Old 07-12-2007, 08:01 PM   #23266
thamjk's Avatar
Originally Posted by ck960 View Post
thanks for the reply,
so does this mean when i use 22/47 at the rear... the side i should put 22F/21R and the optional 18T at the front to compansate???
the rear belt with 22/47 conf is very good fit and not too tight... still cant find the 45T gear diff pulley... thanks,
cheers,
ck
your new front internal gear ratio would be 2.037
and your rear internal gear ratio would be 2.136
different by 0.1 it means alot for the car and I think it will create a lot of drag
if you have rear drive pully of 23T then you can achive a close ratio which is 2.043. different by 0.01
the 710 rear gear diff 802600
hope it helps
Serpent 710
Nova MAX
3PK
thamjk is offline   Reply With Quote
Old 07-12-2007, 08:07 PM   #23267
thamjk's Avatar
Originally Posted by cwai101 View Post
Hi,can testt out with 22f/22r , 17/59 n 22/56.with front solid.
set the 2nd gear engeage slightly later using only your first gear (6.5 ratio) to push the car futher and runing 21/55 in your 2nd gear will be nice.
having closer both gear ratio you won't experiencing a drop in your engine rpm when 2nd speed kicks in. momentum will be carried all the way -up..
have fun..
Serpent 710
Nova MAX
3PK
Old 07-12-2007, 08:37 PM   #23268
[QUOTE=thamjk;3479999]your new front internal gear ratio would be 2.037
hope it helps[/QUOTE
thanks, u have been great help...
with the new drive ratio... my current setup is using both gear diff 30k F and 10k R... the car handles quite good to my driving style i like the accer and mid it gives me
cant find a 23T but maybe i'll try 18T front and 22f/21r to get the ratio closer and play with tire size 2 to 3mm diff (this is calculated from the serpent drive cal)?? is it ok this way?? between, how do u get those numbers?? thanks,
cheers,
ck
ck960 is offline   Reply With Quote
Old 07-12-2007, 09:33 PM   #23269
thamjk's Avatar
cheers,
ck
what i mean here is if you run 35/18 (front pulley) and 22/21 (side pulley), you will get front of 2.037 internal ratio. Xray use to call "DTR ratio" 2.05.
calculation for internal gear ratio is front (35/18)*(22/21) = 2.037
rear (47/22) = 2.136
(47/23) = 2.043
calculation for final gear ratio = (spear/pinion)*(internal gear ratio above)
I have been searching for 23T even some parts from 705 but not available.
again hope these help your research...
Serpent 710
Nova MAX
3PK
Old 07-13-2007, 03:57 AM   #23270
(47/23) = 2.043
Thanks for all the help and support in my experiment...
will try it out, if not good... i'll go back to std...
cheers,
ck
Old 07-13-2007, 08:34 AM   #23271
Default t
have fun..
Hi,tham so my 1st gear remain 17/59?will try it out on 2nd gear as u mention.see how it go.Wanted to try out front n rear using 42 shore ,any advise on set up .Cheers
cwai101 is offline   Reply With Quote
Old 08-13-2007, 04:52 PM   #23272
gearhead13's Avatar
I have had my 710 for 3 or 4 months now and run it on sunday race days and practice tuesdays.
My front belt has been coming off quite a bit lately. I have the front cams set at the tightest postion. I run a front diff.
Are the kit belts lower quality than the replacement ones? Or is this normal?
Why dont the diffs have guides to keep the belt on??
tia
Richard
Serpent
Xray T2
OFNA/Picco red dot
Picco 2607 pipe
Dynamite race 20%
gearhead13 is offline   Reply With Quote
Old 10-13-2007, 01:08 PM   #23273
Pat Clark's Avatar
i know this is an old thread but figured i would try anyway... does anyone have a good starting point for gearing on a 160ish foot straight and pretty open and flowing in field? i ran the stock gearing last weekend and 1st is really snappy off the corner but second seems to run out of stream about 3/4 down the straight... any info would be really helpfull thanks
Pat Clark is offline   Reply With Quote
Old 10-13-2007, 08:00 PM   #23274
Hi,
I've been thinking of buying a 710 RTR. It comes with a Mega SP12 but I have to buy a starter box separetly. My LHS sells the black starter box, not the grey/silver one. Does it work for the 710?
Also, if anyone has got a Mega SP12 or a 710 that came with the Mega SP12, can you please tell me if the engine is anygood and if its fast and durable.
luismx123
luismx123 is offline   Reply With Quote
Old 01-04-2008, 09:48 PM   #23275
Mike Schumacher's Avatar
Trader Rating: 36 (100%+)
Anyone has good setup for running with front diff?
Mike Schumacher is offline   Reply With Quote
Old 01-05-2008, 09:06 AM   #23276
Sow&Steady's Avatar
Depending on the track and your driving, you might find a few good ones at 3hobby.net ... look under "Setup Sheets" in the Downloads section.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 01-21-2008, 03:40 PM   #23277
NitroMaxx3.3's Avatar
Trader Rating: 19 (100%+)
hey, i just picked up a serpent 710 from someone on the site. i am having some problems with the rear end. when i start the car and hit the throttle the front wheels move like they should. the rear wheels barely move. i am new with these type of cars my last nitro touring car was a ntc3 so im going from shaft to belt. All the belts are in the right place. any help is appreciated. thanks
NitroMaxx3.3 is offline   Reply With Quote
Old 01-21-2008, 03:45 PM   #23278
Pillbots's Avatar
Check the rear belt isn't stripped (no teeth in some parts).
Pillbots is offline   Reply With Quote
Old 01-21-2008, 03:53 PM   #23279
the belt looks to be brand new
Old 01-21-2008, 03:59 PM   #23280
Derby Bros Racing's Avatar
The pulleys have set screw on them. Make sure they are all tight and hitting the flat spot of the shafts.
Derby Bros Racing is offline   Reply With Quote
