Old 03-12-2004, 09:49 PM   #5806
2Lmon's Avatar
Originally posted by Pyramid
None that I know.. just make sure you tighten it enough on assembly. No locktite, you need locktite on wheel axle (as no rubber ring on it) as it might come loose on long usage (such as final).
Thanks...oh yes, I always use Locktite on wheel nuts...I've seen way too many wheels come off during a race. I know people who use Locktite even on nylon lock nuts.
2Lmon is offline   Reply With Quote
Old 03-12-2004, 10:06 PM   #5807
SupermaxxRich's Avatar
well, i straightened the wobble on the front one way by lightly pushing the pulley over. That didn't work on the rear so I guess I'll have to to pull the rear diff out.
SupermaxxRich is offline   Reply With Quote
Old 03-12-2004, 10:17 PM   #5808
cox049's Avatar
Default My car
Finally I got it all together
Went to the track to run in the engine some and crashed at speed in the second lap... front right end gone ( the aluminum pivotballs are very fragile).
LHS's don't stock 710 parts yet so I ordered a second kit as spares. I think it's cost effective on the long run
I love this car!!
cox049 is offline   Reply With Quote
Old 03-12-2004, 10:57 PM   #5809
Nice paint scheme! Looks killer. When you assembled your diffs, did they wobble at all?
Old 03-12-2004, 11:28 PM   #5810
cox049's Avatar
I just checked them. The rear has up to .6 or .7mm wobble (it has some side play) and the front is .3mm (Smaller pulley). Nothing to worry about... when those things pick up revs they'll straighten out.
Old 03-13-2004, 12:09 AM   #5811
markp27's Avatar
Send a message via ICQ to markp27
Default Re: My car
I love this car!!
Beautiful!
Hey Crashed_1, we have another brother-in-arms - nice powerbook!
markp27 is offline   Reply With Quote
Old 03-13-2004, 12:11 AM   #5812
Does anyone run 26mm rear tires on the 710 or majority of the racers are using 30mm...? Is it possible to run 26mm in the rear...?
vadn1 is offline   Reply With Quote
Old 03-13-2004, 12:23 AM   #5813
cox049's Avatar
Default Re: Re: My car
Originally posted by markp27
Beautiful!
I will never again be able to live a life without a powerbook by my side
Old 03-13-2004, 12:35 AM   #5814
markp27's Avatar
Default Re: Re: Re: My car
Obviously another graphically talented person
Back to your car pic - what do you use to mask the body work? - the lines look very clean.
Old 03-13-2004, 01:50 AM   #5815
markp27's Avatar
Originally posted by InitialD
Yes of course. Not blocks made by Hudy but a decent droop gauge and droop measured at the bottom of the knuckle.
No worries and no Jedi tricks to the numbers !
I meant to ask you this earlier - which droop gauge are you using?
Is that Mazda of your's ready yet?
Old 03-13-2004, 01:52 AM   #5816
crashed_1's Avatar
Beautiful!
Nice body...nicer Titanium Powerbook..
Together we shall fight this war...
crashed_1 is offline   Reply With Quote
Old 03-13-2004, 07:28 AM   #5817
cox049's Avatar
Default Markp27
The masking tape I used is "pactra" 1/4" to divide the colors and than regular one to fill out the big areas. It's a very easy tape to work with!
Thanks for the good comments on the graphics! It's nothing special but been a rookie at paint jobs I wanted to to play it safe and have a simple yet racy look.
Old 03-13-2004, 07:30 AM   #5818
Diesel Racer's Avatar
Updated my website to include my 710 and courtesy of markp27 there is a link to his 710 FAQ pages, I'll try and keep the link up to date for easier reference.
http://www.markanddebbie.net
Diesel Racer is offline   Reply With Quote
Old 03-13-2004, 09:20 AM   #5819
InitialD's Avatar
Originally posted by 2Lmon
Been following this thread since the beginning and I always find the answer I'm looking for. I just have one question...is it necessary to use Locktite on the Centax 3 pinion gears? I've always used Locktite on my Centax 1, and never really ran without it, so I don't even know if it's necessary. Has anyone had any issues with pinions coming loose? Thanks.
To tell you the truth, I stopped using loctite on my car after I stripped the engine screws ! Perhaps I was new at that time and never thought that you just needed a little of it to get it to work.
I only use on the grub screws on the aluminum pulley adapter. I only use on the grub screws on the aluminum pulley adapter.
I don't use loctite on my Centax pinions and on my engine screws as well as the wheel nuts. I just tighten them up very tightly.
Old 03-13-2004, 09:22 AM   #5820
InitialD's Avatar
