Old 04-29-2004, 08:55 PM   #9196
InitialD's Avatar
Originally posted by Pyramid
SER-802235 Spacer Steering block & upright,
Cool. Have they arrived yet? I think you need 4 pieces right? Ummm, if they look just like ordinary piece of aluminum to support both the 10x15x4 bearings in the middle, then it's also easy to make your own...
Old 04-29-2004, 09:18 PM   #9197
Trader Rating: 2 (75%+)
Originally posted by InitialD
They should be for front and rear. They are the same length for the 710 right? But I think it's pointless installing it in the rear.
Thats what I thought...........just wanted to know from the master!
PUNISHER is offline   Reply With Quote
Old 04-29-2004, 09:25 PM   #9198
Default Re: Re
Originally posted by Wap
I know how you feel
Hey guys, just road by and looked at the new track for Texas Biggie at RCrcnt. What a beautiful track. The way the track is set up it looks like a simi-permanent track, it looks like they can change the in-field.
[email protected]#! i wish i can race.
Just a few more days until the Grand Opening Race!!
Can't wait!
Don't forget to stop by to say hi Wap..................
Look for this guy driving this body!
Old 04-29-2004, 09:25 PM   #9199
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
hey D how is that front diff working out for you?
Old 04-29-2004, 09:48 PM   #9200
InitialD's Avatar
Excellent ! Julius is right. With the front ball diffs, you can really tune how the car handles. How the car goes into the corner, comes out etc. You can tune the car without even having to tune the shocks etc.
I'll be using it in a race this weekend. Don't expect too much from the results though ! It's a huge track which would be very suitable for oneway but traction is lacking. So a ball diff would make driving more consistant.
Old 04-29-2004, 09:52 PM   #9201
Pyramid's Avatar
Yes, just simple piece of aluminum that comes in set of 4 per bag. It will sits in between bearing through axle just like the aluminum spacer on your centax. It will be cheap and not worthed to make your own.
Pyramid is offline   Reply With Quote
Old 04-29-2004, 09:52 PM   #9202
InitialD's Avatar
Default Re: Re: Re
Showing off again?
BTW, nice shell as always !
Old 04-29-2004, 10:11 PM   #9203
Easier yess!!
Lap times
Maybe its just me...
GoldFinger is offline   Reply With Quote
Old 04-29-2004, 10:31 PM   #9204
Pyramid's Avatar
S710 setup to share... Please give us feedback in case you did try it on your local Tarmac track. It`s excellent to my knowledge with planted rear.
Old 04-29-2004, 10:51 PM   #9205
Pyramid's Avatar
Forgot to mention that you would need to cut/shorten you upper arm by 2mm in order to have it set at `UBO` with -4 camber.
Old 04-29-2004, 11:06 PM   #9206
Showing off again?
LOL...Hehehehehee
Thanks!
Old 04-29-2004, 11:26 PM   #9207
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Radio
You should cycle over here. 30 to 35 degree C with high humidity !
No thanks - last summer was a killer for me. We had temperatures upto 38 Deg C and I was cycling the whole time - god knows how it didn't kill me A Malaysian guy I work with was having a nightmare - he told me he moved to Germany to get away from that kind of weather
markp27 is offline   Reply With Quote
Old 04-29-2004, 11:27 PM   #9208
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Tweak Station & Scale
Don't you have those helmet like the one Magneto wears in X-Men on his head?
Obviously, yes Don't you know anything, D?
Old 04-29-2004, 11:28 PM   #9209
InitialD's Avatar
Thanks for sharing the setup Pyramid ! Some questions...
1. UBO / LT setting is pretty high rear roll center. I think that's about the same as what Michael did in Thailand. I'm currently testing UTI / LT. Just one step lower on the rear center than yours. Seem to be pretty OK for the car. Rotates quite well. But I like to use high roll center in the front. Makes the car shift nicely and fast in the on throttle chicanes. I believe Julius is currently having the same type of rollcenters in the front and rear.
2. Noticed you're using pretty soft rear sway bar setting with the inner mounting of the rear arm...
3. How does the 80wt or 70 wt Trinity Oil compare to Serpent's shock oil weight rating? About half that?
4. How is the fixed pistons (used in the rear) different from the adjustable ones (used in the front)?
5. Concerning droop... Mind telling us what shock lengths did you use? That would determine how much droop by using your method. I'll check to see if my droop settings are like what you described.
6. DRS arm... By saying it is below, I take it that the rear wheel will toe in on cornering? I hope you took the LT position of the rear bottom pivot pin into account when mentioning the DRS arm...
Sorry for the many questions !
Old 04-29-2004, 11:29 PM   #9210
BaxterC's Avatar
Default Re: Re: Re: 710 CVD,s ????
Originally posted by Car Breaker
I think 3racing CVD should be ok, i have them on my G4 and i crash it many times , only one has slight bent , but their QC is just so so wish you luck buying them ( i buy 3 pair and only 2 pair can be use )
Are you saying that they aren't that good?
BaxterC is offline   Reply With Quote
