Old 03-22-2004, 08:10 PM   #6631
cox049's Avatar
Originally posted by SupermaxxRich
So has anyone tried this pipe? OFN10066 Its the only one he's got. If its garbage then I'll wait for the Rossi pipe.
They sell it at www.nitrohouse.com 40 bux , but no words about it. Looks good and usually ofna is good bang for the buck, but I wouldn't expect top notch performance
cox049 is offline   Reply With Quote
Old 03-22-2004, 09:20 PM   #6632
FTSPEEDWAY
Guest
Posts: n/a
Anybody know if this pipe will fit the 710 OFN10066? Does anyone know if its any good? I can get a good deal on one and I won't have to wait for it to come from out of town. But if its no good then I'll get a Rossi pipe.
If im not mistaken that ofna's copy of the mugen x12 pipe. If so that is the pipe im running and im extremely happy with it. It is extremely strong, performs really well and is an awesome price.
Old 03-22-2004, 09:47 PM   #6633
InitialD's Avatar
Originally posted by rodrigo1508
Where can I get those kai parts?
In Japan?
Old 03-22-2004, 09:48 PM   #6634
InitialD's Avatar
Originally posted by B
This is just me. But I am not very fond of 3Racing products. They don't have very good quality.
True. I would not get parts like CVDs from them. But from the looks of it, they seemed pretty OK. I got the front upper SSG bumper brace and the titanium 2 speed shaft. The 2 speed shaft seems to hold fine after a weekend of continuous playing.
Old 03-22-2004, 09:49 PM   #6635
InitialD's Avatar
Originally posted by Marcos.S710
Hey Dan i ran my 710 with the os.tr and you will be happy how that car runs, y car is one of the fastes in the infield. That motor has soo much low end punch. It lacks a little bit on the top -end.
Get a shorter pipe to release the top end of the engine ! You'll be surprised what the OS can do with a decent pipe !
Old 03-22-2004, 09:50 PM   #6636
InitialD's Avatar
Originally posted by Fernando_M
http://www.serpent-usa.com/serpent/sernew_1.html
Brown Centax3 shoe is coming.
Brown shoe? Would that make for more clutch slippage? The brown shoe is harder than the XP stock shoe.
http://www.serpent-usa.com/novamega/megnew_1.html
Conical exhaust adaptor for .12 engines.
Do you know if they make the entire pipe length shorter or longer? In other words, more for torque or for top end? Thanks.
Old 03-22-2004, 09:51 PM   #6637
InitialD's Avatar
Default Re: REMOTES
Originally posted by Profoxcg
Hi guys I got a 3pk, but I am considering selling it and getting a helios EX10. Any thoughts on this?
Why do you want to sell it? Both are the same in my opinion. The 3PK on the track is more useful because of the built in fail safe.
Old 03-22-2004, 09:51 PM   #6638
InitialD's Avatar
Default Re: Re: REMOTES
Originally posted by Pyramid
Both KO and Futaba are a good radio. Myself found futaba has stronger signal by turning both radio on and glithces less than the KO.
The Helios has apparently inproved in terms of signal.
We do not use much of Sanwa as somehow, OVERHERE, has the weakest signal and glitches the worst.. This is kind of remind me of excuses people use when not winning the races on some reports on the net
I would agree with you here about Sanwa radios but some racers over here believe that the radio makes the difference in driving for them !
Old 03-22-2004, 09:52 PM   #6639
InitialD's Avatar
Default Re: Marco, Initial D
It's working pretty good now, I raced it. I am going to mod the clutch weights tonight and I will also get the 835 two speed shoes. bc the car was not shifting at all.
Like Macros mentioned, your 2 speed may be shifting too early. Can the car achieve top speed on the back straight with the other cars? If you can, then the 2 speed may be shifting early. Tighten the screws in the 2 speed shoe. If the engine screams at the back straight to get up to reasonable speed, then your 2 speed is not engaging. Loosen the screws in the 2 speed shoe.
The 835 or the 705 shoes have heavier springs in them. Other than that, everything else is the same. Heavier springs would cause more problem for the 710 in your case.
Old 03-22-2004, 09:53 PM   #6640
InitialD's Avatar
They seem to be X-ray springs
But Xray springs are shorter right?
Old 03-22-2004, 09:53 PM   #6641
Send a message via AIM to Profoxcg
so what exactly is the ofna X12 pipe for?
what makes a pipe inflied pipe or top end?
is it uncommon to have more than one pipe at the track? /engine
please give a scenario
Profoxcg is offline   Reply With Quote
Old 03-22-2004, 09:53 PM   #6642
InitialD's Avatar
Originally posted by Dan_E
Thanks for your reply, I guess I wasn't clear on the exact problem. I had too small endplay (.4mm) using the instructions. Adding shims between the flywheel and the motor reduces the endplay - in my case the endplay was already too small so you need to remove the .5mm shim and replace it with a smaller one. I was able to get the endplay to .61mm by using the .30mm shim instead of the .50mm shim between the flywheel and the motor. I saw other people have the same problem as this. It's not clear in the instructions about this point, I'm wondering how critical the endplay is as I've seen some people here say that .4mm is OK, so is .4 - .7mm a good range, or do you just have to try it on the track?
I think it's the OS engine that you're using. With Nova engines, the 0.5 mm behind the brass collet is fine. In fact on mine, I add up to 1 mm (0.5 + 0.5) so that I can use less shims in the front near the thrust bearings.
Well, as lonmg as you understand the principles behind the shimming thing, it should be OK anyhow you do it !
As for the end play (spacing between the flywheel and clutch shoe), 0.4 to 0.7 mm should be OK. The larger the end play, the more agressive the clutch. Usually, if you want smoother clutch engagement (depending on your track traction and layout), smaller endplay is better. The other variable to play with is the pre-tension spring nut.
Old 03-22-2004, 09:54 PM   #6643
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Initial D
hey Initial D how are you , check out my new avatar
Old 03-22-2004, 09:55 PM   #6644
InitialD's Avatar
Default Re: Initial D
Cool. Been very busy lately and have to prepare for race thsi weekend !
Old 03-22-2004, 09:57 PM   #6645
Super Moderator
Marcos.J's Avatar
Default Re: Re: Initial D
i wish i was racing , i have to work
