OFNA DM-1 PRO
OFNA DM-1 PRO
just purchased an ofna dm1. does the stock motor seem to sound lean to anybody other than myself? what is the stock needle settings?
thanks
mark
thanks
mark
hsn 3 turnsout
lsn 3.5 turnsout have fun itsa greatcarif you ever need help send me a pm ...where are you located????
I am experiencing a similar problem. It did not occur until I rotated the brass fitting for the fuel hose on the HSN assembly. Before I loosened and rotated this part the engine was perfect, and easy to tune. So I would carefully look at this area. In fact Ofna has an HSN assembly that uses a composite part that fits much better.
i'm in san diego ca ....i would actually start there.....here in san diego i am running 4 turn out on the hsn.....3.5 lsn the air there is less dense so you may sound lean but as long as theres smoke your good
cool thanks. ill do that today, its 45 degrees out later.
