Old 11-08-2003, 08:06 PM   #16
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
[quote]NEVER use non-digital servos with HRS
receivers. Severe damage to all electronics may
result, including the possibility of a fire. Only
digital servos may be used with HRS receivers,
including for throttle.[quote]
this is from the manual with the 3pk........
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 11-09-2003, 03:39 AM   #17
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Originally posted by sparksy
If you want to go from 40mhz to 27mhz etc then you have to change the modual.
somebody said if we have 27mhz, we may have glitches with most of RTR... thus not adviced to use 27Mhz.
But somebody also said 27Mhz in RTR comes in AM mode. Thus if we are using 27Mhz FM we will not be disturbed by the RTRs BUT THEY (the RTRs owners) WILL coz FM frequency is stronger than AM. Is it?
mop
mop_iko is offline   Reply With Quote
Old 11-09-2003, 06:55 AM   #18
AM can and will interfere with FM on the same band and channel. It is only the modulation of the signal that is different. So if you're on 27MHz FM Channel 2 you will be competing with almost every RTR using an AM radio on 27MHz channel 2.
AreCee is offline   Reply With Quote
Old 11-09-2003, 08:25 AM   #19
mop_iko's Avatar
what do you meanby "competing"? who is interfere who? and who will be interfered most?
or 27Mhz FM wont feel anything but 27Mhz Am will go haywire....?
or both will go haywire?
mop
Old 11-09-2003, 03:16 PM   #20
mop
It simply means that both signals will be out there interferring with each other regardless of the modulation, and band. An AM signal on 27MHz channel 2 will interfere with a FM signal on 27MHz channel 2 and a FM signal will interfere with an AM one. The only difference is that the FM will reject noise better than AM. But then AM will transmit slightly further.
It's like driving two cars on the street toward each other, one uses gas and the other diesel, will they interfere with each other when they crash head-on?
Old 11-09-2003, 10:53 PM   #21
I have a set of 27 mhz crystal for my AM controller, if I get a FM or PCM controller, can I use back my crystal?
TB01 is offline   Reply With Quote
Old 11-09-2003, 10:56 PM   #22
InitialD's Avatar
No you can't. FM / PCM have specific crystals. Likewise AM.
