Serpent 710
#5146
Originally posted by cyba888
Just out of curiosity how old is everyone here?
#5147
Re: I'M A PAPPA!!!!!
Originally posted by markp27
Look what's arrived!!!!
Send it over and I'll assemble. test and qualify it for you.
#5148
Originally posted by BaxterC
Hey look, I found D's car...
#5149
So far we have only been able to gather a partial picture - here is one, not showing much except that he has a tash!
http://www.rctech.net/forum/attachme...&postid=507744
OK, OK boys and girls, enuf fun about the Master!
#5150
Originally posted by crashed_1
*clue*
what goes with polka dots?
*clue*
Bikinis???
#5151
Trader Rating: 27 (100%+)
hey thaks for the pics.
#5152
Ehm, let me see Man, this is as hard as one of the "does-this-look-ok" questions from my girlfriend! Ehm, what goes with polka dots, errrrrr Hmm, can't find anything here - ok, well as only one asian guy has a non-plain top, I have to say stripes!
#5153
Originally posted by Sow&Steady
Pyramid, I looked at my car again and I think you're right, there may not be a need to cut that part. Alternatively, cut a shallower grove instead.
The second milled part is not that important, but I guess all workshops will charge you the same with or without it
#5154
#5155
#5156
I'm awaiting the very same package!!! Can't wait to see that box at my door. Should be here any day now!!!
#5157
ok D must be the guy on the right with cap, stripe shirt and glasses? I dont see no one with bermuda's on.
Like you guys mentioned he has a pot belly
#5158
And for your information, I am not wearing glasses nor contact lenses at the moment !
#5159
Rene Cornella's 710 Setup in Brazil
For those who are interested in setup with a front diff on the 710, here's Rene's recent setup also posted on mytsn;
Suspension geometry Front:
Downstops: +2
Set-up ride height: 6mm
Camber Left: 1.5 degree
Camber Right: 2 degree
Track-width: 199.5
Toe-in: -2 degree
Caster setting (mm in front): 4mm
Roll-center position upper arm (mm): 2mm
Upstop (mm): -
Suspension geometry Rear:
Downstops: 8mm
Camber Left: 2.5 degree
Camber Right: 3.2 degree
Toe-in: 1.5 degree
Track-width: 200
Roll-center position upper: low out
Roll-center position lower: low
DRS arm position (low-mid-up): level
Shockabsorbers Front:
Springs: red
Oil: 35
Holes: 4 of 5
Cilinder type: comp
Shock-tower position: 2
Shockabsorbers Rear:
Springs: red
Oil: 35
Holes: 3 of 5
Cilinder type: comp
Shock-tower position: 1
Lower shock position: outer
Anti-roll bar front:
Thickness: std
Position: 20 degree
Anti-roll bar rear:
Thickness: std
Position: 2mm
Position on lower arm: inner
Tires Front:
Make: ellegi
Hardness Left: 40
Hardness Right: 40
Diameter: 63
Wear in 5 min. Left: 0.4mm
Wear in 5 min. Right: 0.7mm
Tires rear:
Make: ellegi
Hardness Left: 40
Hardness Right: 40
Diameter: 63
Wear in 5 min. Right: 0.8mm
Transmission:
Pinion 1st: 17
Pinion 2nd: 21
Gear 1st: 61
Gear 2nd: 55
Front axle:
Type: diff
Diff. setting: mid-hard
Rear axle:
Type: diff
Diff. setting: soft-mid
Aerodynamics:
Body: Alfa Protoform
Wing: std
Gurney strip:
Engine and pipe:
Engine: Mega
Version: 2106 MS
Head shims: 0.3mm
Glowplug: 7 TF
Pipe: 2171
Header: 2174
Length: fix
Fuel: mixed
Remarks:
Chassis performance: easy to drive and fast.
Engine performance: good. One of the best engines out there.
Test remarks: Oneway is faster, but differencial is more consistent. If there is more grig, i will turn to oneway.
Perhaps Rene could post some of his comments on why he used what he used.
Downstops: +2
Track-width: 199.5
Toe-in: -2 degree
Upstop (mm): -
Downstops: 8mm
Toe-in: 1.5 degree
Track-width: 200
Springs: red
Oil: 35
Holes: 4 of 5
Cilinder type: comp
Springs: red
Oil: 35
Holes: 3 of 5
Cilinder type: comp
Thickness: std
Position: 20 degree
Anti-roll bar rear:
Thickness: std
Position: 2mm
Tires Front:
Make: ellegi
Hardness Left: 40
Hardness Right: 40
Diameter: 63
Tires rear:
Make: ellegi
Hardness Left: 40
Hardness Right: 40
Diameter: 63
Transmission:
Pinion 1st: 17
Pinion 2nd: 21
Gear 1st: 61
Gear 2nd: 55
Front axle:
Type: diff
Rear axle:
Type: diff
Aerodynamics:
Wing: std
Gurney strip:
Engine and pipe:
Engine: Mega
Version: 2106 MS
Head shims: 0.3mm
Glowplug: 7 TF
Pipe: 2171
Header: 2174
Length: fix
Fuel: mixed
Remarks:
#5160
So which one are you D? let it out
