Old 01-29-2002, 03:14 AM   #1
Default Receiver Batteries and Charging
What do you all use for RX packs, NiCd or Nimh? And what type of charger for these, linear or pulse? Is this just regular RC charger?
People say 1 amp is max for RX packs, and that pulse is bad for Nimh, what do you all say?
I know there is some little info on this in the various car threads but I think it would be good to collect all info here!
Any recommendations or suggestions appreciated!
SHARP is offline   Reply With Quote
Old 01-29-2002, 03:50 AM   #2
chippy's Avatar
Me I use 6 volt 800mah nicad pack pulse charge at 500mah takes about 1 hr 30mins to charge but never had a prob with run time..
when discharging still have 400mah left or around that..
havent used nimh as they are heavier and I dont need any moore weight as its over weight already....
chippy is offline   Reply With Quote
Old 01-29-2002, 03:56 AM   #3
Thanks for the quick reply Chippy. What type of charger are you using? Can I use normal RC charger like used to charge 7.2volt packs like electric cars use? What about charging amps?
Old 01-29-2002, 05:18 AM   #4
GregH's Avatar
Send a message via AIM to GregH
I use the nimh pack from Serpent for the Pro, and charge it at 1amp on a T-30.
GregH is offline   Reply With Quote
Old 01-29-2002, 05:28 AM   #5
carpet_killa's Avatar
re:
just woundering . when charging i can use my novak millenium charger for the rx packs right ? cause its fully adjustable. i am using the team orion 1100 milliamp hump packs. i was just wanting to make sure .thanks guys.......
carpet_killa is offline   Reply With Quote
Old 01-29-2002, 05:40 PM   #6
got_speed?'s Avatar
Default Re: Receiver Batteries and Charging
I use 5 AAA 720 mAh nickel metals. Use Nimh mode if your charger has one.....otherwise use linear.....only use pulse for regular Nicd's.....The recomended current for AA and smaller size is 1 Amp....
I use a Novak Millennium Pro..it works great..
got_speed? is offline   Reply With Quote
Old 01-29-2002, 10:08 PM   #7
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
I use both
Mugen 900mA NiMh - charge at .7mA, about 2 hours to charge
and
Sayno 600mA NiCd - charge at 1Amp, about 35 mins to charge
Use Apex Sigma Plus charger
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 01-30-2002, 09:02 AM   #8
hurhur's Avatar
Originally posted by Novarossi
I use both
and
u use fast charge for them on the APEX?
hurhur is offline   Reply With Quote
Old 01-30-2002, 11:59 PM   #9
Michael_T's Avatar
Yeh fast charge both of them using the Apex.
Old 02-01-2002, 12:57 AM   #10
Default Thanks everyone!
Thanks for all the info people!
Mr NR you said a while ago in the MTX2 forum you were getting the Apex, I take it your happy with it? Do you have any links for this? As you are charging both Nimh and Nicd I assume it has linear and pulse modes, and what is its amp possibilities? Thanks in advance.
Old 02-01-2002, 03:30 AM   #11
Default Re: Re: Receiver Batteries and Charging
OK I found info on Apex at www.apexhk.com that answered most of my questions. It says pulse mode for Nicd AND Nimh but doesn't say anything about linear charging
got_speed? am I correct in saying the Nimh mode would be special pulse charging specialy for Nimh? ie there is a type of pulse for Nicd and another type of pulse for Nimh?
Anyone else can recommend good, not too expensive charger?
Old 02-01-2002, 03:37 AM   #12
chippy's Avatar
Default Re: Re: Re: Receiver Batteries and Charging
Anyone else can recommend good, not too expensive charger? [/B][/QUOTE]
Yeh I use Supernova 250s
Does all types of batteries nimh, nicd ,12v pb
1 to 25 cells
Old 02-01-2002, 04:02 AM   #13
Thanks again Chippy. I have seen this charger in a magazine review. Do you just have to tell it number and type of cell and the amps you want to use?
Sorry if my questions sound basic
Old 02-01-2002, 01:42 PM   #14
chippy's Avatar
Yeh its fully programablle.
Ive had mine for 18 months not a prob
Old 02-07-2002, 04:08 AM   #15
Novarossi- does the Apex have Linear charge or do you charge Nimh with pulse mode?
Another question- Is it OK to recharge Nimh RX packs when they are only half empty? I have read that Nimh don't have "memory effect", is this true in your experience?
Thanks again
Charging AA Batteries RCRat Radio and Electronics 4 06-19-2008 05:32 PM
Charging Batteries?????? Drift_Buggy Electric On-Road 2 01-06-2007 02:48 AM
charging batteries MrUnlimited Electric On-Road 3 12-01-2005 09:44 PM
Charging batteries HVAC25000 Electric On-Road 0 02-03-2005 11:27 AM
Charging 12V batteries Cain Electric On-Road 11 04-27-2004 03:46 PM
