Old 04-19-2004, 01:42 AM   #8416
BaxterC's Avatar
Originally posted by GoldFinger
Guys... you were posting too fast
I start to reply.. then I must answer some phone calls, after click the submit button.. its too late I guess..
It is lucky that there was some castor in that fuel, a sythetic will have burned off and the piston and liner will have been scoured Badly and could have been thrown away. the castor under high heat conditions tends to become a tacky (for lack of a better word) and sticks to the piston and sleave, protecting it from scraping. that is normally what that brown sludgy stuff is on the piston after an overheat... PHEW...
BaxterC is offline   Reply With Quote
Old 04-19-2004, 01:43 AM   #8417
BaxterC's Avatar
Originally posted by InitialD
You need faster servos man !
Old 04-19-2004, 01:44 AM   #8418
Default update
heres what it looks like now
Brett.w is offline   Reply With Quote
Old 04-19-2004, 01:49 AM   #8419
InitialD's Avatar
Default Re: update
Better.
Old 04-19-2004, 01:52 AM   #8420
BaxterC's Avatar
Default Re: update
Voodoo_Magic, I must admit, you worked some magic there, Now what you so is lube it up, The the engine rather sloppy, not quite dripping, but well lubed, then put it back together carefully, once it is together,and use a medium plug then put it in the car or in ur run in bench. then warm it with a hair dryer or a heat gun, then crank it and follow my guide from earlier, and let us know, you should be well on your way.
Old 04-19-2004, 01:59 AM   #8421
Default Thanks Guys
Just like to say thanks guys for all your help during my trying times
Old 04-19-2004, 02:04 AM   #8422
True..
I mean, if the brown colour is taken off already and the piston surface is still have a rough surface. That is a problem.
Voodo,
the piston is still good, watch the polished part on the side of piston (upper part). Is the polished part reach the upper-part of piston pin hole alredy?
GoldFinger is offline   Reply With Quote
Old 04-19-2004, 02:13 AM   #8423
True..
Voodo,
The piston does not go all the way up to the top if thats what you mean by hand anyway
Old 04-19-2004, 02:17 AM   #8424
BaxterC's Avatar
True..
Voodo,
I thought as much. If it is rough anywhere on the side og the piston there is a problem. One can get scratches in the sleave and in on the piston. I hade a 2 stroke that we bored to 4 microns bigger than the piston without the compression rings. I put the motor together (WITH THE GREATEST OF DIFFICULTY) and geared it for run-in, (a bike) I neglected to check the bearings, The motor motor would lift the bikes front wheel when you hit the powerband... WOW it had power, it was a 50cc. but it develloped a strange vibration... the bigend had sent bits into the cylinder... the bore and the piston were finished... replaced all this, and started again... I was caught by the police doing 143.1Km/h up a slight hill... What a machine...... I cant remember my point now... oh yes... the scratching, if there is a scratch, the is a problem, and a big one at that.
Old 04-19-2004, 02:20 AM   #8425
BaxterC's Avatar
This is a good thing. remember to warm the motor before you try to start it or turn it over, remember that the engine has already been stressed, and you want to relieve it by heat cycling it, but warm it so that it isn't as stressfull on the conrod and crankpin.
Old 04-19-2004, 02:53 AM   #8426
Ha ha ..
For your bike.. lighten crankshaft and cut the permanent magnet down to its smallest size will make another difference but no more uphill.
Old 04-19-2004, 03:25 AM   #8427
BaxterC's Avatar
Ha ha ..
Thank you, I went and leaned it so beautifully... but then the autolube pump started to play havoc and I seived the motor, so I sold it and said... NO MORE BIKES... only RC Cars...
Old 04-19-2004, 03:53 AM   #8428
Unhappy scratched piston
everything going well and i have just noticed a very small scratch on the piston at the bottom is this a problem and if so were can i get new parts for my dying max?
Old 04-19-2004, 04:04 AM   #8429
BaxterC's Avatar
Default Re: scratched piston
Can you get a pic of the scratch, it may not be too bad, but it may be a killer.
Old 04-19-2004, 04:20 AM   #8430
Default Re: Re: scratched piston
Here it is
