Old 06-19-2004, 04:55 AM   #12736
cyba888's Avatar
Just got this today. Its made out of titanium and whats also cool about it is that the holes for the body post sits about 1-2 cm lower than the factory rear shock towers. The factory rear shock tower lowest hole is still too high for my Stratus 2.1 body. This should do the trick.
Thanks to Dino Racing!
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 06-19-2004, 05:15 AM   #12737
teammpp's Avatar
Originally posted by Proficar403
I believe the OS8 is a short plug. I believe Novarossi's only work correctly with long plugs.
I only use OS plugs in my non-turbo engines. Never had any running problems with them. Cant say the same about when I tried a nova plug.
teammpp is offline   Reply With Quote
Old 06-19-2004, 06:24 AM   #12738
B4
B4's Avatar
Default Pre Tension Springs
Has anyone tried the pre tension spring set. Not sure what performance boost it is.
B4 is offline   Reply With Quote
Old 06-19-2004, 06:43 AM   #12739
Sow&Steady's Avatar
Originally posted by jfc_tech
sorry for the long explaination...my fault, i love 710 and my baby.
Nothing to it man ... you love both the 710 and the baby, n fault in that. In fact its great!!!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 06-19-2004, 06:50 AM   #12740
Sow&Steady's Avatar
Default Re: where can i buy?
Originally posted by BIBOY
where can i buy whole set of ceramic bearings (including diff) for 710?
Biboy, try the-Border, I just got my orders today, they've been good. The same goes with RC-Mushroom but I don't know if they have the ceramic diff ball-bearings though.
Old 06-19-2004, 06:51 AM   #12741
Sow&Steady's Avatar
Wow .. titanium rear shock tower!
Old 06-19-2004, 06:56 AM   #12742
Sow&Steady's Avatar
Default Re: Pre Tension Springs
B4, I've tried them on the 705 but have not had the need to try it on the 710 yet.
They definitely work wonders for the 705. I remember a race I went to a while back. Its almost like the F1 race at the Indy track because the organisers used an outdoor roller skating ring. Half of the race track was on this part and the infield was the inside of the ring.
As you can imagine, the roller-skating part, although banked, was made of smooth concrete and the sweeper had to be taken at the highest speed possible or you end up "playing" in the D or E mains instead of "racing" in the upper mains. The only way to stop my 705's rear from sliding off was to use the pre-tension springs.
Old 06-19-2004, 09:51 AM   #12743
cyba888's Avatar
Ran the car today and went really well. I dont think at one time it ran this good. I used 35 shores on all 4. When exiting a corner a get understeer. Is there any way I can correct this without losing more steering?
Futaba 4PX
Old 06-19-2004, 09:58 AM   #12744
Nitro Tech
dino.tw's Avatar
about 1-2 cm lower
mm or cm?
There is no DinoRacing,that is hand made shock tower. Please polish it yourself.
dino.tw is offline   Reply With Quote
Old 06-19-2004, 10:08 AM   #12745
Nitro Tech
dino.tw's Avatar
I would try F35 and R37 tyres and don't touch any setting now. It will let your car a bit drifting when you leave the corner and also let your rear tyres more lasting. It's good for long time final.
You should let me rape your car today then I may join your camps...
Old 06-19-2004, 10:18 AM   #12746
Nitro Tech
dino.tw's Avatar
Nice to meet you and Jeff today....
Old 06-19-2004, 10:59 AM   #12747
cyba888's Avatar
Originally posted by dino.tw
about 1-2 cm lower
mm or cm?
oops sorry I meant mm. Dino Raicing baby! hhaha...j/k Or should I say my mechanic made it for me?
Good to see you and Jeff today at the track. Hey Dino do you think my pipe that has a tear on it can be repaired? Or just slap on the new pipe?
Futaba 4PX
Old 06-19-2004, 11:05 AM   #12748
cyba888's Avatar
Join the camp so you can rape my car anytime... Get your 200mm car soon!
Maybe we can do a sweep for the whole track and pick up tire pieces so you can build me a custom homemade 37 shore tire
BTW thanks for that tire repair You can be my mechanic anytime
Futaba 4PX
Old 06-19-2004, 11:39 AM   #12749
Nitro Tech
dino.tw's Avatar
Come'on you are a BOSS,a rich guy ok?....kakaka...
Use thermal resistances epoxy putty to fix it...
Old 06-20-2004, 09:53 AM   #12750
Send a message via AIM to kreidel
Default Re: Re: Short track setups
Here is "about" what I am running with good success. Car goes in and comes out very well on a short track. Sometimes I run with white springs in lower traction. I also sometimes do without the front roll bar.
I ran this setup and still was looking for alittle more steering, on and off power. The car never rotated on the sharp turns, it felt real planted. I reduced the rear toe 1/2 degree and still not much better. I then went to white springs up front without much luck. I ran my first qualifier with it but then switched back to my Mugen. Any input on gaining steering?
kreidel is offline   Reply With Quote
