picco xp .12 running- in >
Old 11-07-2003, 06:54 AM
Default picco xp .12 running- in
Just bought a new picco xp engine and was hoping someone maybe be able to help with running in instruction. base run-in screw turn settings for high and low speed settings.
Any help greatly appreciatted.
hachiroku is offline
Old 11-07-2003, 06:58 AM
Old Skool's Avatar
Leave the carb at its factory settings. Idle one tank of whatever fuel you plan to use; keep the temps around 200F. Allow the engine to cool completely with the piston at the bottom of the sleeve. Install a fresh plug (hot), then proceed to drive the car, but don't give it full throttle. You should only have to tweak the high-speed needle after a couple of runs. Remember that the engine won't give its full power until after a gallon has gone through it. Use after-run oil (3-in-1 works as well) after every run.
Old Skool is offline
Old 11-07-2003, 08:19 AM
stefan's Avatar
Old Skool,
you seem to have experience with Picco engines.
Here is my question.
On the Trinity site, they state 2 turns out on the low speed needle for the new carb.
The carbs I got are all 5 turns open from the factory.
How do you adjust yours?
stefan is offline
Old 11-07-2003, 10:18 AM
popsracer's Avatar
stefan;
There should be an instruction manual inside the box with your new engine. This will have the base needle settings for starting your engine for the first few time.
I do NOT recommend 3-in-1 for afterrun. Reason is that 3-in-1 is NOT meant to be burned inside an Engine and could possibly cause deposits to build up over time.
Try some 'Marvel Mystery Oil' instead. 'Marvel' oil is meant to be mixed with fuel and burned in the combustion chamber of an Engine. 4+ years of using 'Marvel' and never a problem with rust or deposits in the engines. You can find it at most Auto parts stores.
popsracer is offline
Old 11-07-2003, 10:25 AM
stefan's Avatar
Pops,
there was no manual, that's why I'm asking these questions.
Now, spill it , pleeeaaase
stefan is offline
Old 11-07-2003, 03:42 PM
popsracer's Avatar
stefan;
I only have the Manual for the older stye Carbs (4 bolts on the needle side).
Here is the settings per instructions (old stye carb);
High Speed Needle - 1-1/2 turns out from closed.
Low Speed Needle- 3 to 3-1/2 turns out from closed.
Hope this helps some.
Old 11-08-2003, 12:01 AM
Old Skool's Avatar
What Pops said...
I'll try the MMO route next time.
Old 12-21-2008, 03:18 PM
Trollkarln's Avatar
Default Wich glowplugs?
Hi! Just bought a TM G4 Evo with a Picco XP-engine in it. Does anyone know wich kind of glowplugs goes with his engine? Turbo-plugs or regular?
Thanks.
Trollkarln is offline
Old 12-21-2008, 05:51 PM
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Take the glow plug out and look at it, if it has a taper its turbo if its squared it standard
20 SMOKE is offline
Old 12-22-2008, 05:08 AM
Trollkarln's Avatar
Already done it, its a turbo-plug but i dont think its a picco-original glowplug. Its leaking when engine is running, small bubbles of fuel coming out around the glowplug.
Its like the plug is too long, but i want to make sure i order the right plug and that is why i am asking.
Thanks.
Old 12-22-2008, 01:13 PM
20 SMOKE's Avatar
i would get a picco plug for it
20 SMOKE is offline
Old 12-22-2008, 02:19 PM
Trollkarln's Avatar
Yes that is what im going to do, just want to know wich one. Turbo or regular?
Thanks!
Old 12-22-2008, 02:50 PM
getpip's Avatar
Turbo.
Picco if possible .. they have a slightly different taper than others.
Others will work but you may experience the leaking problem.
getpip is offline
Old 12-22-2008, 04:49 PM
Trollkarln's Avatar
Thumbs up
Originally Posted by getpip View Post
Turbo.
Thanks alot! Will get me some Picco-original turbos.
