mop
mop_iko is offline   Reply With Quote
Old 11-07-2003, 04:35 PM   #8
popsracer's Avatar
Default Futaba Crystals
Guys;
The "Short" Futaba are to provide a lower profile when the RX is mounted in a Receiver box.
As long as the Frequency and Channel are compatable with the RX/TX, they will interchange.
popsracer is offline   Reply With Quote
Old 11-07-2003, 08:13 PM   #9
change the whole module just to change the frquency channels??..that doesnt sound right..
Los1Fan is offline   Reply With Quote
Old 11-08-2003, 01:26 AM   #10
sparksy's Avatar
Trader Rating: 14 (94%+)
If you want to go from 40mhz to 27mhz etc then you have to change the modual.
sparksy is offline   Reply With Quote
Old 11-08-2003, 09:29 AM   #11
That's the legal way to do it in the USA because of the FCC regulations regarding transmission of radio signals. However, you can change the crystal in the module with another channel but that is an illegal action. Wink, Wink, Nudge, Nudge. It's the same with Airtronics M8 and all the other module equipped radios.
Changing modules also allows changing bands like 75MHz to 40MHz (Not allowed in the USA) and 27MHz.
Also Futaba is planning to release an AM module in both 27MHz and 75MHz. The 27MHz AM module sounds interesting to control the Mini-Z cars or T-Maxxes.
Old 11-08-2003, 12:56 PM   #12
Default HRS RX and R113ip
Ok I was looking in my old issue of car action. And it's about the Schumacher Fusion R12 test run how is it posible to use Futaba S9304 servo with a 3PK Tx and HRS RX.
I though you only can use Digital servos with a HRS RX or is S9304 a digital servo?
so why is it i can't use futaba s9405 with a HRS RX???? or i can but it won't work right?
sIgNInG oFf
JuStIn
Old 11-08-2003, 06:16 PM   #13
I have a 9405 and it is an analog servo, a coreless one but not a digital servo. You can try to use it but it may just fry itself out and may also take the Rx with it when and if it goes.
Let us know how it turns out, OK.
Old 11-08-2003, 07:32 PM   #14
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: HRS RX and R113ip
sIgNInG oFf
JuStIn
go ahead and do it, no one will stop you.
Manticore is offline   Reply With Quote
Old 11-08-2003, 07:58 PM   #15
S9304 is not digital..they prolly didn't care about the servo frying up...it will work for a while but it won't last...
