Old 03-09-2004, 03:59 AM   #5596
markp27's Avatar
Send a message via ICQ to markp27
Originally posted by InitialD
Ummm, you mean uptravel of the arms (downtravel of the chassis)? I'll check it out tonight.
Yep, the uptravel of the arms - i.e. nasty affects of having virtual up-stops!!!!
I feel for you ! Well, it is good and quick solution when the track is slippery. Else, the front diff is always a better compromise when traction is low.
Just look on my clubs website and there is anyway "bahndienst" for at least the next two weekends, i.e. get the track to "working" order before the season starts, so i couldn't drive this weekend even if I did have my motor PHEW!!
markp27 is offline   Reply With Quote
Old 03-09-2004, 04:02 AM   #5597
markp27's Avatar
So that I can go faster? Any colour will do lah ! But I already have the Mazda body. Could just leave it there for you to collect !
What's this "lah" word I keep seeing on the Malaysian forums?
Old 03-09-2004, 04:25 AM   #5598
crashed_1's Avatar
Visit Malaysia someday and you'll know lahhh...
crashed_1 is offline   Reply With Quote
Old 03-09-2004, 04:27 AM   #5599
crashed_1's Avatar
My apologies ! What decals? The one that comes with the body or masking decals for you to paint?
Serpent decals...whatever decals you have lah. It'll help in plotting out the design. Sponsor decals?
No need for masking decals. It's hand made.
Old 03-09-2004, 04:55 AM   #5600
markp27's Avatar
Almost did a few years ago, but never got round to taking up the offer
I'll ask my Malaysian friend
Old 03-09-2004, 05:14 AM   #5601
BaxterC's Avatar
Not if I paint them, when I paint them, I got an airbrush to play with and the bugger wants to play... I may get an MG body if I get a response on that one and paint it good and propper, I have the design all figured, similar to the little picture I use under my name...
BaxterC is offline   Reply With Quote
Old 03-09-2004, 06:28 AM   #5602
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: Re: Re: Re: Re: Re: 710
Ah, now I can see it ! Nice shots.
Is that a BMW M3 body? Marcos, I think you should change the bodyshell. Use the good old Stratus or the Stratus 2.1 or the newer Alfa 2.1 and the Mazda 6. It'll do a whole lot of good to the car.
I knw some one gave me that body to try it worked ok , i will get the stratus 2.1 for the next race.
Old 03-09-2004, 07:05 AM   #5603
cyba888's Avatar
Whatever you do dont use the "lah" word any where else besides Malaysia. Its only for Malaysians! If you do then people will probably look at you like...WTF?! Unless you look Malay... Leave that "lah"word for the Malaysians only
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 03-09-2004, 08:32 AM   #5604
cyba888's Avatar
Do you guys lube the bearings for the wheels? Arent they sealed bearings? If so how often do you lube it and with what?
Futaba 4PX
Old 03-09-2004, 08:41 AM   #5605
markp27's Avatar
There is a link in the FAQ to a mytsn article about lubing the bearings.
All bearing should be lube at regular intervals - a lot of folks like to do this after each race weekend, to ensure none of the bearings are damaged.
If you're not racing, then you can leave them longer without lubing them - but every two to three weeks is still pretty sensible.
Also, you should lube the dogbones, again there is a section in the FAQ that gives information about this.
Cheers, Mark.
Old 03-09-2004, 09:08 AM   #5606
markp27's Avatar
Default 710 FAQ
I've re-organised the lubing sections, so they all are in one part of the FAQ. Also I added information about the rear track width and how it can affect the rear arm up-travel.
Cheers, Mark.
Old 03-09-2004, 09:23 AM   #5607
cyba888's Avatar
Dont you need to remove all the pivot balls in order to take out the dog bones and lube it? Aint that a bitch! Unless you take out the pivot pins from the arm.
Futaba 4PX
Old 03-09-2004, 09:42 AM   #5608
markp27's Avatar
I think you can simply remove the upper rear pivot ball to get access to the rear dogbone, and at the front, you just need to loosen them off and not remove them.
It goes pretty smoothly, actually and as this would be done after a day at the track, you'd probably be resetting your setup anyway, so there isn't so much extra work - the big advantage is that your car will be running optimally on the next run
Old 03-09-2004, 09:50 AM   #5609
markp27's Avatar
Talking Stupid idea of the day
I was just thinking how great it would be to also have a one-way bearing at the rear end of the car, too, instead of a diff - I was racking my brains as to why it hadn't been done yet, when it suddenly occured to me that you wouldn't have any brakes anymore Thinking can be dangerous for those without talent
Old 03-09-2004, 11:08 AM   #5610
InitialD's Avatar
Hmmm, I've got a bottle of Glitzy Copper lying around.... Mix that with Flourescent Green and some Cherry Pink...PERFECT!!!
I want that colour scheme !
