Old 08-27-2005, 04:40 AM   #22171
Julius's Avatar
Originally Posted by jag
Things to try next time:
- less toe-in in the rear (2 - 2.5)
- less toe-out in the front (.5)
- 2.5mm rear sway bar
- 5 holes in the shocks (should I do this front and rear?)
- put grub screws in the flyweights
- gearing (61t 1st gear)
jag
- Will give more off power steering and more on power oversteer.
- Should give slightly less turn in but less difference in off-on power steering
- More steering and mabe more predictable rear end.
- Results depend on the track
- Less clutch slip
- More wheelspin. Might give less performance as a too short gearing will rev hard but give no forward speed. I never use the 16t for that reason. It sounds quicker but isn't.
I suggest if you struggle with on power oversteer to try a bigger difference in the diff settings. Harder in front and softer in the rear. Have your pitmonkey adjust (little by little) the tightness of the front diff and see if you can get the balance you want.
What body are you using?
Which shock positions?
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 08-27-2005, 01:55 PM   #22172
jag
jag's Avatar
- Less clutch slip
Do you agree with my list of changes (except the gearing)?
I was afraid that the 16t 1st gear would do that. I will not try that. I have used the 61t, at the advise of Paolo, and it seemed pretty good but that was on a faster track (Ft. Meyers).
So would you clasify my problem as "on power oversteer"? I didn't know that. I learned something new today. Knowing the proper terminology may prove beneficial. I will have my "pitmonkey" experiment with that. (Justrace, I am refering to you).
I am currently using a Dodge Stratus body (the old one). I have a Cadillac body and a Mazda 6 that I am going to try once I get the setup finished.
I have the rear shocks mounted:
top - 1 up from bottom
bottom - outside
Front:
Red springs and 3 holes.
Any chances you would come to Fla for the WinterNats?
Thanks, Julius
jag
jag is offline   Reply With Quote
Old 08-27-2005, 02:17 PM   #22173
JustRace's Avatar
jag
I'm there!!! Just let me see if my wife will let me out on a Wednesday night If not you should come to GoRacing.
Julius coming to the Winternats? I'll be your pit monkey. Oh wait...I'm already Mark's monkey.
JustRace is offline   Reply With Quote
Old 08-27-2005, 03:52 PM   #22174
Julius's Avatar
bottom - outside
Front:
Thanks, Julius
jag
No chance of me coming to Fla. I love that race though.
I'd go down to the lowest pos on the rear shocks on the top and experiment with going one up in front.
Old 08-27-2005, 04:00 PM   #22175
markp27's Avatar
Send a message via ICQ to markp27
I haven't forgotten
markp27 is offline   Reply With Quote
Old 08-27-2005, 07:57 PM   #22176
jag
jag's Avatar
I will go move my shocks right this minute... well maybe after the football game is over.
If you change your mind about the WinterNats just let me know. I would be honored to be your pitmonkey, waterboy, whatever. You probably travel with your own support staff... big time racer like yourself.
BTW, You know they just repaved the track. It's very nice.
Thanks,
jag
Old 08-27-2005, 08:05 PM   #22177
jag
jag's Avatar
I'll give you a call. Just give the wife the credit card... or is it some crown moulding? What are you doing tomorrow? I think I have the day to myself. Julius, do you want to fly over for some practice? The hurricane is gone.
Don't spread yourself too thin. You know you have to support me, O, Niketa, etc... It's tough when you are the best mechanic around.
jag
Old 08-28-2005, 02:20 AM   #22178
Sow&Steady's Avatar
Originally Posted by InitialD
Who?
Ummm, cut the old man some slack will ya... The man's got to do R&D work. So sometimes he does weird stuff on the car... Or was putting a *spit* spring in the Centax III a typical case of lame excuses for doing too many things at a time?
Yeah, Julius saw it when he took my clutch apart and really spat on it!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 08-28-2005, 02:21 AM   #22179
Sow&Steady's Avatar
Ah... That's a trick I see. More like an excuse for you guys NOT to use a microscope, eh?
Old 08-28-2005, 02:22 AM   #22180
Sow&Steady's Avatar
"Euros 05 Scenes" video is out! Its mad but 6 fun days were squeezed into 6 minutes, you know where to get it!
Old 08-28-2005, 02:55 PM   #22181
Hi there!
What is the difference between the red soft shock bladders and the oem black ones? I currently run the redīs, but one shock is leaking from the top and I only have blackīs as spares...
fulcrum2 is offline   Reply With Quote
Old 08-28-2005, 07:56 PM   #22182
Originally Posted by TShirt Man
Anyone out there using the 2500 receiver batteries? If so, where do I get a pack? I am tired of charging my packs before every heat! Thanks!
Wow! 2500 RX packs. Where do I find that?! I use a 2500 TX pack with my 3PK
http://cgi.ebay.com/SANYO-Futaba-3Pk...QQcmdZViewItem
With Spektrum, it last even longer.
Suggest 900mAh for the RX though.
going4#1 is offline   Reply With Quote
Old 08-28-2005, 08:00 PM   #22183
Originally Posted by fulcrum2
Hi there!
I'm not sure what you mean by OEM. Aren't they both Serpent made products? Anyway, red soft shock bladders are . . . . soft. Black, not soft. My experience has been black has cracked while red has not.
When are the RCC shocks out? Anyone use them? They look really cool.
Old 08-29-2005, 12:03 AM   #22184
OK, with "oem" I meant the ones from the kit. They are also Serpent for sure...
Old 08-29-2005, 07:41 AM   #22185
jag
jag's Avatar
Hi there!
The red ones are softer and they come with a foam insert.
Check it out, #909446. I just ordered a set.
jag
