Old 11-27-2005, 09:52 AM   #22666
Ridder's Avatar
Default Mega pipe
This pipe is supposed to be good:
http://shop.the-border.nl/product.ph...820&quantity=1
But: no info on MyTSN, you also have to buy a manifold and then the price goes up to 100 euro's...
I bought a Mielke pipe, that's very lightweight and supposed to be a good pipe.
http://www.storm-discount.com/catalo...roducts_id=865
Storm Discount also has cheap foamies!
Check out the Twisters...
Ridder is offline   Reply With Quote
Old 11-27-2005, 02:13 PM   #22667
wolfejohne's Avatar
Default Mega Pipe
The pipe I was told to use by Palo was the MEGA 203002 (Pipe-Set Inline ZX12 Conical). This is the EFRA 2607 pipe. I have fount it to be the best pipe I have used, and good gas milage on my MEGA ZX12, OS TR12 and several Murnan Modified x12's.
wolfejohne is offline   Reply With Quote
Old 11-28-2005, 03:05 AM   #22668
Ridder's Avatar
That's this one:
http://shop.the-border.nl/product.ph...8&cat=0&page=1
To me it looks like it is the same as the one I mentioned, but with manifold.
When you look up "203002" on myTSN (product finder)...then there's nothing...
The only exhaust product I can find for a ZX12, is the manifold (#203047), but no pipe...
Now the racing season is over here in Serpent country, it might be a good idea to do some website maintenance...
Old 11-28-2005, 06:14 AM   #22669
Pyramid's Avatar
Ridder,
2607 pipe set (203002) is picco pipe that made to fit ZX12 or any other picco engine perfectly. The newer pipe releases 203048 is the exact same pipe with Max Power 2602 (new version with bigger manifold diameter). NR denotes for novarossi which means if you going to put it on Megas, you need that thicker manifold gasket (provided). I suggest you get 2607 (203002).
Pyramid is offline   Reply With Quote
Old 11-28-2005, 06:26 AM   #22670
Send a message via ICQ to Lassis
Ok, Thank's
to all
Luciano Assis
Virtual RC Racing
- Champion World Series 1:10 Sedan 2008 and 2009
- Champion Winternats and Spring Series 2008 1:10 Sedan
- World Champion 1:10 Sedan 2007 and Winter Series 2007 1:10
Lassis is offline   Reply With Quote
Old 11-28-2005, 11:32 AM   #22671
jag
jag's Avatar
Default New Chassis
I am going to be giving the new chassis a try on Wednesday night and was wondering if the setup was the same or is their any other info. I might be interested in. The receiver bracket and 61t 1st gear look very close to the bottom of the chassis.
Thanks,
jag
jag is offline   Reply With Quote
Old 11-28-2005, 12:00 PM   #22672
Julius's Avatar
Thanks,
jag
When using the lowered chassis, you need to keep a closer look on the 1st gear. It is a little more prone to damage so keep an eye on it and if in doubt change it before a main. You can use the damaged gears in practice again.
Setup wise you have two options. Use all the values of the normal chassis. In that way the cg of the car is lowered by 1mm.
Or use all settings of the normal chassis except ride height and downstop. If you set downstops 1mm lower and ride height 1mm higher, you'd end up with the same cg ast the stock chassis but 1mm more ground clearance. This is good on bumpy or very high tire wear tracks.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 11-28-2005, 01:50 PM   #22673
jag
jag's Avatar
Thanks, Julius.
I've been having a traction roll problem lately so I'm hoping the lower CG will help. I have the car as low as I can run it (5mm) and the tires are small (60mm or less) 40 sh but they prep the track with VHT and the traction is very high. I think I'll try 42 sh next time.
Any other suggestions?
jag
Old 11-28-2005, 02:50 PM   #22674
Julius's Avatar
Thanks, Julius.
jag
Well, you could try a solution used by Paolo and others at the high traction us races. They cut the front tires so they are a smaller width. to 24 or 22 mm in stead of 26.
Old 11-28-2005, 03:02 PM   #22675
jag
jag's Avatar
I have seen that before but have never tried it.
What does it mean when my front tires wear to a sharp edge on the inside edge? When I put the tires on I have nice rolled edges and after 2 qualifiers the inner edge is sharp but the outer edge is still nice and round. Do I need more camber or is that the way the tires wear?
Thanks,
jag
Old 11-28-2005, 03:10 PM   #22676
soc123_au's Avatar
R/C Tech Charter Subscriber
Thanks,
jag
Sounds like you have either too much or too little camber. Hard to say which without a picture. Are the tyres wearing flat or coning. If they are flat I would reduce camber a tiny bit. If they are coning adjust the camber whichever way you need to to get them wearing evenly.
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Old 11-29-2005, 12:44 AM   #22677
Julius's Avatar
Thanks,
jag
It could be you have a bit too much front camber. I like to see a slight cone to the rear tires and the fronts wearing almost flat (just a hint of a cone to the inside). If you have that I wouldn't worry about the edge too much.
Old 11-30-2005, 05:44 AM   #22678
Sow&Steady's Avatar
Yes, definitely keep an eye on it ... I lost my second final at the Euros after the first gear spur stripped.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 11-30-2005, 06:27 AM   #22679
jag
jag's Avatar
What gear were you using 60, 61? Was it hitting the ground or was it damaged by debris?
Old 11-30-2005, 06:31 AM   #22680
jag
jag's Avatar
They look to have a slight cone to the outside (slightly smaller on the outside). I added .5 degrees of camber (2 degrees total) to the front. I guess I need to file the inner edge after each heat.
Thanks guys,
jag
