Old 03-24-2004, 09:28 PM   #6781
InitialD's Avatar
Originally posted by SupermaxxRich
I keep hereing that the 710 has this nasty push or oversteer. If I incounter this problem, what would be the first areas you would adjust to correct this problem?
Like cyba888 mentioned, take a look at the setup booklet table at one of the last pages for a guide.
For me, I suggest NOT to use the kit tires. Use your own tires 40 shore front and rear. It will eliminate the understeering with the stock setup. If it's still understeering (which I doubt), play with simple things such as shock angles and anti roll bar. You could make the rear shock more vertical (up one hole) for better turn in and stay with a harder rear antiroll bar setup for more front traction.
Old 03-24-2004, 09:29 PM   #6782
InitialD's Avatar
Default Re: On Line Shop
Originally posted by clmbia45
INITIAL D:
Followed your advice and ordered from the On Line Shop in Hong Kong. Got my shipment in 9 days and saved 35%.
Thanks!
Ah, you got your P R E C I O U S toy?
Old 03-24-2004, 09:36 PM   #6783
InitialD's Avatar
Default Re: My race day on Sunday 03-21
Originally posted by Profoxcg
The second qualifier was awseome, I qualified 3rd for the main, main B. I had no accident I dont think, but at the end my car was sliding because I manages to loose a rear spring tensioner cup (the piece that hold the spring from the bottom) I just fought the push and drift.
What shore tires were you using? Did you use the kit tires?
A tip for you ! When you install your 4 shocks on the car, make sure that the notch of bottom spring cups faces towards the car and NOT facing outside. You eliminate chances of the cup dislodging out of the shaft on an impact.
I was told to used thread lock on the wheels?? (any comments?)
Ya you could. You could also use some plumbing teflon tape to make sure the wheel nut bites better. But I don't do either. I tighten them down really hard. Make sure you constantly do it before putting your car out on the track. Works for me.
I am concerned that my car didnt track straight after I changed the bent rim and had to play with the trim 40R for it to drive straing whereas before it drove straight at -0-
That's pretty normal when you crash directly at the knuckles. They steering may run a little. A quick adjustment is by using the centering and EPA adjustments on the radio to get it back to center.
Old 03-24-2004, 09:40 PM   #6784
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default InitialD
InitialD damm, you are a book of knowledge
Old 03-24-2004, 09:43 PM   #6785
InitialD's Avatar
Default Re: InitialD
Unfortunately, I don't drive like I type...
Old 03-24-2004, 09:48 PM   #6786
InitialD's Avatar
Originally posted by cyba888
Which tire truer do you have?
Unfortunately, the best tire truer out there is still the Hudy...
Old 03-24-2004, 09:49 PM   #6787
Super Moderator
Marcos.J's Avatar
you are correct , is just too much for me to afford it,
Old 03-24-2004, 09:52 PM   #6788
Super Moderator
Marcos.J's Avatar
Default Re: Re: InitialD
Old 03-24-2004, 10:14 PM   #6789
clmbia45's Avatar
What color were the protoype CVD's? What maintenances are needed for CVD's, just lubing?
They were natural tool steel. They must be lubed, and I recommend a dry lube such as Moly or teflon, or Boeshield T9.
clmbia45 is offline   Reply With Quote
Old 03-24-2004, 10:21 PM   #6790
Send a message via AIM to Profoxcg
I just took off my engine and pipe to clean and prep for next sunday, but the pipe is stained with the dirty all fused on to its surface. What can i clean it with to make it look clean close to new; same for the engine block?
doesnt an aftermarket company make CVD's?
Profoxcg is offline   Reply With Quote
Old 03-24-2004, 10:27 PM   #6791
InitialD's Avatar
Any kind of aluminum polish should take it off on the pipe. The ones on the crankcase is a little difficult.
3 Racing currently makes one. But if they are the same quality as the one made for Mugen, then I say ditch them.
Old 03-24-2004, 10:28 PM   #6792
InitialD's Avatar
clmbia45, any idea how those Serpent CVDs held up?
Old 03-24-2004, 10:40 PM   #6793
markp27's Avatar
Send a message via ICQ to markp27
Ocasionally there are some good deals to be had, too.....right D?
markp27 is offline   Reply With Quote
Old 03-24-2004, 10:44 PM   #6794
InitialD's Avatar
I'm jealous ! Rub it in man... Rub it in !
Old 03-24-2004, 10:50 PM   #6795
markp27's Avatar
The darkside made me do it
Got my Ti screws yesterday and so far I've saved a massive 8 gramms Still a few more to replace. though
