Old 04-23-2004, 09:32 AM   #8776
BaxterC's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Front Ball Diff
Originally posted by Marcos.S710
thanks I will
You'd better... How are things going? all going well. I hope you are nearly finished as I am sure you NEED to race!
BaxterC is offline   Reply With Quote
Old 04-23-2004, 09:34 AM   #8777
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Front Ball Diff
almost done!!! will be starting to race the first week of may
Old 04-23-2004, 09:38 AM   #8778
BaxterC's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Front Ball Diff
Nearly there.... it is payday on monday for me, then hopefully, it will be a better month, cos I am expecting my SHIPMENT!!!
I hope you can hang in there Marcos... I hope you at least get a moment to say good night to the little monster in the workshop.
Old 04-23-2004, 09:40 AM   #8779
Super Moderator
Marcos.J's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Front Ball Diff
Old 04-23-2004, 10:59 AM   #8780
Blue Sky's Avatar
Send a message via Yahoo to Blue Sky
Default Centax III
Since the car is completed, I'm ready to break in the new engine and the car itself.
When putting the car together the longest it took was to assemble the Centax. Everything else was pretty striaght forward since I have an Impulse Pro. I don't have a feel if the Centax is built 100% correctly. Here is the info, and maybe you Centax experts can give me some advice. I have shimmed the clutch gap just shy of .7mm, I added just one .1mm shim there. And for end play, I added all the shims (about 6 or 7) but there is still some end play...I didn't measure it but I'd say about .5-.6mm. The clutch bell can spin freely when crank shaft pointing either up or down.
Thanks,
Ron
Blue Sky is offline   Reply With Quote
Old 04-23-2004, 11:10 AM   #8781
Default Re: Centax III
Thanks,
Ron
Hi Ron,
Sounds like the clutch gap is okay at just under 0.7mm (you can go down to 0.5mm safely), but the endplay is WAAAYYYYY too much. The endplay should be a bare minimum... just a hint of movement but no more. 0.5~0.6mm endplay is much too much and will give you problems. Pick up more small shims and install them...
GlennCauley is offline   Reply With Quote
Old 04-23-2004, 12:38 PM   #8782
Default S710 Switch Mount
For those of you who like using simple mechanical ON/OFF switches, here is a design for a switch mounting bracket to mount a switch on the Serpent 710.
I used 2mm thick fiberglass to make my mount, but you can also use carbon-fiber.
I made two switch mount templates, one of which is shown here.
You can find the image files at:
http://www.travel-net.com/~gcauley/Switch_mount/
Note that I have posted this as an article on myTSN at:
http://www.mytsn.com/publ/publ.asp?pid=9994
Old 04-23-2004, 12:40 PM   #8783
Here is a picture of the installed mount.
Old 04-23-2004, 03:43 PM   #8784
Wap
Default Re: Re: Re: Re: VIP CARD
Originally posted by InitialD
If you're planning to go outlaw, then 5 port engines are nice to have especially on larger tracks. Else, 3 port engines are plenty powerful already especially the SS Novamega versions. Which 3 port Novamega version are you planning to get?
i want to be legal so i will stay with the 3 port.
Wap is offline   Reply With Quote
Old 04-23-2004, 03:53 PM   #8785
Wap
Default Re: Re: VIP CARD
Originally posted by PSI Racing
You need a VIP card?
The VIP card is only if you own a car like the one in the middle of this picture.
Please, I don't want to hear any crap about my car.
I still run it, and think it's one of the best cars out there.
Just takes a lot of time to set it up.
The picture was taken before Christmas last year.
That's why my 710 was still bare.
what a great collection of cars. I sold my Impulse to get the 710, i wish i had not. I think i will buy a second 710 as a back up car.
Old 04-23-2004, 03:56 PM   #8786
Wap
Default Re: Re: Re: Re: Re: Re: VIP CARD
I am going to get another engine too, I want to get a palmaris, but I dont have da cash, and the credit card is just about maxed out. I will have to wait though and my better half will freak, I told here I was thinking about it, just to see how she would react... "You already have one!" I told her that I have two cars, I need another engine. "Whatever, do what you like!" This means, do it and you're dead.
We must have the same wife. Thats what my wife says and what she means, do it and you're dead
Old 04-23-2004, 04:07 PM   #8787
SupermaxxRich's Avatar
Tell me SuperMaxx, Those Top Fuel motors you build, is it for a particular team? Those motors, they seem to lose Cylinders close to the end of the strip, is this because the motor is dying because ALL the power has been pulled from it or can you tell my why they go... Sorry, I was watching ESPN the other night and watch a lot of drag racing...
We build engines for a few teams. The reason they loose cylinders in the top end is because the engine is basically ready to fall apart!! Think of it this way, in a Top Fuel Nitro Engine, when its running its basically detonating the whole way down the track! Because of the high Nitro content the fuel mixture is actually exploding not burning!!!! By the half way mark down the track, the spark plug electrode has completely been burned off and the engine is running strictly on predetonation! Sounds weird but thats how nasty these Top Fuel Engines are. Thats why they change plugs after every pass, not to mention even if the plugs looked good, they wouldn't be runable after the beating they just took. After every pass, the oil pan needs to be taken off and every bearing in the engine must be changed. Soo much cylinder pressure that the bearings get squeezed flat!! Alot work and money to run a Top Fuel Drag Car. If you want to be competitive and run with the big boys, you need about a 5 million dollar budget to run one season. I hope this help clear up some questions you had.?
SupermaxxRich is offline   Reply With Quote
Old 04-23-2004, 07:04 PM   #8788
rwisejr's Avatar
Send a message via AIM to rwisejr
Default Just want to say Hi
I just want to say hi to all my fellow snakers.I have owned a 710 since they first arrived .I have also been lurking on this forum since it was first started.I have enjoyed and learned allot from the wealth of knowledge on this thread. I am looking forward to learning more as time goes by and we learn more about this awesome work of art and design.
rwisejr is offline   Reply With Quote
Old 04-23-2004, 07:24 PM   #8789
Default Re: Just want to say Hi
Hi rwisejr
good to see you here there are some real brainboxes here this is the only forum you need for your car people have help me a great deal here
Brett.w is offline   Reply With Quote
Old 04-23-2004, 07:32 PM   #8790
rwisejr's Avatar
Default Re: Re: Just want to say Hi
Originally posted by Voodo_Magic
Hi rwisejr
yes I have been reading how helpful they all are .Thats what I have really love about this hobby.
