Old 11-16-2003, 03:05 PM   #796
Rene C.'s Avatar
Originally posted by PUNISHER
Hey Rene,
Can you tell us how thick the graphite rear shock tower is on the 710?
Since the rear shock tower double as the rear body post mount I would like to know.
Also do you think the 705 rear carbon body mount will work on the 710?
The shock towers are 2.5mm thick.
The 705 carbon body mount will not fit.
Rene C. is offline   Reply With Quote
Old 11-16-2003, 03:12 PM   #797
Trader Rating: 2 (75%+)
Is the front upper bumper plate graphite or composite plastic??
lol...yes, please post more picture on the 710 gallery so we can get a better look at this masterpiece!!!
PUNISHER is offline   Reply With Quote
Old 11-16-2003, 03:13 PM   #798
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally posted by Rene C.
Sure we test also other cars to see the real performance.
But to be honest, we only test other cars with some knowing setup. We don’t work on other cars. To get a car to his limit you must learn to setup, and that takes much time. We tested many cars to get much information. Ok, the other cars had not the perfect setup, but it gives an injection how the car feels.
Saying it short : We are not scared of the others.
Fair enough...
Have any US drivers(including Flyin' Ralph Burch) driven this car..and were they involved in testing if they have?..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 11-16-2003, 04:06 PM   #799
Motorman's Avatar
YBSLOW
I will begin building my 950R on Tuesday as long as the big brown truck shows up.
One serious bullet to go between the engine mounts under way, no more screwin around in 04.
U turn over a nevada rock and tenessee rolled out? LOL
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 11-16-2003, 06:24 PM   #800
Default Re: Re: Re: Re: Re: 710
Originally posted by Julius
Also with the new sizes the belts run over larger diameter pulleys (especially the front belt) which makes them last longer and run smoother
Julius
Trully this statement is what I looking for..
Because, I totally dissagre with old 16T or 17T pulley and running in both with kevlar belted.
GoldFinger is offline   Reply With Quote
Old 11-16-2003, 07:34 PM   #801
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: 710
How do you account for the 1/8th scale then that uses the 16T pulley in the middle bearing block up front with kevlar belts?
Old 11-16-2003, 07:36 PM   #802
Motorman's Avatar
its accounted for in the wallet as the 16 has always been a belt eater no matter which 1/8th scale car it was ever on. LOL
Old 11-16-2003, 07:50 PM   #803
JABRONI's Avatar
Default Starter Box
Someone may have asked this already, however I am curious if a different adapter is needed for the Powerstart Starter Box ???
Or is a different starting method required ???
Hello Motorman !!!! Scott Az.
JABRONI is offline   Reply With Quote
Old 11-16-2003, 07:53 PM   #804
Default Re: Re: Re: Re: Re: Re: Re: 710
I do not run 1/8 scale, far as I know in my 705 with 103% FR Overdrive, this 16T pulley giving the FR belt very hard time so its became loose easily and you know what happened next....
Then, there is a 5mm option, (better lifetime) but could not turn very smooth since its rubbing the pulleys inside wall.
Old 11-16-2003, 07:57 PM   #805
InitialD's Avatar
Anyway, I have never need to change my 16T plastic pulley. Still using the same one after nearly 1 year ! The front belts tear but that is because small sharp pebbles get stuck in the middle bearing block or in the pulley itself and chews the belt.
I guess if for me the 16T was already good, the larger 19T pulley can only be better !
Old 11-16-2003, 07:59 PM   #806
InitialD's Avatar
Default Re: Starter Box
I asked but I think nobody replied. I should think that they would provide the mounts for the Powerstart in the kit like they did for the 705.
At the product write up of the 710, it is mentioned below int he last lines...
To enable you to start your Serpent 710 with the greatest of ease Serpent provide the necessary alignment brackets for your Powerstart™ starter box.
Ummm, if they are indeed different mounts from the 705, then it would be difficult for those who run 705 and 710... Unless it is accounted for in the pocket to use 2 starter boxes !
Old 11-16-2003, 08:04 PM   #807
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: 710
I actually have never had the front belt loose. I run overdrive too but not much.
All of the times, the front belts break because of the pebbles !
Yes. If not installed properly, the 5 mm belt will last no longer than the stock 4 mm belt ! The flanges of all the pulleys need to be installed correctly. The smooth curve surface should be facing the pulley teeth. Else, the belts get eaten by the sharp flanges.
Old 11-16-2003, 09:14 PM   #808
Motorman's Avatar
its always best to use the biggest pulleys that can be accomodated. big pulleys=less belt wrap drag. some of the 21's I have built for some customers have enough power that snapping rear belts has even been a problem on NT's and MRX's alike so the front really becomes an issue if you run alot of OD. Only thing that seems to really work on the front is an alloy 16 tooth pulley as it stops belt skip when the car shifts on a really sticky track. YBSLOW and Tracy Grieger can vouch for snapped rear belts and they are new ones. The kevlars were the worst, fiberglass type belts streach some and tend not to shock snap we found but their worse for skip. So its a toss up. Tension becomes critical.
My old MTX2 snapped 4 side belts in the same place on Toledo's track the same day one after another when it shifted. I finally gave up and parked it.
Scotty hows it going. May join the snake camp again in the spring. It looks real good so far, I'll have to see what feedback you guys give me over the winter.
Old 11-17-2003, 12:22 AM   #809
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Its looks like Marketing @ Serpent have sent out all these Team Drivers to sell the 710
Where were these guys during the 705 + Impluse days?
Michael_T is offline   Reply With Quote
Old 11-17-2003, 12:51 AM   #810
If I were Pieter Bervoets, I will absolutely do so
(too bad I wasnot.... )
During Impulse+705 days, I thought the atmosphere was not as high as now, maybe they kept busy with da 905.. Am I right guys ?
