Old 11-07-2003, 04:48 AM   #16
snoopy's Avatar
I've got a Rody 3 port V12 and so far i think it's a very slight improvement over my X12 Rody.
I run the turbo fluted crank versions with turbo buttons, not the EFRA ones.
Very happy with both engines, reckon they have better bottom end than the NovaRossi. Probably coz of the crank work, but i'm no engine expert.
snoopy is offline   Reply With Quote
Old 11-07-2003, 09:15 AM   #17
Grinder's Avatar
The V12 crank looks identicle to the X12 crank, the only difference is the diameter of the new crank. The NS12 has an entirely new designed crank, similar to what came in the later Michael Salven motors and the new diameter crankshaft. The NS is better out of the box than the V12.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 11-07-2003, 06:16 PM   #18
Bounty Hunter's Avatar
Default RODY all the way!
You should give the RODY's a try. I have been running the same RODY X12 for like the last 5 months. I have put probably about 4-5 gallons of Odonnel 30% and this motor ran at the Sedan Nats at 65%. I can definately say that the RODY was worth the money as long as you employ some common motor care. It is a little softer than when I first started using it, but sitll has a lot of power all throughout the powerband.
Bounty Hunter is offline   Reply With Quote
opinions on what I should be looking at? sonicboom141 Nitro On-Road 51 07-27-2005 10:53 PM
RB Concepts C5 Circuit Opinions FL_Racer Onroad Nitro Engine Zone 2 05-04-2005 08:23 PM
Silva Concepts, "Ti" Concepts now in!!! Daryl Silva Electric On-Road 0 04-29-2005 07:27 AM
Need Opinions on Tuning My NTC3! opinions on my clutch/suspenion set up needed JDMboy Nitro On-Road 0 09-21-2004 10:05 PM
STS PRO 10 II opinions xxrycecakexx Nitro On-Road 1 03-31-2003 07:47 PM
