Old 01-28-2009, 09:57 AM   #1
wmay11's Avatar
Default 21 Circuit tuning issues
Am am having issues trying to get my motors to run hotter, they cant get to 100 celciius without choking? I am running a #6 or #7 NR plug with .7mm head clearence. Pipes are 2052 and 9886, they are non conical and the carb inserts are between 8.5 and 9mm.
RX21
NS21P
JP Pro
Thanks guys.
RX8 - Savox - Reds Racing - Ko - Contact - Enneti
wmay11 is offline   Reply With Quote
Old 01-28-2009, 01:17 PM   #2
jca2000au's Avatar
Trader Rating: 9 (91%+)
RX21
NS21P
JP Pro
Thanks guys.
If your motors are running fine with under 100 Celsius and fuel last for 5 mins then why would you want to make it over 100 Celsius?
If you have speed, if you see smoke, if it last 5 mins then who cares what the temperature is.
jca2000au is offline   Reply With Quote
Old 01-28-2009, 04:10 PM   #3
wingracer's Avatar
Trader Rating: 24 (100%+)
Don't worry about it unless it starts loading up through the infield. In that case try leaning the bottom instead of the top.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is online now   Reply With Quote
Old 01-28-2009, 05:57 PM   #4
wizby's Avatar
I dont tune by temp. Use temp readings for reference/diagnostics. Use the sound and performace to tell you the tune is correct.
XRAY NT1 2014 NOVA KEEPON DX3R
MIKE PARKER PRESIDENT
NORTHERN INDIANA TEAM RACING ORG. MIDWEST SERIES TEAM DIRECTOR
wizby is offline   Reply With Quote
Old 01-28-2009, 10:05 PM   #5
wmay11's Avatar
whats the best pipe set to run at this stage? Also what inserts are you guys running for tight tracks?
Old 01-30-2009, 02:20 AM   #6
freestyles's Avatar
Trader Rating: 14 (100%+)
What do you mean "load up" Does that just mean it's to rich on the bottom and spits and gurgles a bit out of the corners
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 01-31-2009, 01:36 AM   #7
wmay11's Avatar
Load the carb up with too much fuel and splutters out of the corner. Too rich on bottom.
