Old 04-02-2004, 12:28 AM   #7486
cyba888's Avatar
Default Re: Re: Re: Re: Re: Re: Slowly the 710 is getting there....
Originally posted by InitialD
Euro !
1 EUR = 1.23288 USD
Thats not a cheap engine.
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 04-02-2004, 12:28 AM   #7487
InitialD's Avatar
Originally posted by GoldFinger
On the final I decide to reduce the head shim to .25 mm (stock is .3mm) and it blast everything in front of it.
Ummm, more compression? Of course more compression is always better at the expense of high wear and more chances of detonation. What plug were you using? Usually, with a Nova pipe, Novarossi engines are spot on !
0.25 mm shim? Those aren't Novarossi shims right?
Just my 2cents
(Guys..pls explain to me what this 2 cents means? I keep seeing it and I thought it very cool so I keep writing it..)
My humble opinion !
Old 04-02-2004, 12:30 AM   #7488
InitialD's Avatar
Originally posted by Palmaris Europe
But in general it is mainly only boat and aero guys that use 60%.
I may be wrong but I know aero guys use less nitro than on road guys. More like 5% or 10%...
Old 04-02-2004, 12:31 AM   #7489
InitialD's Avatar
Originally posted by cyba888
Or you can change it by saying "just my 3 cents".
Or you could say "Just my 2 rupiah" !
Old 04-02-2004, 12:31 AM   #7490
PSI Racing's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Slowly the 710 is getting there....
That's $490.69
That's the price of a .21 engine.
And they say 1/8 racing is expensive.
PSI Racing is offline   Reply With Quote
Old 04-02-2004, 12:32 AM   #7491
Most people use it in the states. Its the same as "IMHO"
Thank you, I really appreciated it.
IMHO = In My Humble Opinion ?
GoldFinger is offline   Reply With Quote
Old 04-02-2004, 12:34 AM   #7492
PSI Racing's Avatar
IMHO=in my honest opinion
Old 04-02-2004, 12:35 AM   #7493
teammpp's Avatar
Mostly yeah, but some do use high quantities.
That other discussion started on page 240 of this thread with Julius saying about EFRA restrictions to 16% and also carries on on page 243
teammpp is offline   Reply With Quote
Old 04-02-2004, 12:38 AM   #7494
teammpp's Avatar
Very unjustifable. I dont care who's name is on an engine. Not a single .12 engine (including our Palmaris PS12) is worth more than 300 Euro.
Old 04-02-2004, 12:40 AM   #7495
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Slowly the 710 is getting there....
Originally posted by PSI Racing
That's $490.69
When you start racing competitively, all bars are raised no matter which class you are in !
I think in the recent 1/8th scale WC in Ohio, the Kyosho factory guys were like using one engine per heat with 4% lube fuel !
Old 04-02-2004, 12:43 AM   #7496
BaxterC's Avatar
Also remember that the Pylon guys (Aero racing) use no nitro... But those morors are animals to tune, and dont idle very well.
http://www.rctech.net/forum/showthre...0&pagenumber=7
BaxterC is offline   Reply With Quote
Old 04-02-2004, 12:45 AM   #7497
Thank you.
Old 04-02-2004, 12:46 AM   #7498
SupermaxxRich's Avatar
What does "use the cam of the sway bar" mean? What is the sway bar cam? There are the droop screws that go through the bumper plate and then there are set screws that are on the plastic sway bar holders. Both sets of screws affect droop, correct? Once I get this sway bar cam thing sorted out I think I have the rest understood?
SupermaxxRich is offline   Reply With Quote
Old 04-02-2004, 12:46 AM   #7499
BaxterC's Avatar
Hey Palmaris, What are the palmaris motors like compared to the Nova NS12S3A1, I have not run my motor yet, I am waiting for my kit to arrive as I have a pipe coming with it.
Old 04-02-2004, 12:47 AM   #7500
InitialD's Avatar
Using high nitro content fuels in planes is simply crazy. A friend of mine tried to use 25% in his plane. It was too powerful alright to the extend that he cannot shut the engine off. Cutting the air to the carb still made the engine combust by itself for a good while !
Ahah... it was only you discussing about the pros and cons and the effects of using higher nitro content though. Will check it out.
